Question about Encore Software The Entente: WWI Battlefields for Windows
Hi i start to play the game and i only get like three clicks in to build units and the game locks up and kicks me out any help would be greatly appreciated
  • 4 more comments
  • chuckfore64 Apr 10, 2011
    i am using windows xp, and yes the game crashes and gives and error message of antanta.exe encountered problems and had to close. I just try to play the british campaign mode and get maybe 60 seconds of game time before it happens
    and yes i have tried to reinstall it, i thought i might have to download a patch but just not sure
    yes i completely uninstalled it and reinstalled it and the same thing happened
    so i tried downloading patch1.3 and when i go to run/install the patch it says the game is not installed could you maybe help me out with how to install a patch?
    when i start up the game it says v1.3
    i did see there was a v1.3b patch if that will help at all
  • 2,632 Answers
Welcome to Fixya. May I know th Operating system of your computer, Do you have an error message when it happens, what you do you mean that the game locks and kicks you? Do you mean that the game crashes? Did you tried to reinstall the game?
Please provide the information needed to be able to provide a fix on your problem
Thanks
Posted on Apr 10, 2011
  • 2 more comments
  • Rofel Lantican
    Rofel Lantican Apr 10, 2011
    Hi - did you tried to resintall the game and see if you still have the same problem?
  • Rofel Lantican
    If happening when opening a program that is not part of Microsoft Windows, make sure you're running the latest version of the program and that any patches for the program have been downloaded. The latest software updates can be found either through the developers website.
    Yes you need to download the patch for this one to fix the problem
  • Rofel Lantican
    what is the version of the game that is currently installed?
  • Rofel Lantican
    You can try to check the link below for the fix if it will works
    WWI: Battlefield Game Fix
    Thanks
I can put the cd in and it plays great. but when I'm playing games there is no sound on the computer
hi, check in game setting when u started ur game check sound setting that its on, in option or setting .
Nov 16, 2011 | Microsoft Windows XP Professional
I installed Dead Man's Hand for my XP. It installed perfectly, no problems, no holdups, everything was going smoothly. When I clicked on the icon on my desktop to play the game, my computer gave a small...
Hi. you install the game ok. You need direct x and netframework [last]. and try to reinstall the game. Go to properties and search compatibility mode and now try to change . First put on xp sp3 apply and try to play. if the game not start change on win7 compatibily. Appy and try to play a game. If is do same noting your pc is downgrade for this game. Cheers.
Jun 12, 2017 | Atari Dead Man's Hand for Windows
I have a Maytag top-freezer refrigerator model RTT1900DAE. The fridge works great. I've placed a memory thermometer in there and the low/high temps are normal. The freezer on the other hand doesn't stay...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 15, 2011 | Refrigerators
My Xbox 360 makes a loud humming noise while i play
The Xbox 360 does not like to be moved when playing a disk some of the mechanics may have misaligned or slightly out of sync this may be reason the DVD drive is making those sounds.
I strongly recommend you remove any visible dust from the 360 especially the sides and air vent holes using a vacuum cleaner. Once youve cleaned it place it horizontal (never on carpet) on a flat surface well ventilated away from other devices that generate a lot of heat.
As for the 'shredding sound', place in **** game into the 360 when it starts to make those sounds again gently tap the 360 on top (where the DVD drive is) until it stops making that sound. This doesnt always work but has for me and many others.
My experience tells me that dust can build up not only inside the 360 but also the drive itself which can lead disc read errors and the sounds and you mentioned.
Remember DUST and HEAT is the 360's biggest enemy and can cause RROD, 1 Red Light Problem, and disk errors.
Hope this helps..good luck!
Jul 27, 2009 | Microsoft Xbox 360 Console
VERY hard starting takes way to many kicks usually play out befo
There is a proper way to start the engine. Four controls are on your bike to assist in starting.
  • The choke, used when the engine is cold. Pull the red knob for choke.
  • The " Hot Start " Lever, used when the engine is hot. Pull the lever to lean the fuel mix when the engine has been running.
  • The de-compression lever, always used.
  • The throttle, used to prime the cylinder.
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. Give a strong kick through the full sweep of the kickstart lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from a backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), until the bike starts. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting.
Top rating for this answer? Thanks!
Jun 11, 2009 | 2003 Yamaha YZ 250 F
Cant start regular season
you cannot play the game online now because you are once registered with your username
you need to play offline. it will only allow you to play regular season.
May 11, 2009 | Sony Playstation 3 (PS3) Console
I keep getting kicked off line during game play:server connection error. i wiil start out with a strong signal then i get kicked off, sometimes i get get thrown out of playstation network:an error occured...
one your internet speed could be to slow for the online server to work, two the playstaion 3 scart lead maybe loose belive me it happened to mine i out the scart in properly and it worked, three your internet plug may be loose, try phoning playstation and ask for help if any of these dnt work.
Jul 04, 2008 | Sony Playstation 3 (PS3) Console
Common Problem or Bad merchandise?
This could be something as simple as not enough room on the hard drive from old game saves. I have seen systems lock up when they run out of room on the hard drive just like a computer will.
This would be the first thing I did to see if I could alleviate the issue. Get into the Xbox without any game in the drive, then find the games saves manager and start cleaning up old saves that you don't need and see if this helps any.
Dec 12, 2007 | Microsoft Xbox Console
Encore Software The Entente: WWI Battlefields for Windows Logo
305 people viewed this question
Top Encore Software Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Are you an Encore Software Video Game Console and Game Expert? Answer questions, earn points and help others
