Question about Linksys WRT300N Wireless Router
WRT300N: does not boot, all leds are lit - Linksys WRT300N Wireless Router
    Sniper:
  • 52 Answers
Solution 1.
How can I reset the Linksys WRT300N to factory defaults?
Hold the Reset button on the Linksys WRT300N for about 30 seconds.
What is the IP Address, Username and Password to log in to the WRT300N?
IP Address: 192.168.1.1
Username: none
Password: admin
You should also know the configuration of your ISP provider after reset. You'll need to re configure your connection from modem to router.
Solution 2
How do I upgrade the Firmware on the Linksys WRT300N?
# 192.168.1.1 -> Administration tab -> Firmware Upgrade sub-tab. Click "Browse" and browse to the firmware upgrade file on your computer. Click "Start to Upgrade". Do not reset or power cycle unit while it is upgrading.
Username: none
Password: admin
Posted on Apr 10, 2011
2 Suggested Answers
  • 177 Answers
SOURCE: my wrt300n power led is blinking and the rest of
Hi Friend
Please follow the steps to reset the router in a different way
1) Press the reset button for 10 secs and after that unplug the power cable from the router and wait for 10 secs
2) Plug the power cable back and press the reset button again for 10 secs and after that unplug the power cable from the router and wait for 10 secs
3) Plug the power cable back and press the power button for 10 secs again and unplug the power cable from the router for 10 secs
After trying these steps if you see the power light still blinking then you need to replace the router. Please call the customer care of linksys 1800 546 5797,they will let you know how to replace the router
warm regards
Chiranjeet Mitra
Posted on Oct 09, 2009
My unit indicates a system error due to amber LED was lit whenever I press the power button. I tried to press the remind button in the operator panel but no LED will lit to indicate what maybe the problem....
Interesting, sound like a failure of the button because most system either work with a greeg lit up led or fail with an amber or orange lit or flashing.
In this instance the amber could mean something has gone bad but the fact you can hold the button and have it boot up is strange.
Does the led turn green after holding the button for a while to let the machine boot?
regards,
mike
Oct 19, 2012 | IBM System x3500 (7977F2U) Server
Am using Linksys WRT300N v1.1 wireless router but all LEd are glowing except power led. and i am unable to connect through wired ethernet ports and also wireless is not working.
Try to reset the configuration of your router from the reset button and try that you getting the console with its default username and password.
Jun 18, 2011 | Linksys WRT300N Wireless Router
Lost power on my WRT300N router. Power came back and now the power light is weak and all 4 port lights are on.
I had the exact same indications after a utility power spike.
Quite by accident, I discovered that the power supply to the WRT300N when fully seated into the router causes the lights (and the router!) to malfunction in this manner.
I pulled the power supply connection out gradually and the power light began to flash. Pulling the power supply even farther out eventually caused the power light to shine solid.
I don't know if this is a random manufacturer problem with just my WRT300N (V1.1) or if others may have a similar defect, but it's certainly worth a try!
Good Luck!
May 18, 2010 | Linksys WRT300N Wireless Router
Ethernet lights 1-4 are lit, wireless light out
wireless light will be ON only if you have connected any wireless devices to your network... security light will be ON only if you enabled password to connect to your wireless network.... if you have changed any settings in the router recently, then delete the saved list of networks in the computer.... then search for wireless networks in range and connect to your network....
Apr 19, 2010 | Linksys WRT300N Wireless Router
The power light is very dim and all 4 ethernet port lights are on and internet light is on too, but we are not getting any connection
If hard resetting it does not let the power light lit fully , then it already a hardware problem inside your router , no getting enough power. Bu dont worry it may just be too that the Power light led is just not lighting up properly.
Apr 06, 2010 | Linksys WRT300N Wireless Router
I just rewired all my network connections, my wrt300n wireless indicator is not lit. The network is set up on a linksys broadband router on a cable modem and wrt300n was functioning properly when it was...
Try first resetting the router by pressing the reset button of the router fro 10 seconds while power is ON and then after that reconfigure the router.....
Dec 07, 2009 | Linksys WRT300N Wireless Router
HP Pavilion dv6225us won't boot (power not the issue)
Check http://www.fixya.com/support/t3440299-presario_f500_laptop_problem
Nov 16, 2009 | HP Pavilion dv6225us Entertainment -...
My wrt300n power led is blinking and the rest of
Hi Friend
warm regards
Chiranjeet Mitra
Oct 06, 2009 | Linksys WRT300N Wireless Router
Follow up questions
Normal sequence is the power led should blink 5 times then shutoff when power is pressed. If the led stays lit the DM is suspect. You will need to have the DM trouble shooted to determine whats preventing normal boot sequence from completeing. If you need further assistance. please let me know.
Your chassis is the ATC322
Jul 07, 2008 | RCA HD50LPW164 50" Rear Projection HDTV
Linksys WRT300N Wireless Router Logo
895 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
