Question about General Electric DCVH680EJWW Dryer
Need a diagram for a dcvh680ejww-drum not turning-can hear the motor-out of warranty- need diagram to take apart to check belt and motor
I have a 14 yr old AEG 3200 dryer. The drum has stopped turning.Could this just need a simple belt replacement or wld you recommed a new dryer. Thanks
If you can hear the motor run when activated replace the belt. You should check or have checked the rollers that the drum is supported by. Check the belt tension-er replace if worn. While the unit is disassembled the rollers are easy to replace.
Vacuum all loose lint out from around the motor while disassembled.
These simple older machines are reliable and very durable and only have a few moving parts.
Hope this helps?
AEG LAVATHERM 60750225500 Tumble Dryer Section Spare Parts Diagram
Jun 21, 2017 | AEG Dryers
Drum doesnt turn when turned on, can hear power goes to motor. Hve checked the belt and it is attached and can be maually turned
SOUNDS LIKE YOU HAVE A PULLY ON THE MOTOR SLIPPING IF YOU CAN HEAR THE MOTOR RUNNING, BUT THE DRUM DOES NOT TURN. IF NOT THE PULLY, THEN THE BELT MAY BE SLIPPING IN THE PULLY, BUT THE PULLY IS TURNING. THEN A NEW BELT IS NEEDED. IN EITHER CASE YOU WILL NEED TO ACCESS THE MOTOR AREA TO SEE WHATS HAPPENING. MOTOR COULD BE NOT RUNNING, EVEN THOUGH YOU HEAR A HUM IN IT. BUT, MOTORS NORMALLY RUN LONGER THEN THE LIFE OF THE DRYER.
Feb 20, 2011 | Dryers
Ge frontloader dryer is squeeking incessantly, high pitch squeek driving us all crazy. by manually turning the drum i can isolate the squeek, but cannot see anything wrong. does it need to be taken...
There is a teflon bearing that holds the back of the drum you will need to replace. To get to it remove the top cover, take off the control panel, remove the front cover, take off the belt, then take the drum out, ususlly by lifting it up as you pull it foward. While have it all apart I would reccomend replacing the teflon glides at the front that the drum rides on.
Jan 31, 2011 | General Electric DCVH680EJWW Dryer
Tub stopped turning, connot turn by hand either.
Dryers have a belt that turns the drum, I think dryer belt being broken or slipping badly, burn out motor, or worn support parts.
---Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it. ---You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it. ---Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Thanks..!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 06, 2010 | Maytag Dryers
My maytag model no.mav4755aww makes a whinning sound at the beginning of the spin cycle
Hi
Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.Since you hear whining it means that the bearing is damaged and the seals on bearing are gone too so it rotates without lubricant. It might be possible to hear whining while you rotate empty drum manually...
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. When the bearings have gone bad, the noise is constant the entire time the drum is spinning.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.Then replacing the bearing is suggested.
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 22, 2010 | Washing Machines
Drum not rotating
There are two causes for this...bad motor or broken belt...
Check out a tip that I wrtoe about this...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 31, 2010 | General Electric DCVH680EJWW Dryer
My kenmore gas dryer drum doesn't turn
Can you hear the motor running? If so, the drum drive belt has come apart (from the heat) and is lying loose. You will need to release the drum in order to get a new belt over it, then coupled and tensioned at the motor pulley.
Aug 25, 2009 | Dryers
Noisy bearing
1 Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
  • Step 2 Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
  • Step 3 Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
  • Step 4 Clear the water pumpmag-glass_10x10.gif from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
  • Step 5 Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
  • Step 6 Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  • i think this will help you
  • Aug 03, 2009 | Washing Machines
    Dryer does not run
    Your motor is going out. Try rotating the drum by hand a quarter turn or so and starting it again. If that doesn't work, TURN POWER OFF, take dryer apart and clean the motor. If still not working, it's time for a new motor, they range between $80 - $140 and reletively easy to replace.
    Jan 21, 2009 | Dryers
    The drum on my dryer stopped turning it was heating and it just stopped turning, I just want to get instuctions on how to take it apart.
    If your dryer doesn't tumble, check these:
    Belt
    Motor
    Door switch
    Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
    Click here for a belt installation diagram.
    Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
    • Remove the belt.
    • Check for obstructions in the blower fan housing.
    • Manually rotate the shaft of the motor.
    If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
    If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
    If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
    Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
    Jun 15, 2008 | Magic Chef Dryers
    General Electric DCVH680EJWW Dryer Logo
    120 people viewed this question
    Top General Dryers Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you a General Dryer Expert? Answer questions, earn points and help others
