Question about Microwave Ovens
I ordered a Cabela's super Jerky Blaster. When it arrived the case was broken. I can deal with that by storing the case flat. But, I did not get a manual or any instructions for how the parts fit together or what to take apart to clean. If you could tell me how to download a manual I would really appreciate it. Sherrill Orr email torr@sctelcom.net
How do I replace jvm1490sd broken handle?
Disconnect, open door, remove screws from rear of door, dismantle door. Here's a diagram showing how it fits together.
01 Control Panel Door Grille Case Parts for GE JVM1490SD003
The part you need is #1801 on diagram
Microwave Door Handle
Color: Black. For white order WB15X10070. For bisque order WB15X10071. For the screws order WB01X10305.
by GE
Part Number AP3184331
May 19, 2014 | Microwave Ovens
Sharp Carousel Microwave door won't open, button broke
Take it to a Discount Appliance or Used Appliance store and have them repair it. There they will have the parts that are used and cheaper to repair than hiring an Appliance Service Technician.
Option 2
Take the microwave apart and go to www.searpartsdirect.com and type in your model number and find the broken part and part number. Then order the part through ApplianceZone.com or ApliancePartsPro.com. Later when parts arrive at your door... install theparts yourself and save money!
Mar 27, 2014 | Sharp R-1480 Microwave Oven
Hi, the button to open the door not working properly, I am able to press the button in but it is not releasing the door. what should we do?
This sounds like the door release may have broken (duh!) It may be that a peice of plastic has broken or maybe a spring has come off.
It may be an idea to have a quick look inside the microwave to see if you can see any broken parts near the door release... in some cases it is possible to re-glue broken plastic. Do not use super glue as this will not hold plastics properly, you need "evo stik - hard plastic adhesive" for this job.
BE VERY CAREFULL WHEN GOING INSIDE YOUR MICROWAVE! not only does it contain lethal voltages (even when turned off and unplugged), but if you do not put it back together properly you could have microwave leakage which is not good.
Given the prices of microwaves these days it may be nearly as cheap to buy a new one as pay a microwave expert to fix yours.
Mar 06, 2011 | Microwave Ovens
Hadle from microwave broke
You will need to remove the handle from the door, remove the inner lining from within the door. now the handle can be taken out and replaced or mended with a super glue if broken( if part is difficult to obtain).
Once the handle is put in place make sure that the inner lining is put back in the correct order.
If the handle comes with the lock then the spring settings also should be reset.
Dec 30, 2010 | Kenmore Microwave Ovens
I arrived home from a week of traveling for work and all of a sudden my magic chef mco160uw doesn't work anymore!
thats life, if it can go wrong it will go wrong?
its just unlucky it went when it did most likly it was sat about and got cold and damp, you come home switched it on,,, it went pop! and died on you
its a comon thing with microwaves there very much like light bulbs,,, work for years then for no reson at all the just dont work any more,,,,,
my advice it check the fuses if all ok, bin the microwave,,, dont be temted to go inside of it as you may just kill your self doing it,,,there are 1000' of volts of power inside the thing and if you tuch the wrong part it fry's you the capacitor can hold its charge for a very long time and this charge will kill
have you ever seen a tazer working???
well this capacitor is its "very big brother!" and its not a case of,,, big deal, only 20.000 volts it realy is a big deal as its more likely to be 200.000 volts
please just bump it if its not a fuse in the plug,,,,,,,
be safe not dead
Oct 23, 2009 | Magic Chef CMV1000B Microwave Oven
The latch on kenmore micro #721-62622200 is broken at bottom
In order to have the correct operation of the door latch mechanism and latch switches.
  1. Ensure correct adjustment of the Door and the Latch switches.
  2. Wipe off any dirt or grease around the door key where it touches the latch switched and door hooks with a soft cloth. Maintaining the smooth movement of the latch mechanism and switches etc�
  3. After replacement of the latch mechanism and/or Latch switches. Make sure to confirm a smooth operation of these parts are in order.
to view the exact diagram of how to do this manually just click the link http://www.applianceaid.com/micro8.html
Mar 07, 2009 | Kenmore 62622 Microwave Oven
Magic Chef Microwave table does not turn , Model MCD990SC , Serial # 20600806 jojonew8@aol.com
not sure about this one. but if you remove the bottom, you may find the drive belt has broken. if this is the case just cut the end straight and super glue
Feb 19, 2009 | Magic Chef MCD1110ST Microwave Oven
Dacor DCM24 - Security screw/tamper proof hex bit size?
It's a a T20H Torx type or GTXH20-100, available from hardware stores, or places like Lowe's or Wal-Mart.
Some folks just break or bend the post in the middle, then insert a small flat head jeweler's screwdriver in the space between the post & outer edge of the hole. A sharp tap with a hammer will loosen them a bit.
Otherwise, you can use a hacksaw or Dremel tool to cut a groove in them, then use a flat head screwdriver to remove them.
Just be sure that any special grounding screws get put back where they were to ensure proper grounding of the case, an important protection from shock hazard in rare cases of internal wiring breakage.
The Dacor DCM24 is essentially a rebranded Sharp R930A and I have the full service manual here at my site.
As to what's wrong with it, I would say your secondary interlock (bottom door switch) has failed.
The service manual will cover it, but there's additional info here: http://www.microwavedisplay.com/doorsw.txt
The best place to order Sharp parts is Tritronics.
Sep 23, 2008 | Dacor DCM24 Convection/Microwave Oven
Where does the light (lamp) in a Kenwood SJ SS 25 microwave go? I ordered a bulb but am unsure of how to put it in when it arrives. The booklet that came with the microwave says "don't do it...
I did not fix the problem. I ordered a bulb (lamp) and subsequently saw it is beyond my knowledge to install it. I'll communicate with the store where I bought it 3 months ago and if they won't deal with it, I'll pay a repairman to do it.
Aug 20, 2008 | Microwave Ovens
The bulb is not working in my Panasonic NN-A554W inverter slimline combi oven and I do not know the size/number to obtain a replacement. I know you are supposed to get in an engineer but that is a bit...
It's a T170 type bulb (should be very common at a grocery store or hardware store) rated at 240 volt, either 20 or 25 watt is okay, and if you order it as a spare online, it may come with the 90-degree bracket.
You can see a good photo and detailed specifications here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 06, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
71 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
