Question about GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore regrigerator Top half of freezer does not freeze. Refrigerator does not get cool. Bottom half freezer works fine.
  • Anonymous Mar 14, 2014
    Top half not cooling bottom fine
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Posted on Aug 07, 2008
Refrigerator top works fine, bottom not freezing
If the freezer is not working then the fridge can not be keeping cool there is only 1 compressor I would call a service tech as it probably needs freon added and soon.
Jan 29, 2015 | Kenmore Refrigerators
My kenmore fridge is not working, the freezer works fine but the bottom will not cool. the fan is working but not blowing out air in the bottom
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Jun 30, 2011 | Kenmore 64802 Top Freezer Refrigerator
I have a Kenmore bottom freezer model 596.75934401. The refrigerator top has stopped cooling while the bottom freezer is working but showing some accumulation of icing. I have unplugged the regrigerator,...
There are a couple possibilities. You need to make sure the evaporator fan in the freezer is working, it circulates the cool air to the top. More likely your coil in the freezer is iced up due to defrost part failure, either the timer or the heater assembly. The back panel is going to have to come off. If you defrost the coil completely, the unit will work again until it ices up again. You have to have the defrost system diagnosed and the defective part replaced
Jun 25, 2011 | Kenmore Refrigerators
Top shelf of both regrigerator and freezer not working
i have a side by side refrigerator is all ice bihind the cover evaporator
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
132 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
