Question about Sharp Televison & Video
My tv lost picture and show only green screen although sound works
    Novelist:
  • 159 Answers
Hi, what you have is called hte "default " screen, the audio connection is apperebtly fine since you have sound, so the question is why video stopped. More than likely the video connection came loose somewhere, iI suggest retracing the " video connection " from end to end. If you're using an hdmi cable that has both audio and video cables combined-so it would be the cable or the player or jack on the tv's side that was defectice. if using standard " RCA " cables, those are the colors yellow, for video and red & white for audio. If someone or something become tangled in rca cables this may sometimes stress a connection and give a green screen ( with yellow cable still connected it will feel slightly loose ) I hope this helps ,good luck Prodzilla
Posted on Apr 10, 2011
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
Lg flat screen shows solid green but no picture
Theres a great possibility
that your Power supply unit has problems
Although the fact that somehow turns on
tells us that you may find some bad capacitors and maybe replacing them might fix your problem
Jul 02, 2014 | LG Televison & Video
Television screen is green
Is the picture in a green shade or the whole screen is simply green?
if the second one is currect - the connection to the video source is lost. some tv do a blue or a green screen in order to prevent that anoying sound that the old tv used to make.
try to reconnet your source (PC or a DVD player, whatever you can).
if it works on other devices - your device is probably damaged.
Jun 10, 2012 | Sony KP-53HS30 53" Rear Projection...
Why does my tv have one blue, one red and one green line at the top of the screen but no picture?
The CRT inside the TV has gone bad. You can either find the make and model of the CRT and replace it, or get rid of the tv and buy another one.
Jun 08, 2012 | Televison & Video
Have a Toshiba TV model Mv13M3. All of a sudden it turned off, with no sound and no picture and the word "line" in green on the upper rightn hand corner of the screen. Any suggestions?
Although I did not manage to find the manual for this combo set, to check it fully, it seems that maybe someone pressed the remote button marked "Input Selection" that selects each one of the audio/video inputs of the set.
Press it two or three times and check if it cycles the inputs till a TV channel shows on the screen.
Hope this info can help you!
Mar 12, 2011 | Toshiba MV13M3 / MV13M3W 13 in. TV/VCR...
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
I have no picture, only green screen and audio when I turn on
i have no picture the sceen is green but i have sound can u help thanks.
Jun 06, 2009 | Polaroid FLM-2011 Television
Screen not showing picture
Check and make sure you are on tv not video. Unplug and replug all the game systems or other things you might have plugged in your tv. And if those don't work make sure you are not on input channels (input1, input 2, and do on). If still you are having problems go to the tv menu and and make sure you are on antenna if you have a antenna or cable or satilite if you are on one of those. I hope this helps!
Apr 11, 2006 | Thomson AQUA14 TV
Televison & Video Logo
150 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
