Question about RIM BlackBerry Curve 8520 Smartphone
552 error - RIM BlackBerry Curve 8520 Smartphone
    Scholar:
  • 113 Answers
Reload software: 552 or App Error 552, known issue in Blackberry. To resolve, upgrade to the latest available BlackBerry Device Software version provided by your wireless service provider to resolve this issue.
Complete the following steps:
  1. Verify that the BlackBerry® Desktop Manager and the current BlackBerry Device Software (for your BlackBerry smartphone) is installed on the computer.
  2. Remove the battery from the BlackBerry smartphone. Do not re-insert the battery.
  3. Open the BlackBerry Desktop Manager on the computer.
  4. Connect the BlackBerry smartphone to the computer using a USB cable.
  5. On the BlackBerry Desktop Manager main screen, click Application Loader.
  6. In the Update Software area of the Application Loader, click Start.
  7. Click Options. This allows you to add or remove applications from the BlackBerry smartphone.
  8. Select the applications that you want to install.
  9. Click Next.
  10. Click Next.
  11. Click Finish.
  12. When the application load process starts, insert the battery into the BlackBerry smartphone.
    Hope this helps!
Posted on Apr 10, 2011
What is sc 552 error code on a MP6002SP
Dirty fusing thermistor. Clean it, go into tech mode and turn off main power switch to reset it.
Aug 29, 2014 | Ricoh Office Equipment & Supplies
Error code c 145 E ON MINOLTA di 552
Sir/Mam the you have the problem under the Di183 but you have di552 check the 183 no such code Sure it is a Di 552 and code is c145E?
Apr 11, 2014 | Minolta DiALTA Di183 Copier
What do i need to do if my blackberry curve displays a message saying reload software:552?
I have had the "Reload Software: 552" error on 2 BlackBerry Curve 8900s. When it occurred again (last night) this is what I did:
[ WARNING! THIS WORKED FOR ME, BUT I WAS LUCKY & IT MIGHT NOT WORK FOR YOU! ]
1. Reboot your BB: alt-rightShift-del
2. Start a software reload from the Windows desktop, via the BB Desktop Manager.
When the reload started, I would get a screen on my BB showing 2 computers talking to each other. After a few seconds, this would crash into the 552 error.
3. 3-5 seconds into the software reload, CANCEL the desktop.
4. This should freeze the apps on both the desktop and the BB. The BB should still be showing the 2-computers.
If you do anything on the desktop at this point, the BB will crash into the 552 error again.
5. Terminate the desktop app processes via the Windows task manager. There are 4 RIM/BB processes to shut down.
6. At this point, the BB Desktop Manager app should be gone, and the BB should still show the 2-computers.
7. Now, start the BB desktop manager back up again, and intitiate the software reload again ...
A 4thumbs up will be greatly appreciated. Thank you for choosing FixYa!
Jul 04, 2011 | RIM BlackBerry Curve 8520 Smartphone
Codigo sc 552 ricoh 3800
SC 552 - Pressure roller warm-up error
Definition: After the main switch is turned
on or the door is closed, the
pressure roller temperature
does not reach the ready
temperature within 150
seconds during fusing unit
warm-up.
Possible Cause:
• Pressure roller fusing lamp broken
• Defective pressure roller thermistor
• Defective BCU
Troubleshooting Procedure:
1. Check if the pressure roller thermistor
is firmly connected.
2. Replace the fusing unit.
3. Replace the BCU.
Mar 01, 2011 | Ricoh Aficio 3800CMF Laser Printer
Black berry error code 552. White screen with
you need to connect the phone to the computer or laptop that you are using via usb cable and open teh blackberry desktop manager and go to application loader and install the OS you want and it will be up and working great again.
Dec 28, 2009 | AT&T Blackberry Curve 8300 Smartphone
Hie I have a Gestetner DSm615 which is giving me error code SC:552.How do i solved this problem?
Enter SP mode by pressing;
  • Clear (yellow) button
  • 1 0 7
  • Press and hold the Stop (orange) button for 3 seconds.
  • Switch off and on the machine.
If SC 552 (Fusing warm up error) appears again, possible causes are;
  1. Fusing thermistor defective or out of position or dirty with toner
  2. Fusing lamp open, and
  3. Power supply board defective.
Good luck and please rate me, thanks.
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
My BB has an error code: app error 552. what do i do?
If you're having this problem a lot, make sure that you've moved all of your media (ringtones, music, video, pics) to the Media Card. Clear the Cache on your browsers, adjust the memory reserved for pics. That should clean up many of the issues
Try changing the default location for pictures taken. I've set mine to default to the memory card saving a lot of space on the phone to allow for other more important things.
Jun 09, 2008 | AT&T Blackberry Curve 8300 Smartphone
Rpd 552
Chris, It does not have one. I have this model. Right now I'm dealing with error code 05, which is no where in the troubleshooting section of this manual. I think a good cleaning and realignment is in order for my unit. Cheryl
May 05, 2007 | Blaupunkt RPD 552 CD Player
Error displaying 552
Hi ladakh the fuser unit has failed to reach its required temperature there are 3 possible causes 1.the thermister is faulty 2.the heater lamp has blown 3.the power supply is faulty you need an engineer to check and replace any parts
Feb 27, 2007 | Ricoh Aficio 2015 Copier
RIM BlackBerry Curve 8520 Smartphone Logo
495 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
