Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My LT 4000 wont get in gear. the neutral switch in the back is not ingaged.
Starter stays engaged park or nuetral
Powssible that there is always power to the inhibitor switch. It is the switch that only allows current to flow thru it when in park or neutral. Could be power is always present at the switch when it is in park or neutral. Check the ignition switch first and see if it is powering the start circuit all the time.
Dec 05, 2013 | 2006 Chevrolet Cobalt
When i put it into park it dont ingage and i hve to start in n
Check the neutral switch on the steering column. Sounds like the neutral switch is bad. It is located on the steering column inside and by the floor mat. There is usually two screws that mount it and a wire harness to unplug. Just be sure and don't move the gear selector while changing the switch.
Oct 29, 2012 | 1995-1997 Chevy Suburban Ignition Starter...
Car only starts sometimes
The start circuit from the ignition switch to neutral safety switch to the solenoid on the starter might be bad. Look for power there at solenoid or at neutral safety switch when it doesn't want to crank over.
Jan 02, 2012 | 1988 Pontiac Firebird
I have a 97 Ford Aerostar 3.0 LT wont start
the neutral safety switch is on the transmission where the gear shift cable hooks to it, and I feel like it is out of adjustment and is the cause of your problem.
Mar 11, 2010 | 1997 Ford Aerostar Extended
Bike wont change into gear,
The bike has a bent shift fork. Major repair and major repair cost. Your dealer will probably charge $1300 to $1500 to fix it. Don't try to fix it yourself because the shop will charge an extra $500 or so when you bring it to them in pieces. Besides, you would need some special tools to even begin the job. Sorry, someone had to tell you.
A “very helpful” rating for this answer? Thanks! < < And it doesn’t cost anything!
Jun 26, 2009 | 2006 kawasaki ZZR 1400
97 Mitsibishi Galant Transmission Not Ingaging
Ck transmission fluid level wit trans in neutral. set parking brake
Jun 06, 2009 | 1997 Mitsubishi Galant
Wont start
wont start
i put in a new ignition. now my fuel pump wont ingage and my neutral light wont come on. for some reason my bike will not start or turn over. what is wrong and how do i fix it?
Posted by avatar9.jpgsgaffigan on Feb 10, 2009
    • Added by avatar9.jpgsgaffigan Over a year ago
    • i did that they are all fine. we even jumped the starter cylanoid. and all it did was turn. i think it has something to do with the neutral light not coming on.
Feb 10, 2009 | 2000 Yamaha YZF-R1
Blazer
did you turn the key fully to towards the dash? take the steering wheel left and right slowely and at the same time turn the key back and forth several times slowly. there is a detent inside the steering column that allows you to ingage the neutral safety switch. this should help.....please rate this thanks.
Aug 31, 2008 | 1997 Chevrolet Blazer
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
