Question about Toshiba 42HP95 Television
We just moved our Toshiba 42HP95 TV w/ Motorola DVR to another room and apparently do not have it properly connected. Have sound and picture, but color is not good. Need a diagram for proper wire connections.
  • ddlane21 Apr 10, 2011
    No, our hook up is more complex than that. We have a black S Video cable connected to the TV. We have color stream HD-1 ports and color stream HD-2 ports. Green, blue, and red.
  • ddlane21 Apr 11, 2011
    We can't find in the Toshiba manual the diagram for the hook-up of a DVR.
  • 8,197 Answers
Look at the manual on the link below starting on page 13 will tell you how to hook up. for s-video loot at page 17.
http://www.tacp.toshiba.com/tacpassets-images/models/50hp95/docs/50hp95_om_e.pdf
Posted on Apr 10, 2011
  • Jyackle5
    Jyackle5 Apr 11, 2011
    The dvr is the same as hooking up a dvd player
  • Toshiba Master
  • 6,993 Answers
There is no diagram available for this, but I can explain to you how to do the connection properly.
Get a RCA cord (Yellow, red and white wire). The yellow stands for video, while the red and white stands for Audio left (L) and right (R). Below is a picture of what the cord looks like;
We just moved our Toshiba 42HP95 TV w/ Motorola - walesarumi_52.jpg
Now, connect the yellow part of the cord to "Video IN" at the back of TV, then connect the red and white to "Audio IN" appropriately.
Connect the other part of the yellow cord to "Video Out" on the DVR, and connect the red and white cord to "Audio OUT".
Turn on the TV and DVR, select "AV" on the TV and the display of the DVR should show on the screen of the TV.
If color is not still good after these connection, try to use another cord, as a bad video cord can affect the color display.
I hope you understand the above.
Good luck.
I'm trying to connect my dvd recorder to my Motorola dtc6400 DVR. I can record picture but not sound because there is only one set of RCA audio outputs on the DVR and they go to the HDTV. There is also...
See if your TV has an audio out socket at the back. If so connect this aodio out to the DVR to record the sound . If not buy a pair of ( one for Left channel and the other for Right channel ) one is to two Y connector and plug the jack to the DVR and connect the split ends to the TV and Motorola DVR. That way you will have sound going to TV & DVR
Mar 31, 2011 | Arris DCT6200 DTV Receiver
Tip
Toshiba 42HP95 Front Panel Lock Reset
Toshiba 42HP95 Plasma TV Front Panel Lock Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Front Panel Lock?
Have you forgotten your Front Panel Lock PIN, passcode or password?
If you forget your Front Panel Lock passcode, you can unlock the front panel without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The Front Panel Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
Toshiba 42HP95 Input Lock Reset
Toshiba 42HP95 Plasma TV Input Lock Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Input Lock?
Have you forgotten your Input Lock PIN, passcode or password?
If you forget your Input Lock passcode, you can view the locked input without entering your password:
  • The Input Lock passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
42HP95 TV screen flickers off/on
Can be either one of three things 1) logic board, power supply, or unfortunately most likely is your panel. But if I were you I'd get a hold of Toshiba warranty center to diagnose because then they could check voltages with toshiba tech support.
Aug 23, 2009 | Toshiba 42HP95 Television
Toshiba 42HP95 Plasma tv
http://www.fixya.com/support/t101749-tv_turned_itself_off_turn_back
Worked for me, was ez, and I am a huge skeptic and not very "TV technical."
Dec 23, 2008 | Toshiba 42HP95 Television
Tip
Toshiba 42HP95 Channel Block Reset
Toshiba 42HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
Tip
Toshiba 42HP95 VChip Reset
Toshiba 42HP95 Plasma TV VChip Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Parental V-Chip parental lock?
Have you forgotten your VChip PIN, passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password:
  • The VChip passcode will be reset and you can enter a new passcode if desired.
I hope that helps.
Firmware update
I apologize I already forgot what your main concern was. Can you please resend my solution that I gave to you? Sorry for the inconvenience
Aug 23, 2008 | Toshiba 42HP95 Television
Tip
Toshiba 42HP95 Manual Download
Would you like to review the features of the Toshiba 42HP95 Plasma TV ?
Have you lost your Toshiba 42HP95 Plasma TV Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 42HP95 Plasma TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 42HP95 Plasma TV documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | Televison & Video
Tip
I hope that helps.
Televison & Video Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
