Question about Panasonic SC-PM39D System
My cd/dvd button not responding saying tray init please wait
5 Suggested Answers
furion187
  • 54 Answers
SOURCE: dvd tray will not open
Sounds like it's jammed it self up, if you got finger nails try pulling the front on the dvd drive as you push the open button, otherwise look for a little tool of some sort to wedge in the front of the dvd drive to give it alittle movement as you press the open button, it may need a bit, just be careful not to break it lol , if still no luck unscrew the sides and back if it has screws at the back , lift the top off , and push the dvd drive from in there , that will atleast get the disk out, and lets hope solve future problems ,
Posted on Nov 25, 2007
  • 4 Answers
SOURCE: disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Posted on Dec 31, 2007
  • 4 Answers
SOURCE: init please wait
I've just spent the last 3 nights trying to fix that same issue with my sa-ht670 player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
seeyouatthetop06@gmail.com
Posted on Apr 14, 2008
Ironfist109
  • 3018 Answers
SOURCE: My system says INIT please
  • First you to pull out the DVD tray assembly and check to make sure there is not anything that has broke inside there. Make sure nothing is blocking the trays from moving.
  • Now pull the side cover off. There is a spare gear on the top of the DVD tray assembly. You will take that and place it in the two holes at the bottom of the player. This will allow you to manually adjust the trays. If you don't have this gear you can align the tray manually but it has to be real perfect.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jul 26, 2011
When I turn on my Sony DVP-SR200P DVD player and press the eject button it's turns the DVD player off.
turn on first the dvd player and wait to read a disc inside if no disc inside the tray it will say disc error. if the unit doesn't turn off, eject now the the cd tray. if get turn off, remove the cover then check for an stuck up gear or obstruction in the cd tray assembly. you can check also the power supply board which may have unusual parts like bulged or burnt component parts.
Oct 06, 2012 | Televison & Video
Dvd tray will not open
Nov 25, 2007 | Panasonic 600W DVD+VCR Home Theater System...
My system says INIT please wait and the cd/ dvd trays are out of line i tinkle a little with electronics and feel that if i knew a little more about this problem I can fix it myself,especially due to high...
Regards, Tony
Jul 26, 2011 | Panasonic SC-HT670 System
Hey! when i put dvd/cd saids me tray init please wait and i dont know what to do mi cds are inside of te estereo!
Most drives have a tiny hole above the drawer. You need to straighten out a paper clip ,then poke it into the hole. This should release the drawer catch and you can open it by gently pulling. It may be jammed as a disk was not properly seated inside.
May 07, 2011 | Panasonic SC-PM39D System
My DVD-ROM tray opens only after many tries.
As per your information you done all the basic work. Hope you use little bit of oil drop in the side of the tray. If not then try that .If no success then there is a small spring available for tray in and out function. You have to change that spring from a service center or if possible then at home.
Thanks and waiting for your reply.
Feb 04, 2010 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Panasonic SA-HT680 Home theater problem
Try these steps to reset the unit. I got these from the Panasonic Cust. Service # 1800-211-7262
1. Unplug the unit power.
2. Wait 2-3 mins before replugging the unit.
3. Turn it on.
4. If the display shows INIT / PLEASE WAIT, Press and HOLD the Tune Mode (STOP) button on the main unit. At the same time press #10 (Channel button) in the remote control. They have to be pressed & held simultaneously for atleast 5 seconds. Wait till the INIT / Please Wait display disappears.
5. Once the message disappears, RESTART the main unit by pressing the POWER button OFF / ON.
6. If it does not work, try several times. If it does not work, contact a local repair shop (call them to find out a repair shop near you). If the repair shop wont do it for you, call them back - thats what they told me.
Jan 19, 2008 | Panasonic SC-HT680 System
Unit says Init Please Wait
I've just spent the last 3 nights trying to fix that same issue with my player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
Oct 31, 2007 | Panasonic SC-HT670 System
Panasonic SC-HT670
Sep 24, 2007 | Panasonic SC-HT670 System
Init please wait
Sep 01, 2007 | Panasonic SC-HT670 System
Panasonic SC-PM39D System Logo
349 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
