Question about Frigidaire Affinity ATF7000E Front Load Washer
The Affinity front load washer is not spinning to complete the cycle. The washer still has a little water in it.
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Please score this accordingly. Thanks!
Posted on Apr 10, 2011
My Washing Machine is not spinning all the water out of my clothes.
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Frigidaire FAFW3517KN Affinity Series...
I have an affinity washer and dryer. The last loand did not complete its cycle. It is partially full of water, but not enough to seap out. Itmakes a buzzing sound and will not spin. It is not the type of...
It sounds like the drain pump has stopped. If it still has water in it and you turn it on (in the spin only cycle) the drain pump should be running and you sould be hearing the water drain. The washer will not spin until the water is out. Depending on how handy you are determines whether you can access the drain pump and remove the obstrustion. There is also a trap to catch debries from going into the pump. This could be plugged, but normally you don't hear a buzz. You hear the drain pump working but no water going out. Good luck
Apr 23, 2011 | Frigidaire Affinity ATF7000E Front Load...
My washer is not spinning. What can I do to fix it?
front load infinity washer will agitate but won't drain and spin at end of cycle; water sits in botton of tub
Jan 17, 2011 | Frigidaire Affinity ATF7000E Front Load...
Won't do spin cycle
http://www.servicematters.com/maytag_library/docs/16022808.pdf
http://www.repairclinic.com/Washing-Machine-Repair-Help
http://frigidaireservicetips.com/pdfs/360_TumbleActionWashers.pdf
OK please find above a service and repair manual and a DIY washer self help site, with all this and the troubleshooting procedures in the manuals you should be able to isolate and repair.
May 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
Frigidare affinity model # atf6000es won't spin in
sometimes in the bottom right hand corner of the machine there is a little face plate and allows to you unclog foreign material that collect over time.
Nov 06, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire Affinity ATF7000E Front Load Washer Logo
61 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
