Question about Dishwashers
Kitchen aid built in quiet model door won't open and no lights on in the panel such as the green light when the cycle is finished. light was there after original cycle was completed. machine works when any button is pushes to use any option.
  • 2 more comments
  • jecvec Apr 10, 2011
    lights and machine work when panel choices are selected. The door won't open. I've pushed and held random buttons on the machine to no avail. It's finishing a cycle now..how do I get the door to open when the cycle is finished?
    could the problem be a broken latch? If so, how do we trip the latch assembly to open the machine?
    now all lights work as normal. and the machine cycles as normal...I just can't get the door open... If I need to replace the control module, how do i get the door open????
    there is no water in the machine....it completely cycled. how do I open the door?
    the machine has been installed behind the front of the countertop so that disasembling from a top panel will be difficult. Sliding the machine forward from the wall will require some cutting. I don't have access to the manual... is there a way to trip the lock as one might in opening a doorlock on a car? Do I wait until tomorrow and look at a machine manual at the appliance store?
  • 19,396 Answers
Hi.
I understood that the problem is that machine works, but the control panel does not display any light during cycle. If problem is instead that there is no power at all (no lights, no sounds, and no functionality), then the firs part to test is the power cord, that may have a built in fuse.
If there is power but there are no lights, try first disconnecting power cord or tripping circuit breaker for fie or ten minutes. This will power reset the appliance.
If that does not fix the problem, the control panel built in the door must be disassembled and tested. The problem is fixed replacing the control panel or the control module.
If you need to contact a technician or to purchase parts, use the phone number listed on the owners manual.
You can find parts and specific diagrams using the link below:
Where do I find parts and diagrams?
Regards.
Ginko
Posted on Apr 10, 2011
  • 2 more comments
  • Ginko
    Ginko Apr 10, 2011
    Hi.
    A broken latch may result in door not opening, but no lights in control panel is not commonly caused by a broken latch. If the latch is creating a short to ground because of a contact, that may cause control module malfunction, but it would be a very uncommon fault.
    The latch is probably seized because the control module is defective.
  • Ginko
    Ginko Apr 10, 2011
    Hi.
    If the machine restarted after reset, then the control module is usually OK. Often you get control temporary failures that can be caused by malfunctions taking place elsewhere.
    The door lock is stuck, either because of the control module initial malfunction, or because the latch mechanism itself is defective.
    Next step is getting rid of the water. Try first running a short cycle. Try to go through whole cycle, so that machine drains. Disconnect the appliance, move it and check the drain hose at the back. Empty water inside and check hose height settings. They are given in the manual. If hose is set incorrectly you get water back in the dishwasher.
    Connect and test. If that does not work next step would be reaching the pump hose. This depends on the model.If the pump is not accessible with door shut, then the machine must be disassembled from top panel.
  • Ginko
    Ginko Apr 10, 2011
    In short:
    First give it a couple of tries running cycles.
    Try again disconnecting power after cycle is done.
    If that doesn't work, check drain hose.
    If still no luck the machine must be disassembled to unlock the door. Test the door lock, and eventually replace it or fix wiring harness or control module. Overfill and pressure switch (if present) must be tested as well.
    Read also my previous comment.
  • Ginko
    Ginko Apr 10, 2011
    Hi.
    You probably have a broken door latch. Something like descriptions here : Thread door latch broken can't open door ' Appliance Blog Forums ...
    Check second post (door latch broken can't open door )
    I suggest calling a technician.
Kitchen aid gas dryer lights up but won't start
What is the model number? Look inside the door jamb.
Oct 19, 2012 | Whirlpool GEX9868J Electric Dryer
Kitchen aid dw won't start,, the lights come on it beeps at me but won't start the cycle... also, during a cycle i can open the door and it doesnt halt the cycle, it just keeps on going
see this causes:
Power from the house
reset the c.breaker from your hose or replace blown fuse inside the machine.
Door switch
test the door switch for open or defective this will NOT permit to close the relais for start the motor
Wiring
loose wiring, break or burn repair
Timer or selector switch
selector switch, open or defective, timer defective, however clean contacts diryt or oxide, loose wires, break or burn. GOD BLESS YOU.
Jun 21, 2012 | KitchenAid Dishwashers
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Jan 02, 2010 | KitchenAid KGST307 Gas Kitchen Range
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Dec 16, 2008 | KitchenAid 24 in. KUDP02CR Built-in...
Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
May 17, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
