Question about Kenmore Front Load Washer
I am looking for a kenmore machine part but i do,not no the part name it is attach to drum pulley
    Brigadier General:
  • 6,277 Answers
Sorry but this forum does not supply parts direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number and you should be able to identify the part you require.
Good luck,
John C
(Please score this solution accordingly)
Posted on Apr 10, 2011
What makes the drum spin?
There is a motor on the bottom. You can see it if you lay the machine down. The motor has a belt that attaches to a transmission. The belt could be loose or off. The transmission could be bad, or the spindle into the drum is stripped.
Jun 12, 2014 | Kenmore 22422 Top Load Washer
Dryer was not pulling air out of machine,
This belt and pulley are what spins the fan.Which explains why it is not pumping air.What you will need to do is take the whole front off flip up the top and remove the drum.at that point you will see a fan housing on the bottom directly under where the drum was.you need to screw that pulley you found back on to the fan shaft and run the belt that you found from the fan pulley to the front of the drive motor.Then reinstall the drum and drum belt and it's good as new.a good thing to do would be to use some loctite when screwing the fan pulley back on so it will not fall apart again.another little tip is that pulley has a reverse thread so you will need to screw it on counter clockwise.Also on most models with this type of fan you need to get to the drum belt from the back of the dryer to remove and install the drum belt
Apr 16, 2014 | Kenmore Elite Oasis ST 6807 Dryer
I have a Kenmore Gas Dryer (model 11087471810) that threw its belt. I have the replacement belt and know how to replace that. When I opened the bottom of the dryer, I noticed the Idler pulley sitting at...
The idler pulley/tensioner fastens into two slots in the base of the dryer to the left of the motor . The belt goes around the drum then through the idler to the motor pulley ,you have to make a loop with the excess belt and feed it through the idler pulley, i normally pull the plastic pulley towards the right side of the dryer to give enough belt to go around the motor pulley then let the plastic pulley rest on the backside of the belt. do not turn the drum too much as you may pull the belt back off .
May 13, 2011 | Kenmore Dryers
I may have overloaded my Frigidaire Pin #134465400 0410 front loading washing machine. On the last load it did not complete the spin cycle and there is water laying in the bottom of the drum. When I try...
Pull the unit out from the wall and unplug it. Remove the back panel and check the counter weight (looks like a cement quarter round cement block), spider pulley and belt. The counter weight is attached to the top of the drum and can loosen and fall to the bottom damaging the spider pulley. If the counter weight is firmly attached to the top of the washer drum and the belt is attached to the spider pulley and motor, remove the top cover and lower front panel.
With any luck the counter weight knocked the belt off. If you are unlucky the counter weight broke the spider pulley.
Here is a link for parts.
Jan 06, 2011 | Washing Machines
Machine was draining and spinning and became off balanced.it stopped working.when unplugged and then plugged back in, it will start to drain and try to spin but it makes a noise instead.help!
Pull the unit out from the wall and unplug it. Remove the back panel and check the counter weight (looks like a cement quarter round cement block), spider pulley and belt. The counter weight is attached to the top of the drum and can loosen and fall to the bottom damaging the spider pulley. If the counter weight is firmly attached to the top of the washer drum and the belt is attached to the spider pulley and motor, remove the top cover and lower front panel. Check to make sure the drum springs and shocks are attached to the drum. I hope you only need to bolt the counter weight back on and no other damage to the machine is found, you should get bake to business in about 40 minutes.
Jan 06, 2011 | Frigidaire ATF6000ES Front Load Washer
My kenmore 70 series washing machine wont spin. i took it apart and could see the belt off, but i couldnt figure out how to put it back on
just place the belt over the motor pulley
then get it started over the drum pulley it will stretch on by rotating the drum pulley
Mar 09, 2010 | Washing Machines
How do i replace the belt on a kenmore model/stock # 86950100 69501 i have the machine open and the old belt out but how does the new one go in?
hard to describe, but place belt on drum pulley, through safety switch , then motor pulley, looks like 2 loops, kind of like a car
Jul 24, 2009 | Kenmore 74742 Gas Dryer
Pulley fell off while reassembling kenmore dryer 80 series
the pulley goes right beside the motor pulley,the belt goes under the big pulley and onto the motor pulley-mike
Mar 03, 2009 | Kenmore 659 Electric Dryer
I have a kenmore 90 series dryer, the drum belt broke, bought a new one, but cant figure out how to get it on, too much slack in the belt, not sure where it goes on
REMEMBER BELT GOES AROUND IDLER PULLEY AND ATTACHES TO MOTOR SHAFT ,PULL BELT W/ HANDRUN BETWEEN ROLLER, AND PULL BACK AND ATTACH ON MOTOR PULLEY AND THAT ITS
Jan 02, 2009 | Kenmore 64952 Electric Dryer
Sears Kenmore Dryer. Model/stock no. 76691100 belt is broken, and a pulley attached to a spring steel L with a 90 deg bend is unattached from the machine. Joe
RE ATTACH IDLER PULLEY TO GROUNG ONLY 1 WAY TO FIT RUN BELT THROUGHT PULLEY IDLER AND BEND BACK TOWARDS MOTOR TILL IT ATTACHES TO MOTOR THAT ITS
Nov 29, 2008 | Kenmore Dryers
Kenmore Front Load Washer Logo
16 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
