Question about Weather King Heating & Cooling
Osne12@when I turn on ac out side fen dosent work
    President:
  • 1,515 Answers
Hi, if it just the fan and you know there is power there, more then likely the condenser fan motor has failed. You can kill power, remove the control cover to get to the run capacitor which is probably round, silver in color with several wires coming out the top. Look it over for any oil leaking out, the top of it swollen or deformed in any way. If you see this, this runs the motor and you will need to get one at a appliance parts house. Also, if it looks good, take something long and thin enough so you can reach in to see if you can spin the motor freely. Or, with the power off, remove the screws, 5/16" to get to the motor and if you have had it on for sometime, carefully grasp it to see if it is hot. If it is, power is getting to it from the run cap, and the motor has failed. These motors fail a lot because they work hard in the heat. You can call out a tech for around $150.00, which would probably be cheaper then what you could do it for. I am sure you have lost this motor.
Shastalaker7
A/C, & Heating Contractor
Posted on Apr 10, 2011
My Dell Latitude D620 Screen is Black and the keyboard dosent work when I turn on the computer. The only LED light that shows is the power light, the wifi or the little cylinder light dosent work. I can...
remove all attached devices like printers or flash drives. remove battery and power on using ac adapter only. if it still wont work, try another good ac adapter. make sure ac adapter light is on. if it still shows the power light on and nothing else, replace motherboard.
May 15, 2010 | Dell Latitude D620 Notebook
THE AC WONT BLOW OR THE HEATER
CHECK BLOWER MOTOR FUSE AND RELAY.IF BOTH GOOD.REMOVE BLOWER MOTOR HOTWIRE IT.IF DONT WORK REPLACE BLOWER MOTOR.IF BLOWER MOTOR WORKS.HEATER AND AC CONTROL SWITCH IS BAD.
Apr 30, 2010 | 2005 Chevrolet TrailBlazer
How do i know if my battery or the charger is the problem causing my camera not to turn on
If the camera works when the AC adaptor is connected its the battery, if dosent work with the AC adaptor, its the AC adaptor.
Jan 22, 2010 | Sony DCR-DVD610 DVD Camcorder
On my 1995 Dodge Ram When I turn the A/C On it dosent seem to kick in and get cold just warm air?
In most cases, the problem is the system is low on refrigerant. The AC compressor requires a minimum of 20psi of refrigerant to turn on. There are refill kits available at the auto parts stores. If doing this yourself, select a kit that includes compressor oil, and a refill hose.
RECHARGING AC SYSTEM
  1. Turn the truck on and turn AC on HIGH
  2. Locate the low side AC line (will have a valve and cap similar to the cap on a tire)
  3. Insert the oil or R-134A can to the hose (Do not turn the screw to puncture the can yet)
  4. Insert the other end of the refill hose to the low side valve
  5. Puncture the R-134A can with the screw on the refill hose
  6. You should feel the system suction the refrigerant out of the can
  7. Check for frost on the AC lines and the air blowing inside the truck
  8. If frost develops and the air is cold, you've successfully recharged the system and disconnect the refill hose. DO NOT ADD MORE REFRIGERANT...overcharging the system will damage your compressor and will be less effective
Hopefully this answers your question and you're able to get your AC working again. Best of luck.
Greg
Jul 13, 2009 | 1995 Dodge Ram 2500
No Cold air from 99 Montero Sport
replaced clutch, driver ac belts on 2000 montero sport a/c is still not blowing cold any ideas
Jun 30, 2009 | 1999 Mitsubishi Montero Sport
Air conditioning problems with 2000 impala
What stuff did you put in it? You might need a freon recharge.
May 07, 2009 | 2000 Chevrolet Impala
Heating & Cooling Logo
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
