Question about Boating
WHERE IS THE IDLE SCREW ON A1989 48 JOHNSON SPL OUTBOARD MOTOR I AM A WOMAN WITHOUT A BOOK OR ANYONE TO SHOW ME
4 Suggested Answers
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
  • 53 Answers
SOURCE: need exploded view of 14 hp johnson outboard motor fuel pump
Need year mode?. But you can go to this website and get all you need. Don't worry I'm not a salesman. I just use this site for my own business. www.crowleymarine.com. click on parts catalog then follow directions.
Posted on Nov 04, 2009
SOURCE: Johnson Outboard Motor 175HP
Unplug the heat sensor and try it.
Posted on Oct 22, 2011
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views ยท 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
How to set timing on 75 hp johnson outboard
creates an impulse to the cid as a magnet passes by . not much adjustment to timing small screw toward the front that moves the stator perhaps a 1/4 inch .
Aug 17, 2015 | Johnson Evinrude Timer Base, 6 Cyl 75-85...
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Idle mixture screw on 60 hp Johnson outboard motor
Looking At Starboard Side Of Engine The Screw That Has A Spring Behind The Head On The Upper Part Of Each Carb Is The Idle Air Srew
Pre Set Is From Lightly Seated In turn out 2.75 turns then adjust whilst running to obtain correct idle ,what you do to one do to all
Mar 20, 2013 | Boating
1994 90HP johnson outboard
Hi, your problem is simple you either have a head gasket gone or a exhaust plate/gasket gone. Either will let water into a cylinder which is why it ran ok without water. You should also check the water pump in the leg as you have now run it without water. Regards Phil.
Jun 20, 2012 | Boating
150 johnson wont idle wot great
start engine while in water with slightly high tickover , remove throttle cable and find throttle stop screw and adjust till 800rpm holding the throttle arm against the stop and see if you can select forward gear without stalling ! depends what size pitch prop your using as you mite need tickover slightly higher but as long as it selects without stalling then ok ! as long as it doesnt jump forward , in gear should be 800rpm + or - 100 max ! if still stalling then possible requires fuel system cleaning !
Jun 03, 2012 | Light Outboard Motor Boat Bass Fishing...
93" 115 H V4 Johnson outboard motor will start and idle fine
your carburetors might be dirty blocking flow to the high speed jets causing it to bog down
Jun 29, 2010 | RTO Outboard Motor Bass Fishing Boat Rod...
1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Jun 30, 2009 | Sport & Outdoor - Others
Where can I download a free manual for Evinrude 4HP motor.
Adampeake how do you download free from the web link
they wanted $19.99USD
Apr 22, 2009 | Boating
Boating Logo
229 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
