Question about Compaq Mini 102 NetBook
Hello, I try to instal Windows XP Pro SP3 on a Compaq Mini 102 but Windows installation don't found the Hard drive. Display : Windows XP Professional Setup ============================ Setup has recognized the following mass storage devices in your computer : <none> * To specify additional SCSI adapters, CD-ROM drives, or special disk controllers for use Windows XP, Inluding those for which you have a device support disk from a mass storage device manufacturer, press S. * If you do not any device support disk from a mass storage device manufacturer, or do not want to specify additionnal mass storage devices for use Windows XP, press Enter. ================================== Do you kwno how to do ? Thank you !
  • Compaq Master
  • 1,881 Answers
We can not guess how you did this.
Microsoft CD/dVd install media, ?
HP CD install media from HP
home made media,???? dont
or F11 key restore.
so how can we guess that, ?and MATTERS BIG TIME.
didn't find ,past tense.
first off , not all PCs are the same.
did you go TO BIOS and run the HDD test first? page 73 below.
after the HDD can BAD , so we do that first.
if that fails it is bad, for sure.!!! buy a new SSD and install that?
then boot and (power button) and press F11 as the service guide tell you, see link at end.
F11 reloads the OS. page 92
F11 is only works if:
1: HDD GOOD
2: Someone did not install Microsoft OS and kill the HP restore partitions.
3: XP virus didnt wreck that partition or someone did foolishly.
if F11 is dead, then only HP install disk work. real.
that means all HP software like new still all works like day 1.
if all you need is email, then other solutions are available.
first google hit btw... in 1 second flat.....
http://www.hp.com/ctg/Manual/c01990115.pdf
Posted on Jun 29, 2017
2 Suggested Answers
  • 451 Answers
SOURCE: Hello, I try to install Windows
try setting the bios for the hd to ide compatible
windows xp does not include sata drivers which is why you can't detect the hdd.
if you set it to ide compatible it should work
Posted on Apr 10, 2011
Why can i play hidden object adventure pack on my dell with Windows xp
Hi Jennifer,
When you say that you are unable to play , do you mean its not loading ? unable to install it? do you get a specific error message when you try to launch it ?
hidden object adventure pack:
  • System Requirements: Windows XP (Home & Pro) SP3, Windows Vista SP1, Windows 7 . , 800 MHz processor or greater. , 512MB RAM. , 237MB free hard drive space. , DirectX 7.0. Administrator privileges are required to properly install the program on Windows XP, Windows Vista , and Windows 7. Format: WIN XP,VISTA,WIN 7 Genre: ENTERTAINMENT Rating: E10+ Age: 8386390063
if your using windows XP , make sure that you have Windows XP (Home & Pro) SP3 and the rest of the specs mentioned above.
Thank you.
Dennis
Aug 03, 2014 | Video Game Consoles & Games
My windows xp startup disk with the os an drivers is no good microsoft says i need contack manufactures copy do have one
You should not have contact the manufacturer (microsoft)
one of these will help you
SP3 is the third and final service pack released for Microsoft Windows XP, and it eliminates many of the security holes that previously affected XP. While Microsoft recommends that users download SP3 using Windows Update, some users are unable to do so. However, it's easy to create a Windows XP SP3 installation CD; it requires only that you download the pack from the website and burn it to a CD-R/DVD-R using an ISO burner program.
Download the SP3 installation ISO by visiting the first link listed in the "Resources" section of this article. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en XP PRO SP3 ISO Download the iso also download the imageburn http://www.imgburn.com/
http://windows-xp-pro-startup-disk.soft32.com/ http://support.microsoft.com/kb/322389 http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid windows xp pro start up disc
post a reply if you need more help with this
Mar 12, 2013 | Compaq Presario sr1403wm AMD Sempron 3000+...
HP dc5000 compaq - running win xp pro sp2 and it won't upgrade to sp3. Sp3 needed to run Nero 11.
go to this link http://www.microsoft.com/en-us/download/details.aspx?id=24 download winxp sp3 exe follow instructions disregard for IT professionals and developers this is the download you need after installing goto windows update and download and install updates
Aug 24, 2012 | HP Computers & Internet
Hello, I try to install Windows XP Pro SP3 on a Compaq Mini 102 but Windows installation don't found the Hard drive. Display : Windows XP Professional Setup ============================ Setup has...
Apr 10, 2011 | Compaq Mini 102 NetBook
I have a compaq presario r3000 and i'm having trouble when i install windows 7 or when i try to install windows xp pro sp3...first with windows 7.. it will load up to the windows 7 logo and then just shuts...
From what you are saying i would try installing on different hard drive, as it sounds like file corruption is playing a big part of your problems. If it isnt the hard drive then it may be one of your ram chips
Mar 17, 2011 | Microsoft Computers & Internet
I bought a brand new compaq mini 102 with windows xp installed in it. Once i turned the unit on, it takes long time to boot and if i open a folder or a file, it took minutes to respond. How can this be...
hello,
I think you have a virus threat in your laptop.
if you are using internet than you must use a good antivirus programme & First you install a good antivirus & scan your laptop it will surely fix your problem.
if above doesnt work than u can do defragmentation of your harddrive it will surely help you.
Thanks
Dec 30, 2010 | Compaq Mini 102 NetBook
Installing XP SP3 pro on my presario C700
Most likely you have a SATA drive which windows is not detecting. Restart the setup and press F6. You will need to use another system to download the SATA drivers and save to a disk. Then when prompted you can insert the disk. You can also upgrade to XP professional which will almost always recognize the SATA drives. Good Luck.
Jul 30, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Presario C300 Recoivery Disc 2 corrupt
Hi John.
F11 process is not working and you get a NTLDR missing when you turnon the notebook.
Steps to be performed:
1. Perform hard drive self test from BIOS.
2. If it is passed then use retail version of operating system disk to install XP or try using new recovery disks which nay cost you $15.00.
In your notebook model this issue appears if there is any issue with the hard drive.
Jul 04, 2009 | HP 435768-001 - Compaq Presario C300...
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
Compaq Presario SG3430IL Desktop PC display does not work with windows xp sp2 and vista
Kindly get me the drivers as i have installed xp in my compaq system. and i want drivers for that
Aug 20, 2008 | HP Compaq Motherboard
Compaq Mini 102 NetBook Logo
87 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
