Question about Philips HTS5580W Theater System
Trying to figure out the placement of the speakers. In the menu it asks for distance for each speaker...ie 3 ft, 10 ft, etc. Is the distance from the tv/blu ray player?
  • 10,594 Answers
The distance from your seat/ sitting area.
Thanks.
Posted on Apr 10, 2011
Just bought the mixer and cant figure out how to get sound to the main speakers, i have the apms correctly hooked up and speakers also
Since you posted this question nearly 3 weeks ago, I expect you figured it out by now - in which case, please mark thread as "closed".
If you are still trying to figure it out, please reply with the following information:
1. Make and model of mixer
2. What you are using as a signal source (mic, instrument, etc.)
3. Make and model of your speakers (important if they are self-powered, or not)
We'll take it from there - but a couple pictures will answer a lot of questions in regard to gain structure, signal path routing, buss outs, etc.
May 21, 2016 | Music
What is a good placement for the 901 series VI speakers? I've heard the backwall is half the distance to the sidewall
Depends on the shape and contents of the room. Look up "best acoustic placement of speakers" in your web browser. Good Luck!
Nov 14, 2014 | Bose 901 VI Main / Stereo Speaker
What gauge speaker wire use for yamaha R-v905 Receiver
The usual gauges range from 18 to 16 with one limiting factor being the ability of the receiver and speaker terminals to handle larger gauge wire
Jan 28, 2013 | Yamaha R-V905 Receiver
What type of cable do i need to hook up my speakers and if i need an amplifier too and what kind or type? theater research TR 2810
A strand copper cable in clean condition, a guage from 10-16AWG will suffice. Choose a solid state amplifier with a high damping factor, preferably no less than 100 and able to operate with low distortion with up to 100 watt loads.
I see that these have a side firing driver so keep in mind there placement distance from side walls; going too close may give a bloomy or boomy sound.
Apr 24, 2011 | Theater Research TR-2810 Main / Stereo...
My onkyo reciever working very well but last 2 days subwoofer out put off from receiver .... subwoofer is ok
Hi, If you have remote to receiver try hitting the speaker setup selection. I am thinking perhaps a speaker setting was inadvertantly taqmpered with. In speaker settings you will have such things as distance setting-speaker size-delay etc..then you should come to a selection for whether or not a subwoofer is used ie: subwoofer : on, off.. I hope this has been of some use and thank you for choosing FixYa,Good luck, Prodzilla
Apr 13, 2011 | Onkyo Audio Players & Recorders
What is the best locxation for 901 series v1
Optimal placement of these like speakers of any design will vary depending on room dimensions and your listening distance from them.
A good place to start with them would be the same distance apart from each speaker as they are from the listening position. In that position they should also be placed closer to a rear wall than any side wall, approximately half that distance.
Dec 10, 2010 | Bose 901 VI Main / Stereo Speaker
What is the 20/40 degree listening position narrow or wide?
johnledon1,
You can compare this the 45 and 60 degree listening positions for surround sound but it means just what you said, 20 degrees for a narrow field and 40 for a wider field. Just remember to listen to what your ears are thinking and not others are telling you as your ears cannot be wrong to you.
45 Degrees:
The speakers are half the distance apart from each other as they are from the listening position; i.e-10 ft apart but 20 ft away.
60 Degrees:
The speakers are the same distance apart from each other as they are from the listening position; 10 ft apart but 10 ft away.
In surround sound, the higher the budget film, the higher field degree is optimum but never more than 60 degrees where you can easily go down to about 25 degrees.
For music most people like a narrower field unless you like groups like Pink Floyd where sometimes they will sound better in a wider field.
-Chris
Sep 08, 2010 | Onkyo Audio Players & Recorders
Sony STR 1200 audio-visual sync
Yes it can be fixed.
Enter the speaker setup menu and toggle till you get to the selection for speaker distance. Assuming that you have your speakers properly positioned for correct reproduction of 5.1 surround sound, decreasing the setting for speaker distance will help. Start with 3-4 feet closer from the current setting. This enables the on board DSP (digital signal processor) to delay in milliseconds, the sound output for closer distance settings. It can also advance in milliseconds as well for further distance settings FYI.
Mar 24, 2010 | Sony STR-DA1000ES Receiver
Yamaha HTR-5840 best eq setting to start or use as base line
there are many settings 1.distance (This is the distance between you and the speakers) if your sitting say 6 ft away then you set it to 6 and so on (all front speakers should be lined up the same distance from you) The rear speakers are set up the same way (distance from where you are sitting) then 2. small and large (always pick large for best sounf)3.Tone (this is more a matter of choice) play around a bit with it! the sub should be at least one foot from the wall for best sound! I keep my center chanek a little lower then the other channels for best sound !
Dec 18, 2008 | Yamaha HTR-5840 Receiver
Philips HTS5580W Theater System Logo
50 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
