Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
I have a 16 GB SDHC memory card i formated my memory card and put it on the camera it gives error (the card is set for erasure prevention) and the lock swith is broken (it maybe from here) !!! any solution plzzzzz
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
The SD630 works with SD cards. Your 16GB card is an SDHC card and will not work with this camera. You need to use SD cards, 2GB and smaller.
Posted on Oct 28, 2012
  • kakima Oct 28, 2012
3 Suggested Answers
  • 11967 Answers
SOURCE: I have a Panasonic Lumix
If this is a new card, it needs to be formatted in the camera first. If it has pics on it, you need to download them first using a card reader if necessary.
Posted on Dec 15, 2010
tommya300
  • 724 Answers
SOURCE: SDHC Card 4 GB SanDisk will not format. get
SD 2 gig card max in a Z740 it will hold more than 1000 pictures at max resolution! You can never, at one sitting take that many pictures. If you do buy more 2 gig SD cards or a laptop to transfer and clean the memory!
Posted on Mar 25, 2010
Ge X550 will not switch to memory card when it is installed, stays on internal memory
Hi, a few possibilities...you may have a menu setting that only saves to internal memory, so: clear your custom menus and check your shooting and playback settings. The specs on your camera states that it supports up to 16GB card, so the problem should be a menu setting. Also make sure the little tab on the left side of the SD card is NOT in the lock position.
May 08, 2014 | GE X550-WH Power PRO Series Digital Camera...
Memory card full
If you already used the card in the same camera, the only thing I can think of is you did switch the lock switch on the SD memory card. Or there must be one or more protected images on your card. If the card comes out of another camera be sure it is a SD or a SDHC card, not bigger than 16 Gbyte because a SDXC card would be one size to big. The manual says max card size 16 GB
If you accedentely formatted the card in the PC (or MAC) it could be you did put a format on the card the camera does not understand. Most camera's use FAT (max 32) and never NTFS.
Try to format the SD card in your PC.
Nov 04, 2013 | GE X500 Digital Camera
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
Mar 05, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
The camera reads memory card error but when I go to the menu to format the card the format catagory is not highlighted and when you page down it skips over the format area. I am using a scan disk mobile...
There are no 16GB SD cards. A card that size is actually an SDHC card (yours actually sounds like a Micro-SDHC card). SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
You really don't need a card this size on a still camera. 1Gb is plenty. If you really need more space, you can carry a spare, like people used to take extra films with them on holiday.
I don't know why the 512Mb card is giving you trouble. This might indicate an actual fault.
Dec 11, 2010 | Canon PowerShot SX20 IS Digital Camera
I have a canon 2000 video camera and it says the card is set for erasure prevention and I cant delete some videos that i want gone. How do I correct this problem?
THE CARD IS SET FOR ERASURE PREVENTION
- The LOCK switch on the SD or SDHC memory card is set to prevent accidental erasure. Change the position of
the LOCK switch.
http://shiromundo.blogsome.com
Jul 06, 2010 | Canon FS200 Flash Media Camcorder
I recently purchased a 32 gb memory card for a Canon powershot sd 700 is Gigital elph. This is the second card I have purchased and I keep getting a memory card error message. The 16 gb card in the camera...
Here's the specs for your camera from Canon. Sorry, but an SDHC card is not listed as compatible with your camera. Only SD or MMC. Now look on your 16 and 32GB cards. You'll see SDHC stamped there. Although SDHC looks exactly the same as a standard SD card, the format the cards use are very different. Unfortunately your camera was designed before the SDHC format came out.
You'll need to instead purchase a standard SD card (those that are 2GB or less). Fortunately these are very inexpensive these days, with 2GB cards going for around $6 with shipping.
Jun 11, 2010 | Cameras
My Sanyo hd1010 camera repeats format sdhc card on start up
its a fult with in the camcorder program chips only thing you can do is get it repaired or buy a new camcorder witch may work out cheeper
Oct 27, 2009 | Video Cameras
Card error with 16 or 32 GB SDHC card
The solution according to JVC (and it did work), is only buy card from Sandisk. Toshiba and Panasonic.
Sep 22, 2009 | Video Cameras
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
81 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
