Question about Hauppauge Wireless Headphones
We just purchased an AUVIO wireless headphones. The transmitter is on (red light), the headphones are on (blue light) but we have no sound on the head sets although all connections have been made to the tv. what can be wrong???
Where do I find the model number
The words "red and blue lights", "paired", "connect" and "beeps" make me believe that your headphones are Bluetooth-enabled. However, I never heard of a TV that is Bluetooth-enabled. Therefore, I do not think that you will be able to pair, nor connect your headphones to your TV. If you want to listen to your TV wirelessly, you will have to use regular (not Bluetooth) wireless headphones, which consist of two pieces: the headphones and a transmitter that connects to the audio output(s) of your TV and transmits the sound from your TV to the headphones wirelessly.
Dec 06, 2014 | iHip Audio Players & Recorders
Can I connect to Vizio TV with blue tooth
If your ear buds have been connected to any device before your TV then it won't work. If you want to connect it to your TV you turn on your headphones, hold the call button for 3 seconds, and you will see ur light flash and connect it to your TV. If this didn't help then go to the manual and check how to connect your headphones to your TV.
May 24, 2014 | AUVIO Bluetooth Headphones
Red light wont turn off on auvio headset
While your headphones are charging press and hold the call button and volume up button and your problem is solved.
Mar 22, 2014 | AUVIO Bluetooth Headphones
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Manual for Auvio Bluetooth Speaker
My Bluetooth speaker's light for the Bluetooth (middle light) blinks rapidly, alternating blue and red. Any ideas?
Jun 10, 2013 | AUVIO Bluetooth Portable Speaker
Sharper image indoor/outdoor wireless speakers and transmitter has no audio.
First, determine if the TV device is putting out sound by plugging in a headphone into the audio out of the TV. If audio is there then the
transmitter and wireless speakers system may be at fault.
You can also plug in a CD player playing a disc into the transmitter to see if that source then transmits the audio.
Aug 21, 2012 | Audio Players & Recorders
My Freepulse headphone won't pair anymore. Both components charge, both both of them display the red LED light. I've tried the override button on the transmitter, and I've tried holding the power button...
You hold the button on the transmitter for about 50 seconds - light flashes red, solid red, goes off and then flashes blue and red. Then you can do the same on the headphones. Then wait and they should pair.
Jun 29, 2010 | Logitech FreePulse Wireless Consumer...
I have Logitech wireless headphones for my Ipod, and I can't get them to work. When I press the on button on both pieces, it goes solid red and not blue.
Visit the Logitech support website and find the instructions to reset and pair them. Since yours is for an Ipod I'm assuming you have the older white/grey model and not the freepulse headphones. The procedure is not the same. From memory the procedure it to reset both (look for the small hole to insert a paperclip). Once both are reset begin with the transmitter. Hold the power button down for about 30 seconds until the light flashes red and blue. When it does do the same for the button of the headphone until it flashes red and blue. When both are flashing red and blue they should pair together and the lights should turn solid blue..
Oct 15, 2008 | Logitech FreePulse Wireless Consumer...
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Feb 27, 2008 | Logitech (980361-0403) Headphones
Setup Bluetooth Wireless headphones
Each brand has it's own peculiarities and you did not specify the brand. I would suggest turning off the headphones, resetting the transmitter (turn off and on again for separate devices) and then pressing and holding the 'on' switch for 15 seconds or so. You may see (in some models) a light start to blink blue then red and back. This should indicate that the receiver (headphone) is trying to find a transmitter to pair with. Hope this helps.
Nov 27, 2007 | Logitech Bluetooth Wireless Headphones
Hauppauge  Wireless Headphones Logo
1,363 people viewed this question
Top Hauppauge Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Hauppauge Audio Player and Recorder Expert? Answer questions, earn points and help others
