Question about Digital Lifestyle FA1B32Z 32 in. LCD Television
Needs software update how do i update this tv
  • 52 Answers
Does the Tv have a USB port? If so you should be able to find the firmware on the makers website, assuming the company made a firmware update for that model. If so then download it to a flash drive, zip drive and plug it in to the TV's usb port for the update! Best of Luck!
Posted on Apr 10, 2011
Problem with getting tv to fire up, takes about 20 minutes of pushing power button to start.
Recent Fire TV software updates causing blank screen issues
www.aftvnews.com/recent-fire-tv-software-updates-causing-blank-screen...
Aug 17, 2015 - Ever since Fire TV software update 51.1.6.1 and Fire TV Stick software update ... update, Fire TV devices now enable HDCP immediatly at boot up. ..... I'm still getting this blank screen issue on one of my TV's but not the others.
How to Get Your New Fire TV Device Up and Running - Wired
www.wired.com/2014/12/amazon-fire-tv-setup/
WiredDec 25, 2014 - Here's how to take that new Fire TV device from zero to streaming in five easy steps. ... How to Get Your New Fire TV Device Up and Running .... I'm not sure why this is not an issue for Chrome Stick, et. al but I invite you to ...
Report Amazon Fire TV / TV Stick Playback issues here - Plex Forums
forums.plex.tv > Google TV & Amazon Fire TV
Jan 10, 2015 - Indicate if your problem is for the Fire TV/ TV Stick or both, if the FireTV, .... when playing files back, i'm getting the same freezing issues regardless of ..... to have to refresh content about 25% of the time when I first fire up Plex.
Jan 10, 2016 | Televison & Video
Why did it freeze during software update?
Here is some help on a Sharp Aquos. You pull the plug and update manually.
Sharp Aquos Firmware Update Issue and Resolution I recently had problems with my Sharp Aquos LC-60LE632U and firmware update 311U1204061. When I attempted to run the Netflix app, I was told that I couldn't proceed unless I updated the firmware. After 2 attempts to update the firmware via the network, I turned to Google and found that this was a common problem. In order to resolve the issue, you'll need to update the firmware manually, via a USB thumb drive. See the following instructions:
  1. Go to the Sharp USA product download site
  2. After you choose your TV model, download the firmware file
  3. View the rest of the instructions found here
Info found here
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/1436990-sharp-aquos-frozen-when-updating-software.html
Oct 03, 2015 | Televison & Video
After initial set up and download, TV is displaying a hand on power plug picture with a red circle and line through it and a refresh symbol in light blue next to it, what does this mean?
Hi! and Welcome to Fixya!
What you have on the tv screen is a warning sign that your tv is currently updating its software. A hand holding a power plug with red circle on it says do not unplug the tv while its running the software update. The usual time for the update to finish is 60 minutes. It may took more than 60 minutes if you have a slow internet speed. This is normal especially if you are running the software update for the first time during the initial setup. The next time tv performs software updates it will take shorter time.
However, if the updates took more than two hours, the tv may be frozen. You can unplug and plug it back in and start from the initial setup again.
On some rare occasion, the tv may not proceed with the initial setup. You may have to turn off your modem to complete the initial setup. when initial setup is done, connect your tv to network and run software update again.
Let me know if you still have other questions.
Sep 07, 2015 | Sony BRAVIA KDL-55W802A 55" 3D 1080p...
My Sony Bravia TV will not turn on. the power light flashes red 7 times then stops for 4 seconds then repeats
System Error:
  • If a Red LED is blinking and the TV is not working properly it means that the TV has detected an issue or problem. Most Red LED blink conditions require service. The meaning of the blink codes differs between TV models, but the following steps may resolve user serviceable errors related to heat, temporary conditions, or software updates:
    NOTE: 8 Times Blink - For certain models, a special reset procedure is needed if the Red LED on the front of the TV is blinking 8 times and then repeats. This is a model-specific issue that may be resolved by following these steps (please check the answer to be sure your model is included).
