Question about Microwave Ovens
Our KitchenAid Oven shows power to the master control board, but the oven does not heat up. Warming drawer underneath working fine.
  • dahlin_jeff Apr 10, 2011
    It is a KDRRS807( think) gas combo (convection) oven. Yes, it did start after my wife tried to do a clean then aborted it. Also the oven light will not turn off.
    Thanks
  • dahlin_jeff Apr 11, 2011
    Yes, great, very detailed. Thanks much.
  • Microwave Ovens Master
  • 2,605 Answers
Hello, Welcome to FixYa. Can you could provide the model number that will help determine if it's a combo, gas, electric and avoid any generalizing with you machine. Another question I have that may go a long way in solving this problem is this, did this problem seem to start following a self clean of the oven ? You also mentioned the clock/timer (master control) has power going to it, but what about voltage coming out when you select either bake or broil ? I'll wait for you reply to see whats been done or suggested and checked to this point. Regards, Macmarkus :)
Posted on Apr 10, 2011
  • Mark MacDonald
    Mark MacDonald Apr 10, 2011
    Hello again,
    Thank you for the reply and providing the model number. I've found this model I think to be yours, KDRS807SS. Since this followed a self clean cycle I'd suggest you check the thermal fuse at the back.
    This will require you to slide the oven out and remove the back panel. Once the panel is off you should see a stat/fuse which will resemble this image...
    you can ohm out that part and you should have continuity with one or both wires removed ( closed contacts ) or you can remove the wires on the stat and join them together ( known as "jumper" connecting ) to try the oven function.
    If the fuse is "open" or no good, ( no continuity -infinite ) you can replace it with part # 9759242 available at "searspartsdirect.com" or "repairclinic.com" to name a couple.
    **Please use caution when doing these test's and unplug the range entirely when servicing, only plugging it is when you're all clear and no wires are touching anything...safety first**
    If this occurred before the clean cycle actually became operational or was functioning, it could be a door latch switch error, but that will typically produce an error code of some kind. We'll cross that bridge if or when necessary.
    Let me know what you find and I'll continue to assist you in any manner I can. Good luck.
    Regards,
    Macmarkus :)
Where is the warming drawer sensor in my kitchenaid oven?
If you wish to get some details about microwave oven repair and error codes then check the following link
http://electro-medical.blogspot.com/
Jul 27, 2016 | KitchenAid Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How to reset dacor mwo30s warming drawer
If for some reason you don't still have your owner's manual, you can find it here.
Nov 30, 2013 | Dacor MWO30S Millennia Series Warming...
Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
Power is fine but it stop heating as disired ? display , time function all working but no heat ?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ]
[][]0-=-=
Apr 10, 2011 | KitchenAid KCMS145J Microwave Oven
I'm getting error 40 on wolf warming drawer, with beeping...buttons don't work...rest breaker few times...doesnt work...
Not knowing the make and model number of the microwave doesn't give me much information to work with. Try to google the make and model number, along with the phrase "unit beeps and error 40 on warming drawer", and see if something comes up. There are sites with error codes, which might help.
Also, refer to any literature that came with the unit, to see if they have the error codes listed, and what they refer to.
You can often go to the manufacturer's site and find useful information about various problems, and what needs to be done.
Wish I could be more specific, but will try to check back to see if you can include the make and model number, and then we will go from there.
Oct 31, 2010 | Microwave Ovens
Everything seems to work fine, timer, power selection etc., but does not heat food???
heatman101
Oct 25, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
Code F6, E0, "Communication Error"
Hi. this code represents a key pad or control board malfunction. you will have to make sure the key pad or control panel connectors are connected tightly and securely. If the wires and connectors are secure, the actual control board may be faulty and you will need to replace it at this point.
Mar 01, 2009 | KitchenAid Microwave Convection Oven
Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
Microwave Ovens Logo
46 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
