Question about Sears Garden
I can not find the directions on setting the dial on the Sears Lawn spreader 1100 model # 671.19871
SOURCE: Spreader Settings
I called Scotts, and according to them the Edgeguard Deluxe uses the same settings as the SpeedyGreen 3000.
Posted on Jun 16, 2009
bbreton
  • 437 Answers
SOURCE: I need a T-handle with control cable for a
Go to www.searspartsdirect.com. You can look up parts there. But you will a better model number than the one you showed. I have tried it.
Merry Christmas
Posted on Dec 23, 2009
  • 13 Answers
SOURCE: I borrowed an older craftsman walk behind lawn
Well, they represent the size of the opening through which the product falls before hitting the spinning spreader part. A larger opening allows more product though; a smaller opening allows less.
I don't know if these are standardized across makes (I don't think they are). The best thing you could do would be to look in the hardware section next time you're in town and set a display model to the setting called for by your product (Scotts always lists the settings for their spreaders on their product), and then eyeball the size opening you get, then approximate that on your machine when you return home.
Or you can just pick the middle setting and do a test run and see if you think more or less should be applied, then adjust accordingly.
Posted on Mar 28, 2010
  • 63 Answers
SOURCE: What i s setting on scotts lawn pro spreader to
you can normally gauge it from the size of the granuals i think it is between 6 and 7
Posted on Jul 24, 2010
  • 10 Answers
SOURCE: I just bought a new
I am sorry that neither spreader performed as they should have. This is very concerning to us, and we would like to get more information about the spreaders, if you still have 1 the manufacture date would be most helpful to us. It sounds like you could possibly have an over-application of the product as well. If you could call us at 1-800-543-8873, we would be happy to discuss this with you. Stacey at Scotts.
Posted on Jun 08, 2011
What setting do I use on a turf king drop spreader to cover 8,140 sq ft?
http://plantscience.psu.edu/research/centers/turf/extension/factsheets/calibrating-spreader
You have given the area you want to spread, but you also need the rate per square foot of the fertilizer. The link above tells you how to calibrate and check the rate of application.
Or you could ask Turf King direct.
http://www.turfking-lawn-care.ca/index.php?option=com_content&view=article&id=107&Itemid=328
Apr 09, 2016 | Garden
What setting do I set my Scotts speddy green 2000 broadcast spredder to spread colonial bentgrass at 2 lbs per 1000 sq ft?
Scotts Spreaders
Robert, Normally the bag tells you the setting to use, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Scotts Spreader Settings Helper Tools Scotts
How to Calibrate Scotts Speedygreen 2000 Lawn Spreader eHow
Lawn Care Basics How To Use Lawn Spreader by Scotts
Mar 23, 2016 | Scotts Garden
The spreader settings are never listed on lawn care products for this spreader. What should seeting be for Bayer fungicide?
If the product you are applying has a spreader setting for any Scotts SpeedyGreen, you can use that setting recommendation. If there is no Scotts Spreader setting, then this question would best be answered by calling Scotts directly at 1-800-543-8873. One of our associates would be happy to assist you further. Hilary @ Scotts
Jun 15, 2011 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 | Garden
I have a Scotts Rotary Spreader model C2.\r\nIt has letters of the alphabet, can u send me the relationship to the numbers . Rich Jewell
There is no correlation between the letters on your C2 to the numbers that are now used on newer spreader models. Your best bet is to do your own test. Measure a 50 x 20 foot area in your lawn. Place enough material in your hopper to cover 1000 sq ft. Set your spreader setting on a ¼ of your spreader setting range. Spread the material over the 50 x 20 foot area. If you have product left over you increase your spreader setting. If you come up short you decrease your spreader setting. While this is not exact it will give you the ballpark setting
Aug 03, 2010 | Scotts Company Garden
I have an old Jackson 36HSS-26 lawn spreader. What setting should I use for various materials? I am about to spread some Scotts Turf Builder with Plus 2 weed control.
It should say on the back of the box or give some indication as to the settings but in general you can gague it from the flow rate and or the granual size but a rough setting is about 5 to 6
Jul 12, 2010 | Jackson 24" Pulltype Lawn Spreader Model...
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Apr 29, 2010 | Scotts Company Scott'S& Lawn Pro Spreader...
Speedy Green Parts
Replacement parts for your model can be found at amazon, click here and take a look: Amazon com scotts lawn parts. I hope this was helpful. Cheers
Mar 18, 2010 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
How to use Spreaders
Follow the specific spreading instructions that come with your spreader. When working with spreaders, always load a spreader on a surface where an accidental spill can be cleaned up and won't matter (driveway, walkway, etc). Common practice is to first run the spreader around the periphery of the area you are treating; this ensures a consistent application around the edge of your lawn. Next, you run the spreader back and forth within the area bounded by your first perimeter run. Always allow on overlap to avoid missed streaks or "holidays". Ideally, apply your material at half the recommended rate and make two sets of runs, first back and forth in one direction, then again another set of runs at 90 degrees to the first set. This ensures a good consistent coverage and it compensates for any uneven patches.
Aug 27, 2008 | Scotts Company Scotts& Accugreeen 3000...
Garden Logo
63 people viewed this question
Top Sears Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
Dennis Key
Dennis Key
Are you a Sears Garden Expert? Answer questions, earn points and help others
