Question about Toyotomi TAD-T32G Portable Air Conditioner
My Toyotomi TAD32G portable air conditioner is not working just recently stops working. The main switch "on and off" bottom blue light is flashing. I did check all the troubleshooting based on the owners manual and It was all good. Except the bottom blue light indicates internal wiring failure? Why? what went wrong since I've only got this for 7months from purchase. Anybody with an expertise and a kind heart to please help me fix with a step by step procedures I would really appreciate it. Thanks in advance!. PS. this unit is kind of expensive for me and not even a year yet that's why I'm desperate to make my money worth it for buying this.
  • france_0911 Apr 11, 2011
    Update: The correct model is TAD-T38J
5 Suggested Answers
CrazyLarry
  • 173 Answers
SOURCE: light on plug doesn't come on
most things are put together with a philps screw. sometimes star screws. start there unscrew all the screws you can find some might be hidden. no screws its a snap together plastic piece take a flathead screw driver to pry gently on a corner low...in case u dent it..if you ever get it open fallow the ac cord inside and it lead you to the fuses. sometimes they put a fuse link inline with ac input cord and heat shrink it...get your ohm meter out and test all fuses you find for continuity. replace with exact if new one blows you have a short somewhere.
Posted on Aug 18, 2007
  • 86 Answers
SOURCE: toyotomi ccti/ccto 445
red light means power on
Posted on Mar 16, 2008
  • 1796 Answers
SOURCE: Freon R-22
Hi!!
I would not worry about the R-22 gas part. First, you do not have to put gas in an A/C unless there is a leak. The A/C gas is not like propane that you have to keep refilling because it gets used up. A/C gas circulates in a closed system and years can pass before you may even need some. Take for example the R-12, it was fhased out in 1994 and it is still available (for technicians only) 16 yrs. later.
So if you like the unit and the $$, get it.
Don't forget to rate this post. Good Luck!!
Posted on May 23, 2010
Testimonial: "Thanks for the advise. You made a reasonable point about not needing to replace the refrigerant for years."
micromatikal
  • 2777 Answers
SOURCE: I have the toyotomi TAD-T38J
That means you have some fairly major hardware failure inside the machine. The control board is my suspicion for sure, it definitely sounds like that is having electrical failure.. Have you called back the Toyotomi service person / people after you confirmed that their suggestion made no difference? This unit is definitely going to need in person service.
Thanks
Tim
Posted on Oct 08, 2010
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
Portable A/C unit will not stay cooling
Install pressure taps, read the pressure & you will find it is probably low on refrigerant. Find & fix leak...charge as needed.
Nov 27, 2013 | Toyotomi TAD-30F Portable Air Conditioner
Need replacement fan motor and contactor
Contact the factory it looks like they sell parts.
The phone number is 203-775-1909
There is a link to parts towards the bottom of the page
http://www.toyotomiusa.com/products/PortableAirConditioners.php
Jun 10, 2013 | Toyotomi Heating & Cooling
My Toyotomi TAD-30F 'tank full' light keeps coming on despite my emptying the tank daily.
Check and see if the light is activated by a float switch. If it is it may be sticking. Your owners manual may have a clue.
Jul 11, 2012 | Toyotomi TAD-30F Portable Air Conditioner
My 1800 will put out ac and then will go off
Check an error code displayed?
If unit stops immediately after you switch on, fan motor mechanism locked. Check motor and PCB.
If unit stops after few seconds, check coil and room air sensor and replace if it's defective.Helpful?
Jan 19, 2011 | Toyotomi TID-1800 Air Conditioner
MY PORTABLE AIR CONDITIONER NOT WORKING!
There is a switch inside the bottom of unit that shuts it off when it is full of water. Has to go in just right to be able to work. Russ
Jul 24, 2009 | Danby 7,000 BTU Portable Air Conditioner -...
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Light on plug doesn't come on
try opening it up to see if there's a fuse inside.
Aug 18, 2007 | Toyotomi TAD-30F Portable Air Conditioner
Toyotomi TAD-T32G Portable Air Conditioner Logo
80 people viewed this question
Top Toyotomi Heating & Cooling Experts
hmca
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
