Question about Samsung RB195ABPN (187 cu ft) Bottom Freezer French Door Refrigerator
Samsung R195 fridge falshing led after power outage.Tried repalcing the display panel ,no control of temp but fridge still runs fine.
tborn6
  • 700 Answers
SOURCE: SENSOR PROBLEM ON SAMASUNG SRS580DW (side by side fridge)
go ahead and take and hold in the top two button until the unit blinks and resets the controller. Please don't rate this unitl the problem is solved because i can't come back and answer any more questions then. Also if this fix's please rate this solution please. Thanks for usin FixYa
Posted on Jan 01, 2009
bobotfel
  • 236 Answers
SOURCE: fridge is in lock mode
Please press the white wine key and interior lamp button together for 3 seconds.
Posted on Jan 09, 2008
La_C
SOURCE: fridge temp display flashing
Is the evap fan running? What is the current temp and how long has the unit been in operation
Posted on Dec 29, 2008
  • 7 Answers
SOURCE: RS267lash samsung refrig. display panel fridge
Sounds like the fan unit is faouling with ice. The solution is to remove the whole of the contents and then the units inside at the rear. Defrost same and re assemble. Its not that hard if you remove the light difuser first and the two screws. Mark the difuser for top. Then ease out the unit and remove after taking out the electrical connections. They fit only one way. The lower unit has four screws. Two under covers. Easy to unclip. The ice seal may mean that it is not that easy to remove. Defrost both the units with a hairdryer or similar and clear insulation from the fan drain. Re assemble when clear and as dry as you can. The problem will come back so be aware that you have to repeat the procedure when the fan gives signs of fouling. Paul.
Posted on Jul 11, 2010
  • 117 Answers
SOURCE: My samsung SRS20NTD fridge/freezer LED
have alook at this samsung fridge freezer channel on youtube
some good stuff re common samsung fridge freezer faults ">
Posted on Dec 02, 2010
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
How do you get compressor running after power outage?
Hello AnnArborMom, thank you for your inquiry!
I would recommend you adjusting the temperature to a lower setting to see if that would start your compressor to cool. If that is not successful I would contact a professional to come and properly diagnose your appliance. It could be that the power outage shorted the main control board or relay. I hope this is helpful. -Matt
Sep 07, 2014 | Frigidaire FGHF2366PF Gallery 22.6 Cu. Ft....
We have a Samsung RS265TDWP side by side refrigerator. After multiple power outages last night in storms, I discovered this morning the temp on the fridge is 53. I have tried unplugging to reset. Did...
Being a newer fridge I would look at the control board being faulty. They do not Handel porters surges very well and you may have blown a relay or resistor on the board. I would install a surge protector on anything you own with electronics in the future.
Sep 08, 2012 | Samsung SRS20DTD Side by Side Refrigerator
Our power went out due to the snow storm, and the display panel shows 88 on each side...how do I reset this...will this cause the fridge temp to go up?
From http://www.samsung.com/us/support/supportMain.do
Your refrigerator is equipped with an onboard diagnostic system. If the diagnostic system detects a fault, it will display a specific line segment on you refrigerators LED display. If your refrigerator is displaying an error code, please note the error code, and reset the refrigerator by unplugging the refrigerator for 30 seconds. When the refrigerator is plugged in, it performs a self diagnostic check of the various sensors and functions. If the error code reappears your refrigerator will require service. Please click the "Create Online Service Request" button below this article to initiate the service process. After a power outage the display panel may start blinking "88 88." If you unplug the unit for 30 seconds then plug it back in the display will return to normal operation after several hours. The power outage/surge can cause a communication error between the circuit boards in the unit. It can take several hours for these boards to stabilize.
If the display does not reset, go to the Samsung Support link above, enter your model number, and follow the prompts to request a service ticket.
Good luck, and if this helps, please rate my answer!
Feb 02, 2011 | Samsung Refrigerators
Control panal is not working.
Hold Energy Saving & Lighting buttons simultaneously for 10 seconds! Panel dispaly resets.
Mar 31, 2010 | Samsung RF265AA Bottom Freezer French Door...
We have a samsung american side by side fridge freezer, we had a power cut and when the power went back on the light in the fridge was flashing and making a clicking noise.also the panel on the outer door...
Check your owner's manual. There may be a "reset process" that you can perform in order to restore the refrigerator properly after a power outage. Otherwise, there may be an issue with the "main electronic control board". If this is the case, contact an appliance service company. If within warranty, contact Samsung!
Feb 15, 2010 | Samsung 26.0 Cu. Ft. Side-by-Side...
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Samsung french door fridge not working?
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
Oct 14, 2007 | Samsung RM255LASH Side by Side...
Samsung RB195ABPN (187 cu ft) Bottom Freezer French Door Refrigerator Logo
37 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
