Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool washing machine does not work after move
Our Whirlpool washing machine worked for about two weeks after our move and now it is no longer working. It was purchased in 2000, is an Ultimate Care Super Capacity make, top load. I did check to be sure it is plugged in and breaker on, we are not getting anything when turning on. The moving company apparently does not cover the inner workings of washing machines so any advice is appreciated.
Thanks!!
  • jeclark Aug 08, 2008
    Thank you for the suggestion, however, this did not fix it. We have the Whirlpool Unlimate Care II Heavy Duty Super Capacity Plus. Not sure if this would make a difference in troubleshooting. I look forward to your next suggestion!!
    Thanks again
  • 481 Answers
You can check the harness under the control panel and make sure it is not loose from the move.Whirlpool washing machine does not work after move - ee653d9.jpg
this is just the first step, so if it is not the problem let me know and I will help you figure it out. Mike
Posted on Aug 07, 2008
  • Mike Durland
    Mike Durland Aug 08, 2008
    the timer would be the next thing to check.
  • Mike Durland
    Mike Durland Aug 24, 2008
    sorry I was not helpful at all. maybe someone else will benefit from the pics i took for you. I quit this website.
Wtw5200VQ2
have you checked the lid safety switch under the top that opens and stops the machine when you open the lid? if these get bad they wont work even if the lid is down,you can open control panel and by-pass this switch for testing
May 11, 2012 | Whirlpool Washing Machines
My Whirlpool Cabrio (Model Number: WTW6400SW2) washing machine gets an F1 error signal 5 seconds after I power it on to wash something, I have to pause it and then restart it for it to work,
Your machine needs a new control. The F1 code is an error within the main machine control, and it will only get worse the longer it goes. CLICK HERE for the part. Using coupon code 1050 will get you a discount on the part!
Jan 12, 2011 | Whirlpool Washing Machines
I have a whirlpool GHW9200 series washer, a few weeks ago I wash getting an F02 error, so I cleaned the trap and it worked OK for a few weeks and now it won't drain at all, I set it to spin and drain, puts...
I had a similar problem with my 9200, after looking up the fault codes, I found the f02 code can be triggered by low or insufficient water supply. After disconnecting and cleaning the inlet screens on the supply lines, have not had the problem since. Unfortunately since then, the spindle broke and destroyed the plastic tub, so we moved up to a Samsung and like it much better.
Jan 04, 2011 | Whirlpool GHW9200L Front Load Washer
My machine will agitate but won't drain or spin. A few weeks ago, I discovered sticking a screwdriver into the hole (directly under the lid) would make contact and would allow it to drain and spin. Its...
The thing you were poking with a screwdriver is called a lid switch. That would be bad. The cost is about $45.00. You can buy one online or from a appliance parts distributor. Good luck! Make sure you rate me.
Aug 22, 2010 | Whirlpool LXR6432JQ Top Load Washer
My start button no longer works on Whirlpool Cabrio WTW6600SW0
the plastic board where the button attaches is broken and the button fell down inside..
Feb 09, 2010 | Whirlpool Washing Machines
Top Loading whirlpool washing machine.
Could be the top lid switch. If the timer has stopped moving (you can no longer hear it clicking along) good chance that's what it is. When it has stopped try pushing hard down on the top of the lid AND/OR put a piece of plastic (or something ) into the lid latch switch... See if it continues on with the wash cycle...
Mine just went bad this week. Bought the part for $25...
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle sounds like a jet plane, machine rocks and rolls. have had washer for one week.
washer was under warrenty. called whirlpool and a service man camed to the house.i did have a wonerful response from your site and will call the appliance service man, when washer is no longer under warrenty,who called me yesterday and gave me lots of information. thank you!
Aug 01, 2008 | Whirlpool Washing Machines
Won't fill with water
is your water turned on if it is you have a bad water valve
Jan 20, 2008 | Whirlpool LSN1000LW Top Load Washer
Drum filling with water
An obstruction in the water-inlet valve may mean that it's no longer able to shut off You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Good luck !
Sep 09, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
323 people viewed this question
Dan Webster
Dan Webster
Sal De
