Question about Car Audio & Video
My GM-7300M anot woking
Recently my GM-7300M amp stopped working ive checked all my fuses and wires and found nothing wrong with it. My wife bought it and had it installed at best buy and now a year later it wont work.
  • 631 Answers
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage on both terminals is 12v or higher, the amplifier may be in need of repair.
Let me know if you have any other questions.
Posted on Aug 09, 2008
My amp quit working i might have overloaded it. ive checked all the fuses on the out side all wires r hooked up properly. i was wondering if there is a couple of fuses on the inside and what can i do if...
The only servicable components on your amplifier are the extrenal fuses if any.
If you have checked them and there is othing wrong then you will have to send your amplifier in to a reputable dealer to have it checked and repaired.
Nov 07, 2009 | Pioneer GM-5300T Car Audio Amplifier
2003 ford escape, fuse keeps blowing for door locks, radio and dome light. y
check for a shorted to ground positive wire repair as nesseacry
Jun 01, 2009 | 2003 Ford Escape
Fuse for brake lights blows
There is a short in the brake light wiring, that I guess you know, these types of problems have no common fix, each is different, did you add any wiring like for a trailer?
Oct 01, 2008 | 2006 Ford F-150
Installation
Buy an amp wiring kit. The battery cable goes to the battery (duh, right?) with the fuse within 18 inches of the battery. The ground gets bolted to a clean section of the car chassis/body. the remote lead goes to the radio's remote out (blue/white stripe). the rca cable goes to the radio's Sub/rear RCA outputs. Speaker wires go the speakers. Done!
Sep 12, 2007 | Pioneer GM-7300M Car Audio Amplifier
No power to amp
Are you sure it has the full voltage going to both BATT and REM? sounds like the REM signal is weak.
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Car Audio & Video Logo
87 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
