Question about Car Audio & Video
My radio works but my door speakers come in and out and now only the tweeters will play music
  • 24 Answers
Sounds like the speakers are blown or the wires that go through the gap between the door and the shut are broken. you will have to replace the wires. keep a good check on the wire colours and then copy down the replacement colour give yourself self plenty of slake so you can easily make the new connections. if you cannot solder then use those blue snap connectors. you will see why you need plenty of slack.
Posted on Apr 10, 2011
Signal working no noise 07 pontic G5
Probably the driver door speaker is going out (yes the "click" noise is "played" through the speaker). Seems common on these cars and was my problem. Turn all your music to that one speaker using the radio controls and see if it plays music. All the chimes and blinker noises come out of that speaker.
Oct 21, 2016 | Cars & Trucks
2007 camry radio
hey, that sounds like wiring for sure, if your cd player is working fine and its just your speakers? then yes that would be a wiring problem, theres a bad wire somewhere in the system. either find out yourself where the bad wire is or bring it to someone who know how to repair those types of problems. good luck!
Feb 15, 2014 | Cars & Trucks
Boston Acoustics VR 950 speaker (tweeters) have static when playing music with a lot of piano. Clean as a whistle (no problems) with acoustic (guitar), though. Are the tweeters blown, or is there...
Don't blame the speakers just yet. Check your PC's audio controls to make sure it's not modifying anything and that your speakers are defined as speakers, not headphones.
Try running UNripped music to them. Solo piano is a difficult signal to reproduce.
Nice amp, huh? I have one plus some Cubes.
Feb 20, 2011 | Boston Acoustics VR950 Main / Stereo...
The radio in my 2002 freelander only plays the high speakers it isnt playing the 6" round door speakers
Either the wire is severed to the door speakers, or the radio has bad amps inside.
Jul 01, 2010 | 2002 Land Rover Freelander
When i connect the wires from my receiver to the top "red/white" connectors, the tweeter works fine, but the two midranges don't have any sound. When i connect the wires to the bottom connectors the...
are the two connectors on the speaker itself i belive you need two diiferent cables coming from the radio ect
what yu can do to make it work
connect the bottom connectos to the top connectors keeping the polatrity the same though
Jan 10, 2010 | Energry Speakers Energy Speakers Audissey...
2001 eclipse spyder gt radio works but only tweeters come on.If you turn it off and on quickly the door speakers will come on but only the left plays properly.The back speakers wont play at all.All this...
The main amp box is under the passenger seat so it might have gotten wet.
try drying amp.
disconnect battery for about an hour
(before you disconnect the battery make sure you have the lock code to your stereo some need.
re connect battery and stereo sould play fine
if not then you may have a bad amp or speakers
Jun 21, 2009 | 2001 Ford Focus
Front speakers
either the wires in the boot where door folds open has broken wires in it or the most likely case you have 2 blown wolfers and 1 blown tweeter. common for cars with the monsoon stereo system, they made the radio better than the speakers.
Mar 09, 2009 | 2001 Volkswagen Beetle
Uv8 some seakers dont work in dvd/cd mode
You have the wrong wire hooked up to turn on your amplifire. You used the blue wire but need to use the Blue/White wire!! That is an amp turn on wire Thje blue one is for a power antenna and goes dead when you put in a disc. The tweeters play because they are hooked direct to your Jensen. You'll be jamming in no time.
Larry T
Winona Lae
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html IN
Jan 26, 2009 | Jensen VM9510 Car DVD Player
My Kenwood amplifier is having problems, whenever i turn it on. all seems well until i play some music through it, after 30seconds to a minute the music will cut off and a distinct click is sometimes...
Your amp is going into protection. The click you hear is a relay meant to protect your speakers and stereo. Check your speakers with an ohm meter for the the proper ohms ( listed on the speaker ) and physically try to push each woofer and midrange cone in gently to make sure it moves and is not stuck or frozen in place. A speaker may read correctly on an ohm meter if the woofer is ok but if the tweeter or midrange is not working it will cause the amp to go into protection mode. When you play music stick your ear up to each tweeter\midrange\woofer to ensure they are working.
Your stereo could also be the culprit although usually if it plays music it is ok as long as you are not hearing loud pops. Loud pops are voltage spikes that indicate that a transistor\IC is breaking down and will eventually short. Good luck!
barneyluc
Oct 01, 2008 | Audio Players & Recorders
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
