Question about Exercise & Fitness
Hi! I have balanced two wheels whith my 471 Repco Electronic wheel balancer. I let a wheel shop test my two wheels. My wheels have too much tireweight, 15-20 gram each. I also test some of my summerwheels and I have same problem there. Do you know if I can callibrate my 471? I did not find anything about this in the manual. Do you have some manual for calibration? Best regards Michael Carlin Sweden
SOURCE: CALIBRATION OF POCKET SCALE
Press and hold 'CAL' key to calibrate the scale. www.luxford.cn
Posted on Dec 14, 2007
  • 126 Answers
SOURCE: Front wheels
BEFORE YOU TRY TO FIX THE WHEEL AND DAMAGE IT MORE THAN WHAT IT IS PLEASE CALL GRACO AND SEE IF THEY CAN SEND YOU ANOTHER WHEEL.
replacement parts
LINK: http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
Telephone
Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Postal Address
Graco Children's Products Inc.
Attn: Graco Store Consumer Services
150 Oaklands Boulevard
Exton, PA 19341
Posted on Apr 28, 2008
  • 64 Answers
SOURCE: Faulty Repco sports treadmill
Not really familar with this brand but if it has a safety key, check to make sure it properly inserted and making proper connection.
Posted on Jun 08, 2009
SOURCE: i need to calibrate the coats 850 wheel balancer
hi,
to calibrate coats 850, first you take a balanced wheel, tie it on machine shaft, enter the wheel dimension or wheel data such as distance, width and diameter, the press c90c, start the machine after completing cycle machine stops, add 100gm wieght out side the wheel and run it again, after this complete cycle your machine will be calibrate,
if you have any problem you can sent me email on zafakar@yahho.com
must reply me.
best regards
Zafar
bye
Posted on Oct 17, 2009
  • 194 Answers
SOURCE: How to operate my 700ss wheel balancer?
the manual can be located athttp://partners.ammcoats.com/docman/viewDocument.asp?sParm=hemmfdmoc-t~e-t
Posted on Dec 12, 2009
What is my balance?
we have no idea whatsoever.
Dec 26, 2017 | Cars & Trucks
How good is static balancing of motorcycle wheels or do I need to dynamic balance them and where would I find the weights to put on a specific wheel (Yamaha XJ650G). Wheels are Aluminum with a center...
Hi, John static balancing is fine for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
YZF600R Forums View topic No Mechanical Experience Should Replace My Tires...
How to balance motorcycle wheels using static balancer
Yamaha XJ750 Owners Workshop Manual
OEM parts for Yamaha
http://www.carlsalter.com/pdfs/Yamaha_XJ600SK_Owners_Manual.pdf
Jul 30, 2013 | Yamaha XJ 650 Motorcycles
Steering wobbles when driving
Improperly balanced wheels can cause the wheels to wobble at speed which can be felt through the steering wheel. A local tyre shop can test the wheels for balance and make the necessary adjustments to the wheels by adding weights to even out the balance.
Feb 07, 2013 | 2008 Citroen Berlingo 1.6
Right front tire inside balding, shakey steering wheel at higher speeds. Any input?
This sounds like the wheel balance is out and /or the tracking is out. You need to take it to the tyre shop and ask for the front wheels (both ) to be tracked and balanced. This should cure the problem.
Good luck
Nov 13, 2010 | 2003 Toyota 4Runner
2002 VW Passat shakes when on the highway traveling over 60mph. ABS module needs to be changed, as well as some engine coils. Do not know why shaking is happening, any info on this?
Over 60 MPH is likely due to the wheels being out of balance. I would take it to a local tire shop and have the wheels balanced and then take for a test drive. Look also for bent rims or any damage to the tires but over 60 is likely out of balance.
Oct 20, 2010 | Volkswagen Passat Cars & Trucks
HI I HAVE A 01 FORD EXPEDITION AND ABOUT 3 MONTHS AGO IT STARTED TO SHAKE A LITTLE WHEN IM GOING ABOUT 50MPH AND ITS LIKE WELL IM NOT A MECHANIC BUT ITS LIKE THE INJECTORS WERE DIRTY. OR SOMETHING WAS...
Sounds like a wheel balance problem. If there's no instability in the steering at speed (wandering, cutting) meaning you don't have to keep correcting it to stay on the road, its most likely tire balance. Check your wheels for packed mud, bent rims or tire belts that have seperated. The way to tell this is to look at the sidewalls for concave spots. This is where there will be a broken belt. This will create balance problems. If none of these exist take it to a tire shop and have them check the balance. The shop that installed the tires will usually do this for free.
Feb 08, 2010 | 2001 Ford Expedition
My GX470 IS JERKING. The kind of feeling when wheels aren't balanced. Have done balancing and nothing changed. It happens whether brakes are applied or not.what else do I have to do.
make sure they were balanced correctly. the big lexus SUVs are very sensitive to the balance of the wheels. alot of tire shops use what is called smart balance, it rounds off the amount of wheel weights to make balancing faster. its great on most cars but on luxury cars it doesnt work as well. also make sure they roadforce the wheels. however unlikely it is that wheels with that large a sidewall will have high roadforce it is still possible.
Nov 11, 2009 | 2004 Lexus GX 470
Hi. i have changed my tires now when i drive i get this vibration all over
They ALL Must be Checked for Debris Behind the RIM < or Between Rim & HUM this is a Common Misshap upon Switching Wheels Also Be SURE they ALL are SET BACK against there Hubs.
Sep 27, 2009 | 2004 Audi A4
Exercise & Fitness Logo
118 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
