Question about Mercury Computers & Internet
My pc has the following issues: 1. keep on logging of unexpectedly ive tried to clean up cpu but nothing has changed 2. if it does log on and i try to install any software including genuine mercury drivers or OS it switches off completely plus it indicate there is no Digital Signals. 3. No sound for my Mercury Tv Card and keeps Please advice accordingly.
  • Mercury Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 10, 2011
Asus u52 shut down unexpectedly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 17, 2012 | ASUS U52F-BBL9 Laptop
Unexpected shutdowns
G3 is very very old server, most are retired now. 99%\
12 years old servers...
it is so old it has floppy drive ! yes that old. and PCI slots no express slots old. (relic it is)
Does it have the 2 CPU option:?
did you read the server logs? it has logs!
it records all shut down causes on my bigger/newer G7
It will shut down by self for a 3 reasons.
it overheats, or the PSU is bad. or the PSU was overloaded.
mine even has power log, that proves that and 2 PSU's that auto backup power, if one is bad. of the 2. (you have only 1 PSU on this old server ,unlike my G7)
is this your only 330? no spares ? as most servers installations have (all do really for clustering)
clean out the dust in the CPU heat sinks and make sure all fans work first? that be first. so it cant overheat
did you first change out the COIN cell on the MOBO,
bottom of motherboard see that Cell it be NO GOOD at 12years
old ever. and makes the BIOS go Nuts and RTC clock same.
no logs, ever heard of iLo (lights out)
its built in micro web page. and its own IP address
you connect to it and read the shut down logs.
data sheet it is at HP, as is full help at HP real. HPE its called
http://h20628.www2.hp.com/km-ext/content-webapp/document?docId=emr_na-c00353085
on mine I can see 6 fan speeds
and 21 temperature readings at any time.
under system information page in iL0
and then the iLo event log. mine says admin turned it off last night.(a video server it is , here)
but read the logs first.
this be the first place to look on any HP Prolaint ever made.
Nov 24, 2017 | HP Compaq ProLiant ML330 G3 Server
Hello, I have problems with color printing with the DCP130C. First it printed no colors at all (even in the test print). Replaced cartridges - no change. After unplugging the mains cable for several...
If it is running on windows xp then you can log on into safe mode and remove the password from the admin account. Following are the steps listed to do so:
1. Turn on the computer and keep tapping F8 and it will show some options. 2. Select safe mode. 3. Log on using Admin. 4. Go to control panel by clicking start. 5. Then go to user accounts and remove the password from the account you are trying to log in with.
Jun 03, 2011 | Brother DCP 130C All-In-One InkJet Printer
Laptop cuts off during operation and when I attempt to log back on it cuts off again.
Hi
Thank you for your query
Please do the following steps to narrow the problem down
1) Switch on the laptop
2) Once switched there may be a meeage that says press del or F12 to enter setup, if not try the del key or F12
3) This will being you into the bios screen, once in there let the laptop run, if the laptop keeps cutting out in tis mode, you will have a overheating issue
If it is overheating then try cleaning out the vent where the hot air comes out from, if that doesnt looked block then it looks like the Heat sink (the fan that cools the CPU down) is faulty and will need to replaced.
If however it does not cut out then you have a sftware issue and i would recommned a clean install
Hope this helps
If this has been useful please leave positive feedback/vote
Feb 12, 2010 | Northgate Computers & Internet
Im using my frieds computer and want to lod in to
Do the following:
1. Log out of your friends FaceBook account.
2. Log in to your FaceBook account.
When you are finished using FaceBook then:
1. Log out of your FaceBook account.
2. Get your friend to Log in to their FaceBook account.
Your log in will be your Email Address (or User Name you created) and your Password.
NOTE: if you have forgotten your passwords or email accounts, OR your friend has forgotten theirs.
THEN (your friend will need to check their profile information) before they log off. In the Profile, they will find what email address is listed as being the current one. (You can supply more than 1.)
