Question about JBL PSW-D112 Speaker
Recently acquired a PSW-D112 Sub in good shape and also still have a PSW-D110 sub that has not really ever been used. I have been reading all the posts about these models amplifiers crapping out because of incorrect circuit board Capacitor(s), power module? ratings and the fixes. So like everyone else, I can get access to their service manual and confident in replacing and resoldering what needs replacement but realize these parts are no longer available thru the manufacture. This does not boast alot of confidence so I just need to know if comparable parts are available thru parts-express or another warehouse? Don't know if I should go on wild goose chase look for parts, scrap them, or replace the amp w/ similar one? It's a shame, both in good shape. Even if I use the D-110 it is still going to do what all the others have and fail in time!
    Brigadier General:
  • 8,546 Answers
Or you could prepare for the worst but live in the moment and wait til it dies. You have time on your side. Plus, you could always use it as a passive sub if you have a separate amplifier. I did that with a Klipsch KSW-12 when my second copy blew its amp.
Posted on Apr 10, 2011
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
Mar 25, 2008 | JBL PSW-D110 Speaker
Good afternoom, i need to know at about de part number of CIS53AMI. May you help me?
It is the Class D power amplifier module that JBL uses a lot in the powered sub-woofer, they are very unreliable and hard or impossible to get.
I had modified them to use linear power amp IC instead.
http://s807.photobucket.com/albums/yy352/budm/JBL%20PB-12%20mod/
Mar 14, 2011 | JBL PSW-D110 Speaker
Have a PSW-D112 sub woofer that needs a new amp. Repair facility says original amp took a catastrophic power surge and it's toasted. JBL says repair parts not available. Please advise on source for...
Go to Parts Express and buy the Bash 300w digital subwoofer amp.It fits almost exact except it is one inch shorter.Just use mdf to fill the space and this amp will outperform the original.I have done this and it's not really difficult,pretty straight forward.
They usually sell for around $149,but they have sales often around $99.Good luck.
Oct 28, 2010 | JBL PSW-D110 Speaker
When my jbl psw-d112 is on it will run just fine for a few min then it will sound like the speaker is blown. the green power light that is next to the vol level knob starts to turn red. What does this...
That model is known to have issues with the amps.Your problem is caused by a couple of components on the board shorting out.If you pull the amp out you will find on the large board behind the speaker terminal a couple of burned components.
The easiest fix is to buy a Bash 300w amp from Parts Express and replace the original amp.The Bash amp fits pretty well except that it is about an inch shorter.You can fill the hole with some mdf and have a sub that actually performs better than the original and with less heat build up as it is digital.Hope this helps,it's not complicated really.
May 01, 2010 | JBL PSW-D112 Speaker
I have an old sub woofer I want to hook up to my computer what would I need to do ?
That would depend mostly on your computer's audio capabilities, connections and software. Assuming you already have the rest of a multichannel speaker suite defined and supported, why not a POWERED subwoofer?
You really need to be looking at this from the PC side.
Jan 31, 2010 | JBL PSW-D110 Speaker
Subwoofer will not product sound. (ignore product)
Please verify that we're talking about a JBL PSW-D110 here. I'm making no assumptions.
Are you running the Ipod into its L & R RCA jacks as prescribed?
Have you tried it with something besides the Ipod? A sub isn't supposed to reproduce a full range signal. Come to think of it, is the Ipod even outputting anything within the sub's operational range? I don't expect a lot of real bass comes out of one.
Perhaps you could try adjusting the Low Pass up to 180 to see if anything anywhere near the 'real' bass region is present.
Bottom line: There's not a lot of need for a sub (and no other speakers) running off of any music sound source. You wouldn't hear anything above 180hz.
Nov 28, 2009 | JBL PSW-D110 Speaker
How do you disassembly the JBL PSW_D110?
what i did was i stuck my hand in the port, screw driver in hand, used the blunt end of the screwdriver put it in the indent on the magnet on the back of the sub, positioned it so that the end of the screw driver was stickin out and smacked it with a hammer and it popped out, make sure u take the screws out of the front of the sub, and then take the insulation out of the box and do the same thing to th eboard just do it on theblack part of the amp not on the board
Mar 09, 2009 | JBL PSW-D110 Speaker
JBL SUB ACR10 SUBWOOFER
I would suggest to check the rectifiers first, very unlikely that the capacitors became shorted.
Sep 04, 2008 | JBL PSW-D112 Speaker
Power not working
If it is fused check to see if the fuse is blown... Start with power and work you way down from there.
Power to the sub.
Signal to the sub
Cabling to sub
Check the speaker itself to see if it is good.
john
Aug 16, 2008 | JBL PSW-D112 Speaker
JBL PSW-D112 Speaker Logo
387 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
