Question about Health & Beauty
I took the blade assembly unit apart to clean and got distracted by grandson, now I cant remember how to put it back together again. Model PCMC-2 Wahl animal clipper
SOURCE: wahl clippers
Contact a scisor sharpener in your area. They usually do clipper blades as well ..
Posted on Oct 09, 2007
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
  • 3 Answers
SOURCE: I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Posted on Jun 20, 2009
SOURCE: Need advice on how to sharpen Wahl animal clippers
try getting they sharpened but this time when you use them oil between the two blades before during and after use. oil will maintain the useful life of blades.
Posted on Sep 06, 2009
philschneide
  • 448 Answers
SOURCE: CHANGING BLADES
There is a small gun-metal colored bar (dark gray or black) at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Hope this helps you.
Posted on Apr 09, 2010
How do i put the lid back together on a moulinex serie f30 after taking it apart for cleaning
One shouldn't take things apart if one cannot re-assemble them :D
Take it to your local vac shop.
Oct 29, 2014 | Vacuums
Putting a wahl 9307 back together
You will notice there is a little hook that the spring thing fits into on the device. You want the smaller part of the spring facing upwards and it should tuck in smoothly.
This is the smaller part of the spring facing upwards:
Then it gets tucked in as such:
Take note from the above photo that the square edges on the plastic piece go at the top of the blade piece and the rounded edges are at the bottom.
Then the bottom blade piece rests on top with the curvature facing upwards: putting-wahl-9307-back-together-g0fa4lo4hxabacpjggd4qk4j-2-5.jpg
The rest should be straightforward!
Jul 10, 2014 | Wahl 9307
I took the bladeoff to oil and now can't remember how to get it back together.
i needed to replace my blade - my husband replaced it but it would not cut so we took it apart and cant figure out how to put it back together. nothing helpful on line.
did anyone have a link how to put all the pieces back together to create the blade? thanks
Jan 16, 2011 | Oster 76076-010 Hair Trimmer
I can't find the manual of my Conair GMT 170X. I took the blades apart to clean and lube and now I don't know how to put the spring assembly back together with the blade. Please help
their is 2 long wires with a l shaped hook on the the smalles blade that goes on the bottom the points of those wires go in the holes in the bottom of it which is a white thing with 2 groves in it make sure the blade is facing away from where the screws go the take the plastic pad and put it in the 2 holes of the top blad the set it on their facing the same direction the push down till its flush the put the 2 screws back in
Dec 17, 2010 | Conair GMT 170 CS Beard Trimmer
Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
May 20, 2009 | Conair GMT200TD
Cannot put blade assembly back together
Sounds strange, since I don't think that the HQ5 heads in the shaver have the pointy parts that other shaver heads have. If your comb has 2 pointy edges, make sure they are located correctly in the head housing - they will need to be located inwards, with the the spindle that the retaining bracket attaches to in the center of the the two pointy parts.
But apart from placing the combs in first, locating the cutters in then putting the retaining bracket in (which may be broken if it won't fasten properly) I'm not sure what you can do, other than calling your local Philips Service Centre,
Apr 07, 2009 | Norelco Reflex Shaver 5885XL Electric...
Took unit apart to clean and need reassembly diagram please
the thick racket sit on top of the lil gold bracket
Dec 02, 2008 | Wahl 8550
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