I hope this information is useful to you. Please rate. Regards
Feb 12, 2010 | Facebook Social Network
2log(base4)x + log(base4)3=log(base4)x-log(base4)2
It is easier to use the rules for logarithms to clean this equation before trying to solve it. And the calculator is no help here.
Let me represent the logs as follows log b in base a = log(a,b). The first argument is the base.
2*log(4,x) - log(4,3)= log(4,x)- log(4,2)
Here you have two similar terms 2*log(4,x) on the left and log(4,x) on the right. Gather them both on the same side, say the left. You have
2*log(4,x) -log(4,x) +log(4,3) = log(4,x)-log(4,x) -log(4,2)
which is equivalent to log(4,x) +log(4,3) = -log(4,2)
Gather the constant terms on the right, and use log(a) +log(b)=log(a*b)
log(4,x) = -log(4,2) -log(4,3) = - { log(4,2)+log(4,3)} = -log(4,2*3)
You get log(4,x)= -log(4,6).
Take the constant term to the left, while changing its sign in the process. On the right remains 0, which is also the log of 1 in any base So log(4,x)+log(4,6) =0 =log(4,1)
Use the rule log(a) +log(b) = log(a*b) valid in any base, to obtain
log(4,6x)=log(4,1) which is equivalent to 6x=1. The solution is x=1/6
There are a few other shortcuts to get the solution but I preferred to take a pedestrian, step by step, approach.
Hope it helps.
Nov 25, 2009 | Casio FX-300MS Calculator
Dell Optiplex GX270 - Freezes up!
You may have either a memory chip gone bad or the CPU overheating. Withot seeing it and testing it's hard to tell you which. But one thing you can try is if you have 2 RAM installed, try to remove 1 and see if the problem continues. If so, change them and put the one you removed back and remove the other. if it continues then you may have an overheating problem.
Otherwise, you can try a SCANDISK and DEFRAG to clean up the hard drive and data.
Jun 19, 2009 | Dell OptiPlex GX270 PC Desktop
Windows Live messenger Error : 80048820
If you are receiving error 80048820 when trying to sign into Windows Live Messenger you should also get an extended error code. If this extended error code is 80048412 the problem often occurs because the time and date settings on the computer are incorrect. The error will appear like below:
You cannot sign in to Messenger. Additionally, you may receive the following error message:
We were unable to sign you in to the Messenger at this time. Please try again later.
To let us try and troubleshoot the problem, click the Troubleshoot button.
Error code: 80048820
Extended error code: 80048412
The following steps may help resolve your issue:
To troubleshoot the problem on a Microsoft Windows XP-based computer:
1. Click Start, click Run, type control timedate.cpl, and then click OK.
2. In the Date and Time Properties dialog box, confirm that the date and time settings on the computer are correct, and then click OK.
To troubleshoot the problem on a Windows Vista-based computer:
1. Click Start, type control timedate.cpl in the Start Search box, and then press ENTER.
May 29, 2009 | Microsoft Windows Live Messanger
Yahoo Mail closes unexpectedly
this is an issue with firefox 3 try to use firefox 2 when logging in yahoo mail, other yahoo services are ok.
Nov 07, 2008 | Yahoo Mail
Mac OS X 10.5 iDisk error -35
Give your mac a few moments to wake up before you try to connect iDisk.
If this didn't solve your problem
1. From the Apple menu, choose Log Out.
2. Log back in.
3. Try to connect to your iDisk.
4. If the issue persists, restart your computer.
You should now be able to connect to your iDisk. However, if the issue persists, follow
these additional steps:
1. Open System Preferences.
2. Click MobileMe.
3. Click Sign Out. Note: This will unregister your computer from syncing with MobileMe, and disable iDisk Syncing if it is enabled.
4. Retype your MobileMe account name and password.
5. Connect to your iDisk.
Aug 27, 2008 | Apple Mac OS X 10.4
Computers & Internet Logo
32 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
