Question about Garden
My stanley lawn tractor will not go forward or backward. the belt is fine. does the trans-axle require some type of fluid and if so , where does it go in.
  • 3 Answers
SOURCE: i have a 2005 husqvarna lawn tractor. 24 hp, 48 in
sorry. I don't have an ansewer for you however I might have some helpful hints. Your mower should be going dam near 5 MPH. But yes can't cut in reverse. you have a belt going from the trans axle to the motor. It could be slapping against the frame. The idler puller or the tension pulley could be wobaly where the bearings are gone out. If you remove the 4 bolts on the back of the mower under the seat and gas tank it should visable tell you the story. My question is mine hits gears real hard as if trans mission needs oil or internal damage.
Posted on May 10, 2009
wadembly
  • 489 Answers
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Posted on Jun 06, 2009
stmc97
  • 41 Answers
SOURCE: Was mowing when it just stopped going forward. It
Under the mower below the seat of the rider, at the rear of the tractor, look up and you will find the transmission there. There is a belt that runs on the pulley under there, and this belt can slip off when it gets worn or stretched. Sort of a tough spot to get to but, that is most probably cause.
Let me know,
Chip
Posted on Apr 11, 2010
  • 5 Answers
SOURCE: My lawn tractor has started going backwards. How
manual ...www.LRNelson.com
Posted on Jul 28, 2010
woobie dog
  • 1273 Answers
SOURCE: I own a Cub Cadet Hydrostatic Lawn Tractor, not
Hello, W/D here.
Without a particular model number, I'll have to be somewhat generic, so forgive me in advance.
The fact that the mower will run and the blades will engage is good news; it eliminates about half of the things that would need to be checked.
Look for a lever at the (usually) back of the tractor, on the back plate, down low. Sometimes called a range selector or a disengagement lever. Normally, the position of this rod is "IN". If it has pulled towards the "OUT" position, the transmission is disengaged. Usually this rod is pulled out when you want to push the mower, and I expect you're tired of that by now! Chech and see if this is the issue, and post back if not.
Regards, --W/D--
Posted on Mar 07, 2011
Yt 3000 42" will not move forward or backward
Your drive belt might be off or broken (upper one) not the belt that controls the blades. There's a rod at the rear of the mower that also controls the trans-axle, if it's pulled out, the transmission is disengaged. To purge air out of the system, you pull the rod out, keep it in the out position with a pin and move the motion lever to go forward and return it to neutral several times, then do the same thing to the reverse direction. Then release the rod and return it to the very most inner position. GOOD LUCK, hope it's not a bad transaxle.
Feb 24, 2014 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Won't move
check drive belt and tension pulleys under machine if belt is stretched or damaged replace if popped off pulley check all to make sure one has not froze causing it to pop off also check rear pulley on axle sometimes pops off and just spins
May 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman lawn tractor model 917.270821 ( Auto trans)
Check the fluid level in the transmission. If the fluid level is low, the trans will act as if it's slipping.
Nov 25, 2009 | Vacuums
Transaxle not working.
on the back of the mower you will need to remove the back there is a hose comeing out of the trans its a vent tub remove the plug and put some good 30 w oil in the tub tha should fix it
Sep 30, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My mower will not move in gear forwards or backwards? drive belt is on and the pully is turning?
the pully on the trans axle may of sheared the the drift pin and now is just spinnig on the input shaft
Sep 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Wont move
Is it a hyro-axle?
If so, you might have to re-check fluid level and bleed air from the system. With the axle off the ground and the fluid level correct, shift full forward then backward several times with the axle engaged, then disengaged. Repeat this as many times as necessary until you see the axle work properly. I hope this helps.
Aug 23, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I have a 2005 husqvarna lawn tractor. 24 hp, 48 in deck, the transmission runs fine on level ground but when i go to an incline the tranny slips and i hear a clunking sound, and if i travel farther up hill...
May 09, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a OLD Craftsman lawn tractor 36'' Drive belt diagram ?
go to sears.com click on parts and enter your mod#
Apr 19, 2009 | Garden
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