    For other TV models or other Red LED blink codes:
    1. Turn the TV off and back on. If the TV will not respond to the remote or the power button, or if that does not fix the issue, unplug the TV. For a Projection TV or Projector , leave it off for 3 minutes. For other TVs leave it off for 1 minute. Plug the TV it back in and turn it on.
      NOTES:
        • If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
        • Projection TVs and projectors need to cool down before they will turn on again. You may need to wait several minutes before these will turn back on.
    2. Clean any vents/slots in the TV cabinet and make sure there is room for air to circulate around the cabinet of the TV.
    3. Some Sony TVs have a media box (tuner) and separate display. If you have one of these TVs, check to make sure the cable between the media box and the display is securely connected.
    4. For Projection TVs and Projectors, make sure that the cover/door for the lamp is closed and secure.
    5. If the TV can be operated at all, check to see if a software update is available.
      • If your TV is connected to the Internet, press the Home or Menu button on the remote to get into the setting menus. The Software Update option is usually found under theProduct Support or Contact Sony menu.
      • NOTE: For a limited number of Internet-capable models, the only option is to turn onAutomatic Software Updates and allow the TV to update on its own. If you only have this option, make sure it is set to On. Automatic updates are only downloaded when the TV is in standby mode (turned off with the remote but not unplugged). Normally this download will happen overnight but may take up to 24 hours.
      • Software and driver updates for your Sony product are available online. You can check to see if a software (firmware) update is available for your television. Steps to install will be included if an update is available.
      • Older CRT TV's and TV's that cannot be connected to the Internet do not have an option to check for a software update or may not capable of being updated.
  • If these options do not resolve the issue, the problem is most likely related to an internal component that must be replaced and service will be required.RF
Mar 04, 2015 | Sony BRAVIA Televison & Video
46" Samsung smart TV series 5, purchased Nov 7 2014. When I watch Netflix or a YouTube video the TV is working just fine and I'd assume it works from an HDMI decide as well, but when I'm browsing around...
It sounds that the the problem is with its firmware. It will be best to consult the authorized service centre for Samsung, before doing any software update. A software update will be necessary. But, without knowing any details about the version of software loaded at present, it is difficult to advice you more about the software version, which has to be updated. A wrong software update might make the TV fully in-operative. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 07, 2014 | Televison & Video
PC TV PCI/7130 PAL TV/FM CARD (0022007030107] (s/n:m2349000) software user manual in install CD
hello, you can find the information that you need for this device by going to the link below, it will have the software and driver for different windows version "http://www.fixya.com/support/t8450502-tv_card_driver" Thank you for using Fixya.
Mar 13, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
How do i get a software upgrade for my tv
You will need a USB port or SD Card reader on the TV set in order to update the TV's Firmware. (note: some TV manufactures specify what types of memory are compatible with their TV sets i.e. magic gate, etc.)
Use the appropriate storage device for your TV set and go to:
http://www.support.philips.com/support/downloads.jsp?userLanguage=en&userCountry=us
Enter the model number in the search box. It will search for available software/firmware for your TV set. Download it and save it to your storage device.
Insert the storage device into the TV set. If the software/firmware update screen does not come up automatically, select update software/firmware from the TV's menu.
I hope this helps.
Feb 12, 2010 | Philips Televison & Video
NO sound
go to philips/support.com
then look for drivers/software
download the link onto a thumb drive
put the thumb drive into your television then power the unit on--the tv will run a scan and install the updated software--- there is more info in the owners manual
Dec 06, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
DIGITAL SOFTWARE UPDATES FOR SAMSUNG 32 INCH LCD TV
you cant force updates, and they may never be another update. updates are only made when there is a problem with the software in the tv
Feb 26, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Digital Lifestyle FA1B32Z 32 in. LCD Television Logo
223 people viewed this question
Top Digital Lifestyle Televison & Video Experts
paul
paul
Are you a Digital Lifestyle Televison and Video Expert? Answer questions, earn points and help others
