My washing machine has not been great over the last few weeks, at time getting stuck midway through a cycle. There has also been unusual flashing on the control panel as well as really loads spinning sounding like the machine will take off at any moment. Now once a program has been selected the machine part fills with water and then wont spin or empty. I have tried using different cycles as well as unplugging it over night nothing seems to make any difference.
    Brigadier General:
  • 6,277 Answers
I suspect 2 things- balance needs to be checked for the 'sounding like the machine will take off...' and a possible blocked filter.
Balance
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
Blockage
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
(Please score these solutions accordingly. Thanks!)
Good luck,
Posted on Apr 10, 2011
We have a Bosch washing machine E-nr wet2820GB / 13 FD 8101 0017. Recently it has started making an unusual, very loud 'crunching' noise during the wash cycle, it then stops on 'main wash',...
There is a clutch that gets dry and sticks it has to be greased from time to time.
It sounds like the clutch cannot slide on the spline and is causing the issue at hand.
Aug 01, 2011 | Washing Machines
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
Cold water will only trickle into washing machine
Check your water pressure if thats good check the screens on your hoses, if thst good go to the water inlet valves that allow water into your tub
Jun 09, 2009 | Washing Machines
My whirlpool duet is about 1.5 years old. It has been working great until the last few weeks. I have had a burning spell coming from it. Now it won't drain or spin out. Just makes a buzzing noise. The...
you may want to check your pump and see if something might be stuck,you should be able to take bottom kick plate off in front of machine.when you take it off you will see the pump.most have a filter you can unscrew and pull out to see how much junk has collected.the buzzing is usually your pump or doorswitch.
Mar 24, 2009 | Washing Machines
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Loud noise thourghout the cycle
I would have the counter-balancing system checked for proper motion.
Jun 07, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
