My amana top load washer model #DLW330RAW will not agitate. and is leaking water. how do I remove the agitator?
aborcass
  • 2651 Answers
SOURCE: amana washer
PULL,PULL. turn your head and pull!!!!!!!!!, your also gonna need some adhesive for that seal kit silicone wont work
Posted on Feb 25, 2008
  • 1028 Answers
SOURCE: Kenmore 80 Series Top Load Washer not agitating
if it will pump out ckd motor to gearcase coupling probably broke
Posted on Sep 03, 2008
huuum
  • 750 Answers
SOURCE: GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Posted on Oct 04, 2008
reg501
  • 413 Answers
SOURCE: Remove the agitator
The agitator is actually pressed on without mechanical fasteners . Grab the bottom of the agitator firmly on each side. Pull up with a quick, hard **** (careful not to hit your face). If this does not work, wrap a belt under the agitator. Grab the belt firmly and pull up with a quick, hard ****.
Posted on Dec 25, 2008
  • 84 Answers
SOURCE: Amana washer won't agitate when full with laundry
The belt is probably worn down. Replace it.
Posted on Jan 17, 2010
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
How do you remove the agitator on amana washer model lwa30aw
Unplug the Amana washing machine from the wall outlet, and open the lid. Pull the liquid fabric softener dispenser straight off of the top of the agitator. Some Maytag washers require the use of a flat head screwdriver inserted between the dispenser and the top of the agitator. Twist the handle of the screwdriver to pop the dispenser off of the agitator.
Remove the barrier cap inside the agitator using your hands. Pull the barrier cap straight out of the agitator. There is an O-ring that attaches to the outside of the barrier cap. If it did not come out with the cap, pull the O-ring out of the center of the agitator.
Remove the bolt securing the agitator to the drive bell with the socket wrench. The bolt is inside the center of the agitator.
Place your fingers in between the bottom of the agitator and the tub. Lift straight up to remove the agitator from the tub. Keep your head out of the way in case the agitator is stuck and unexpectedly releases. If necessary, use agitator hooks. Insert them under the agitator and push down on the hooks to release the agitator.
Aug 06, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Will spin but not agitate LWA40Aw2
Hi, it sound likes a belt. Some amana washers take 2 belts,1 for the spin,and 1 for the agitate. or some models spin rite of motor,and a belt for agitate. hope this helps. :)
Jul 07, 2009 | Amana ALW895 Top Load Washer
Ihave an Amana washer model DLWRAW. Ithas a
not a good number go to whirlpool parts surplus dot com and ask for mark i can get you going on that with a great price shipping is only 4.95
Jun 25, 2009 | Amana DLW330RA Top Load Washer
Does not agitate with large load
have same problem but mine take large and small loads and leaks
you need part #ap4253876 made by whirlpool
Feb 28, 2009 | Amana ALW480DA Top Load Washer
I need to remove the agitator from my washing machine.
On most Amana washers you pull on the agitator with brute force. It "snaps" on. It helps if you fill the washer with hot water and let it set for a few minutes... drain and then try pulling it out. When i last took apart my Amana it took me and a friend to pull the agitator off.
Nov 22, 2008 | Amana NAV2335A Top Load Washer
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
