Question about Kenmore Washing Machines
Our washer just stopped. The drum is full of water and clothes. Help! Thank you! Ann
    Brigadier General:
  • 6,277 Answers
Kenmore (Whirlpool)- please try this-
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this solution accordingly.
Thanks and good luck!
John C
Posted on Apr 10, 2011
Knocking from the drum
You really should realize that when clothes get wet, they get heavy. If those heavy clothes are sticking to one place on the drum it will be out of balance and knock at the sides of the washer. If this happens, simply open the door (not when the washer is full of water, of course) and the drum will stop spinning. Just spread the wet stuff around the drum surface and close the door...voila!
Jan 12, 2013 | Electrolux Washing Machines
I have an LG WM0532HW front load washer. The washer drum has stopped in the middle of a cycle and it show the UE symbol indicating there is an unbalanced load. At this point my clothes are in a drum full...
I would replace the sensor on the stater. I have replaced that a couple times for this problem and it has solved the problem. If you remove the back then take off the main drive you will see the stater and you will see a small sensor on it. Change it and you will probably solve this problem. The part is about $25.00
Mike Anderson
Anderson Appliance
Feb 18, 2010 | LG WM-2277HW Front Load Washer
Water didn't shut off
There is a part called a air-dome that is connected to the lower section of your outer drum. The part where you put your clothes in is called the inner drum.The air-dome has a small tube connected to it which travels up the drum to a level sensor in the control panel that turns off the water when the washer is full to the point water level is set.This is usually on top loaders.
Feb 06, 2010 | Kenmore 23822 Top Load Washer
Not enough water in the drum during the washing cycle
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
Aug 30, 2009 | Samsung WF203ANW Front Load Washer
Kenmore washer Heavy Duty (70 Series) 1985-1989
behind the knob that you use to set the water level is the level control it should have a n adjustting screw to set the water level(you can set it where you want)
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Water does not stop running when the washer is full.
turn the water on for a minute,then turn it off,if it stops it's not the water valve,if it does not stop then it's the water level hose or switch that's bad-mike
Jun 04, 2009 | Kenmore 22622 Top Load Washer
Zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
Oct 20, 2008 | Zanussi FJD1666W Front Load Washer
Machine dosent seem to drain model #lat8840b maytag
my machine had a pair of kids underware stopping the water from entering the draij pump,you may have clothes inbetween the drum and outer wall stopping the normal rotation
Aug 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
19 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
