Question about Canon Office Equipment & Supplies
How do I align the head on my Model-PIXMA MP 970 Canon Printer?
  • Lincoln F Gayton Apr 10, 2011
    Multi-colors are being printed - the colors are not being separated. And differnt colors not in the picture are being printed (wider at the top and narrowing to a fine line at the bottom.
  • 2,574 Answers
How to perform a Manual Print Head Alignment in Windows ->click here .
How to perform an Automatic Print Head Alignment in Windows->click here .
Posted on Apr 10, 2011
  • Canon Master
  • 4,737 Answers
In short, while the printer is On, press the Home button on the printer, use the up-down button to scroll down the menu and locate "Settings", again scroll down and locate "Maintenance", press "Ok" and locate "Auto Head Align" and press "Ok", again press "yes" when you see a confirmation message on the screen. The alignment page will print out. Make sure there's paper in the tray (not in the adf) before performing this.
The long procedure is given below (if in case you need it):
Press and release the On/Off to turn the power on. Open the sheet feed cover on the rear paper tray. Pull out the paper support until it stops at its fully extended position.
  1. Open the paper output tray. Flip the paper output tray extension out. Load a sheet of letter-sized plain paper in the rear tray. Slide the paper guide to the right until it is snug against the left side of the paper.
  2. Press and release the Home button on the control panel. The Home screen will be displayed on the LCD panel. Press the Up or Down Arrow button to scroll through the menu. Select the Settings option. Press and release the OK button. Select the Maintenance option. Press and release the OK button. Select the Auto head align option. Press and release the OK button.
  3. Wait for the confirmation screen to be displayed on the LCD panel. Select the Yes option. Press and release the OK button. Wait for the printer to automatically align the print head and print the alignment sheet. This process should take approximately 4 minutes.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
  • Lebanon Raingam
    Lebanon Raingam Apr 10, 2011
    Well, just to let you know, it would be better if you could post back with the result or with the problem instead of simply reject my solution. In fact I've provided you the solution for your question. Anyway Good Luck.
    Once again Thanks for using FixYa.
Error 5b00 on mp 970
If you get into the Service Menu.
Click RESUME four times.
Click POWER
Turn off the printer and turn on again.
Dec 26, 2013 | Canon PIXMA MP130 All-In-One InkJet...
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Cannot align printer head on Canon mp 210
You need Canon mp 210 set-up disk to align print head. Insert the disk in your computer and follow the instruction.
Jul 06, 2011 | Canon Office Equipment & Supplies
I've got a Canon Pixma MP 500. Printing from my computer = faded print. Copying = blank page. Auto head align fails. Alarm light goes on. Have tried stop/reset button. How can I fix this?
It sounds like the print head on your printer is either clogged or not working.
You get faint print from your computer because the computer will use your color inks to get gray. When you copy, it only tries to use black and the black isn't printing at all.
Check your user's manual and it should show you how to clean the print head. Otherwise replace the print heads and you should be fine.
Thanks,
Pat
Aug 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon Mp 510 printer does not print
mine is the same. did you find a solution to this problem?
Feb 15, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Where can i download cannon pixma mp 198 driver?
follow this link
drivers.softpedia.com/get/PRINTER/CANON/Canon-PIXMA-MP180-MP-Drivers-xp64-101.shtml
Sep 08, 2009 | Computers & Internet
Prints every other line
Use the cleaning cycle first.If it completes do a nozzle check and then to align follow below.
You need to hook it up to computer to do a manual head align through the printer properties maintenance section.
Jun 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon MP970 Streaks!
the colered pictures may be illegal to print like school pictures if you scan and then print them they will have a line threw them.
Sep 04, 2008 | Canon MP970 Photo All-In-One InkJet...
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
81 people viewed this question
old marine
old marine
