Question about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
Amana ALW88OQAW full or empty mech. vibrates (hard)
    Brigadier General:
  • 6,277 Answers
(try this!)
I mostly answer front load problems but ' out of balance' is a common problem with both!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck and please score this accordingly. Thanks,
John C
Posted on Apr 10, 2011
Rough idle problem with Santa Fe. I changed the egr valve no good. Very bad vibration it turns out my injectors where very bad and it didn't show up on many diagnostic systems plus airflow meter was bad...
no year stated
2.2 liter Diesel.
first off its not a jeep, i moved your post.
this is not a question.
and misfire is caused by over 50 things.
and the PCM is not AI yet, come back in 2050 and we might be there. (artificial intelligence, Alan Turing dream, is not here yet) sorry.
it still takes hard work, a real scan tool and experience to find problems. Did you drive the car hard with scan tool logging full time.
sounds like the problem was not the engine at all (not misfiring at all)
, but was a pure physical mech failure.
of a clutch.
any thing can break at any time, in the real world,
car has 3000 parts, any can fail.
Mar 17, 2015 | Hyundai Santa Fe Cars & Trucks
Amana 115vac60hz bucket full
the aircon unit sweats when it is cold, this sweat drips into a bucket. You must empty the bucket when it fills up. the unit tells you when it is full. 24823715-u40lsvyytnuesyuv3fbafhtd-3-0.jpg
ahh... sweating beer! empty the bucket.
Jul 14, 2014 | Frigidaire FAP094P1 Portable Air...
Hard vibration
that is called MISFIRE.
it is caused by 50 things, (misfire and flooding)
why guess.?
vibration parked?
vibration racing in neutural?
hot or cold engine or both.?
only moving , ? at what speed, what gear, is it autotrans or sticK shift.
a mech sees all this in 5min flat, me never.
making me blind.
see, and anyone else too. id bet.
Feb 14, 2014 | 1994 Toyota Camry
2007 murano passenger seat & console vibration
1st stay away from dealers-the mechs are inexperienced-------motor mounts may be bad or align service not rite etc--bring it to a specialist that is honest---chec out magicmechanic online and send him the issue-loves to reply
May 05, 2012 | 2007 Nissan Murano SE
I have two hard drives on my computer one is nearly full the other has on a few things on it, but i don't know how to transfer things from the full one to the empty one
Just simply copy any big folders you have on your full drive onto anywhere else on the empty one. Remember to start installing things to the empty one too. Right Click>Copy>Paste onto empty drive.
Start>Computer> You should see your two drives.
Jun 25, 2011 | Computers & Internet
HI, our Amana ice maker produces only a shell of an ice cube sometimes. It happens during half of a harvest is emptied. We turn the ice off and let it sit for a few hours and then some harvests are...
you are having a problem with not enough water getting into the ice maker.
we call this getting "hollow cubes"
you have to clear or replace the valve that connects to your house water line. most are whats known as a "piercing type" valve. they get plugged or break into the water line of your house.
you can try to shut off the valve and then turn back on and see if you get full size cubes after that.
most likely you will have to replace the valve with a "drill type" of valve from your local hardware store.
this is very common and the new valve will fix your problem.
Jan 08, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Carb 740cuts out while driving fuel filter empty
Check in tank priming pump, also check inline fuel pump. runs only while eng. is rotating.
Dec 27, 2009 | 1990 Volvo 740
Vibrating Front Loader
An experienced appliance technician can quickly check the balance of the machine. If the tub is off-balance or one of the balancing springs has been damaged then the technician should be able to resolve the problem without too much trouble.
Installing anti-vibration pads is also a good solution. Some pads are much better than others. Pads made of hard neoprene rubber are okay but try to find something made with a urethane rubber or multi-compound material. My appliance repair tech swears by Silent Feet pads from The Vibration Solution.
Jun 27, 2009 | Amana 3.2 cu. ft. Top-Load Washer
1990 wrangler 4 cyl - gas guage stays on full
you have a bad gauge( check dealer ) for part. easy fix, they will even let you talk to mech. to get some helpful tips
Dec 24, 2008 | 1990 Jeep Wrangler
Amana APO95R Turning Off/Tank Light (!) On and Off
There are only two items that will shut it down after it is set to run. The bucket full which you took care of and low humidity in the area it is being operated in. Low humidity would not constitute a reason for returning it.
Jun 15, 2008 | Amana Haier AP095R Air Conditioner
Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
128 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
