Question about Nspire AS-800B-NO Full Tower Case
I cannot open DVD door. I am not sure what model my tower is and I cannot find manuel
    Master:
  • 451 Answers
If you open the side panels there should be clips on teh side that hold the front bezel/panel to the case.
push in those clips adn the front should come off.
you should be able to access the dvd bay/tray and see what is the problem maybe a spring came loose or clip.
Posted on Apr 10, 2011
  • 374 Answers
If the door on your CD/DVD drive will not open when you push the eject button (on the front of the drive), Click on Start, My Computer, and Right Click on your CD/DVD drive. Then Click on Eject. If the door still refuses to open, you can insert a paper clip into the small hole on the faceplate of the drive and push it in until the door opens. If the door continues to refuse to open in the normal manner, you will have to replace the drive,
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
HOW DO YOU PROGRAM THE CAR HOMELINK REMOTE FOR A NEW ASSURELINK GARAGE DOOR OPENER.
refer to each cars owners manual on the procedure to follow each process may be different than the other. Make sure the allure opener has the correct presets made refer to manual.
make sure overhead door is in the closed position to begin process
Oct 08, 2014 | Building Materials
DVD door will not open to eject DVD
There could be 2 reasons, 1. Hardware issue 2. Software drivers:
Fixing 1: Hardware
Make sure the DVD is fixed properly in your tower ( I am not sure whether you are using a tower or lappi)
The direct solution is to put a pin i the small hole present on your DVD player. That should open the DVD door.
To fix the software part.
>> Try to update the drivers depending on the operating system you are using.
>> Download the latest drivers to check if it fix the issue.
>> Open the My computer >> Right click on the CD/DVD drive and select Eject, this will normally open the door.
Else, try to uninstall the drivers from Device Manager and then restart the PC once, this will reinstall the drivers once again by its own if your Windows is up to date.
Please do get back to us, if that does'nt fix.
Jan 18, 2014 | Zenith XBV243 DVD Player/VCR
Have EMachine tower door will not open to install DVD
You can use a paperclip to open it.
On the front of the DVD you'll see a little pinhole; unrwist a paperclip and push the leg of the paperclip into that hole; it will manually push open the DVD tray
Nov 07, 2013 | HP Compaq Presario SR1650NX...
I am having problems inserting a dvd into my acer laptop tower.I was opened up the side where it says dvd but it doesn't seem to fit in!
A) What is a laptop tower?
B) What is the model number of the Desktop PC?
This can be found on the back, near the Windows product key; or up on the side of the computer tower.
Is it an Acer?
Just pulling your leg about the laptop tower thing. I can see you meant Desktop, and not Laptop.
Just want to make sure you're not referring to an Acer laptop, while posting about a desktop computer made by somebody else.
Post back in a Comment.
I will try to find the User Manual for you, and take a look at this little beastie myself.
Regards,
joecoolvette
(Kicking rubber 'feet'................Hmmm, it's got good tread.
Looking down side of case............no, no bondo.........looks straight.
Yep,...............had oil changes at regular intervals..............there's the 3,000 minute WD-40 sticker...........
................oh, and Computerfax gives it a good report..........
WAIT a minute,..............what were we talking about? !O_O! ]
Mar 03, 2013 | Acer Computers & Internet
I have a DVD door that won't open. I tried to
Unless I am mistaken there will be a little hole on the door (or near it). That is the manual eject, use a pin or a paper clip to press the button inside.
Feb 12, 2010 | Gateway (5502134) CD-RW/DVD-ROM (Combo)...
My cd compartment won't open.
You can manually open the door using a straightened paper clip inserted into a small hole in the door. Press firmly and the door will be released. You may have a CD stuck in there, or you may need to reinstall the driver for the CD. Or the CD drive may have failed...at least the control part that opens and closes the door.
Nov 12, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
2001 saab 9-3 fuel door will not open
May sound a little stupid im just trying to cover all bases but have you made sure the car is unlocked. If the car is locked then the fuel door will be locked.
Apr 26, 2009 | 2001 Saab 9-3
I have a Gateway 300x Micro-Tower case circa 2002 and I can not open the case, without breaking it. I'm trying to install a new audio card and can't get at the 300x innards. Help!
Most of these towers are vertical style, therefore the big button is just to the left of the Gateway symbol. Push it in and pull the left panel away from the case.
Jan 11, 2009 | Computers & Internet
Craftmans remote garage door opener does not work
Most likely the battery is dying and needs to be replaced.
You can open the rear cover and replace it, they should have the battery you need at wall greens!
Once the cover is off make sure the switchs matches those of the Garage door sensor itself other wise it will not open.
It should tell you how to do this in the manuel that came with the unit.
If this does not work call tech support at the 800 number provided to you in the manuel and they will walk you through it. Most likely you bought this from Sears, craftsman is a Sears product.
Sep 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Nspire AS-800B-NO Full Tower Case Logo
159 people viewed this question
Top Nspire Computers & Internet Experts
David Payne
David Payne
Are you a Nspire Computer and Internet Expert? Answer questions, earn points and help others
