Question about Tippmann 98 Custom Pro Act Paintball Gun
I have a tippmann custom pro with a cyclone feeder. I recently got the SAW stock to put on it and encountered some problems many times after I reassembled the gun. I took it apart at least 5 times before I thought it was fixed but now ive encountered another problem. I believe it has to do with the cyclone feeder not responding or something is out of line in the gun. When I picked up the gun to shoot, no paint came out so I took off the CO2 and the barrel and saw that the paintball was 1/3 inside the gun. I also have a problem when im shooting it sometimes does really fast burst. Thank you
  • 274 Answers
Hi there. Tippmann markers are super tough to make sure that they are put back together properly. The stupid clamshell design plus all the little, under engineered parts make it difficult to get it back together properly, especially after installing a stock. I was in the paintball industry for 10 years but have been out of it for a little bit, but i was one of the founding members of Uprising Nation and was a gunsmith/ salesman for PaintballOnline.com / Xtremes. Now with that said...I even had trouble with the tippmann 98's...and I can rebuild an autococker with my eyes closed but can sometimes be stumped by the tippy's bad design. It is really tough to diagnose an issue on these guns without looking at it. You may have the ball detent backwards,l missing a pin, sometimes the after market stocks on those are a little too large on the outside diameter preventing the internals from properly seating. The cycloce system may be off due to the valves not meing properly aligned or the connecting rod not being in all the way. Many times though it is incorrect installation of the detent or the deternt gets damages. That little orange peice of **** flap is a mance. I would start there.
It may seem like i am bashing your gun. Im not... Once they are put together properly they work great. Just DONT TAKE THEM APART. lol. If you buy the parts at a local gun shop they will install them for free.
lol I have 6 guns for sale :)
Have a good day
Posted on Apr 10, 2011
  • enricolatham Apr 12, 2011
    So does dicks sporting goods count as a gun store? Will they also fix your gun?
  • Kelly Comstock
    Kelly Comstock Apr 13, 2011
    Nah. sorry. the large chains that sell pb guns wont have a gunsmith. You need to find a true blur pb store.
The Rear Bolt wont **** fully
it sounds like your bolt is upside down try rotateing it 180 degrees
Dec 31, 2012 | Tippmann 98 Custom Act Paintball Gun
The paintballs just fall straigt out of the gun or shots like 5 at a time
The part that is bad Tippmann calls a "ball latch". It's a small orange rubber part that keeps the ball in place before the marker is fired. The parts is inexpensive it is common in most paintball stores or can be found online at www.tippmannparts.com
I highly recommend taking this paintball marker to a local pro shop to have the part replaced. You can service this marker at home but is not easy to put together if you have experience working on then, they have a few springs under tention that make it tough to put back together. If you are interested in doing the repair yourself I highly recommend doing it on on a clean floor in a clean room so when you disassemble it it will be easier to find the springs that could shoot out.
One thing that will make it easier is to leave the feedneck on. It will keep one less spring from jumping out at you, just a tip from a pro. I also highly recommend not using a spray lubricant and to only use oils in you tippmann made for paintball guns.
Sep 19, 2011 | Tippmann 98 Custom Act Paintball Gun
Just installed a shoulder stock on a 98 tippmann......velocity is really low.why?
There could be a 2 reasons. The spring guide could be missing or your new stock just has different tolerances and you will need a spring kit.
Spring kits found here.
If the spring guide is missing and lost you can find it here.
Apr 18, 2011 | Tippmann 98 Custom Act Paintball Gun
I have a used custom 98 ACT platinum. When i fire it , it goes full auto. My speed is at 270 fps.What do i do?
Buy a oil for a few dollars made specifically for paintball. Put a few drops in the ASA(where the tank screws in) screw the tank in and try to fire it about 10 times. If the gun still goes FA or sputters, I highly recommend having it serviced by a local pro shop or Tippmann.
Mar 29, 2011 | Tippmann 98 Custom Act Paintball Gun
I attempted to put a car stock on my Tippmann 98 custom and took apart the gun but the stock didnt fit, now when i put it back together and shot it with my tank connected the gun wont stay cocked and...
Check the O rings on the big metal striker, make sure that you have the spring on the back (where the stock would have went) in the right hole on the back plate. Make sure that your velocity is set to a reasonable level.
Oct 02, 2010 | Tippmann 98 Custom Act Paintball Gun
I have an a5 paintball gun with electronic trigger, when i hook it to air and pull the trigger, the hopper is not moving!!!
On the A5 the hopper or Cyclone feed is powered thru a small tube on the feeder side
of the gun. Make sure that tube is connected and if so, pull it off and see if air is flowing
thru it when you pull the trigger. If not, the internal passage may be blocked. Tear down
the gun and clean out the obstruction. If there is a pulse of air coming out the tube when firing
then it may be the Cyclone feed mechanism. Just unscrew the 3 phillips head bolts
under the Cyclone and observe the air driven gear drive. Air up the marker and see
what is moving or not moving. Complete replacement upgrade Cyclone gear drives
are available that say they increase performance if you cant get it moving.
Here is your manual
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
Sep 25, 2010 | Tippmann A 5 Standard Paintball Gun
Paintballs will fall out of the barrel of my tippmann 98 custom, randomly when the gun is not being fired. I am not sure how to fix this, or if it can be fixed. Mechanically the gun fires and aims great....
Get another ball detente from ebay, this one is the cheapest one I could find.
http://cgi.ebay.com/NEW-TIPPMANN-C-98-BALL-DETENT-A5-BALL-DETENT-/370469346400?pt=LH_DefaultDomain_0&hash=item5641b19c60
Jun 26, 2010 | Tippmann 98 Custom Act Paintball Gun
Tippmann a5 cycles just not fast
The cyclone is supposed to feed at least 15 p/s if you are having that problem I would take apart the cyclone make is clean, you would not believe how much paint can get in there. I would check the hose and after that the o-ring on the cylinder piston. Another thing that might be messing the cyclone is the speed on the marker or the valve itself not sending the amount of CO2 or air to the cyclone. I hope this helps.
May 02, 2010 | Tippmann Cyclone Feed System
Model 98 rap 4 stock issue
yes . take your time and sand to fit,
Jan 09, 2010 | Tippmann 98 Custom Act Paintball Gun
Tippmann Custom 98 simply NOT WORKING
  1. Home page | Special Ops Paintball SPECIAL OPS - A-5-A2 COMMANDO EZ-KIT. Regular Price: $ 79.95 ... Special OpsPaintball is a proud sponsor of the Living Legends scenario paintball game. ...
    shop.specialopspaintball.com/ - Cached - Similar
    Forum Brigade Tippmann A-5 Upgrades Gear Vests Articles Sick Deal Tippmann X7 Upgrades Markers More results from specialopspaintball.com »
    YOU NEED TO BUY A RE-BUILD KIT ITS CHEAP HERE.
Oct 04, 2009 | Tippmann 98 Custom Marker
Tippmann 98 Custom Pro Act Paintball Gun Logo
152 people viewed this question
Top Tippmann Sport & Outdoor - Others Experts
spank61
Tom Chichester
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
