Question about Toro Garden
What transmisiion fluid does a toro 268 hydro take? the reservoir is low.
2 Suggested Answers
  • 8 Answers
SOURCE: my toro hydro was rideing fine now having problems going up hills it moveing really slow noticed the resivor was over flowing when i started to cut grass the level was fine it drives in forward and r
It may have goten over heated. causeing some scoring in the cylenders. Notice if it uses engine oil or not.
Posted on Jun 12, 2012
I need a manual for toro wheel horse 268 hydro model 72107 serial no.210000417
Go to TORO.com and look for manuals. They are available for download
Jan 23, 2017 | Toro Garden
Not getting gas to carb. changed fuel pump, bypassed filter. hold gas line below tank and fuel comes out. but not being sucked through pump it appears. help
It has a pressure differential fuel pump, just put a little fuel in the carb. and it should start it may stall but do it 1 more time and then it will stay running as it uses the crank pressure to actuate the fuel pump
May 08, 2015 | Toro Garden
How to check hydraulics on toro timecutter z480
check the fliud level and chang filter and hydro fluid this might let it start working again if dont look at buy new hydrstatic pump about 200 hundred dollars pump goes bad if oil is dirty or if low on fluid
Aug 25, 2014 | Garden
Time cutter hydro does not move but i can hear it whine
Did you check the could have air in the system, did you check the hydro oil level? In my experience with toro hydro systems is when i change the oil air gets in the system. At low rpm move control handles forward and reverse several times until air works itself out. if this doesn't work more than likely there could be internal pump problems.
Sep 02, 2013 | Toro Riding Lawn Mower. TimeCutter SS4235...
Hydro wont move on toro timecutter z4200 2010 model i can hear them whine but wont move
sorry to say your pump has gone out or there no fluid in it ether way your going buy a new pump
Sep 02, 2013 | Toro Garden
My toro zero turn radius mower will not go into gear
make sure you have hydro fluid in it and that you hydro is not locked out check release wires at back to make sure they didn't get moved and also make sure your belt didn't come off hydro pump
Nov 10, 2012 | Garden
Hydro pump reserve blowing out fluid on Toro z- master
is this all after the parts where changed and while bleeding out the air put the system under vacuum
May 13, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Hydraulic lift will pump up about 1/3 of intended height. At that point pedal feels soft and lift won't rise more.
What are you talking about, the bike or the bike lift?
If your hydraulic bike lift is doing what you say, it is low on hydraulic fluid, check the reservoir. HINT: The reservoir is the housing where the shiny bar extends out from; there will be a fitting on it that can be removed to check hydro levels. HINT: Before you remove that fitting, MAKE SURE THE LIFT IS ALL THE WAY DOWN; if you try this with it up, you will spray hydro fluid everywhere.
Jan 21, 2010 | 2004 Harley Davidson FLHTC - FLHTCI...
How do you add transmisiion fluid?
You should be able to add the fluid straight from the engine bay.. there should be a reservoir
Aug 17, 2009 | 1997 Volkswagen Passat
Garden Logo
67 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
