Question about Kenmore 74932 Gas Dryer
I need a diagram for a Kenmore gas dryer drive belt. How do you string it around the idler pulley?
  • Kenmore Master
  • 2,696 Answers
Wrap the belt around the drum with the smooth side up not touching the drum then pinch the belt together,pull it under the pulley and wrap it on the motor,the belt will separate when you wrap it on the motor shaft....copy and paste,watch the video..........http://www.youtube.com/watch?v=zpUqCrLaI7g
Posted on Apr 10, 2011
Kenmore 110.731102100 Gas Dryer replace belt
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
Leave the drum in the machine. Now, directly in front of the motor on the floor of the dryer you will see two slots. This is where the idler pulley will go. You'll notice on the pulley at the bottom of the bracket a piece of metal sticks downward. This will sit in the slot closest to the dryer wall, and the end of the bracket will slide into the other. You'll want to slide the end in first. Now with the pulley in place take the belt and put it around the drum tread side down. To hook the belt around the motor pulley you'll have to pull the idler pulley towards closest dryer wall and place the belt around the motor pulley. Slowly release the idler pulley and thats it. Put it together and your done.
Jun 03, 2012 | Kenmore Dryers
I have a Kenmore Gas Dryer (model 11087471810) that threw its belt. I have the replacement belt and know how to replace that. When I opened the bottom of the dryer, I noticed the Idler pulley sitting at...
The idler pulley/tensioner fastens into two slots in the base of the dryer to the left of the motor . The belt goes around the drum then through the idler to the motor pulley ,you have to make a loop with the excess belt and feed it through the idler pulley, i normally pull the plastic pulley towards the right side of the dryer to give enough belt to go around the motor pulley then let the plastic pulley rest on the backside of the belt. do not turn the drum too much as you may pull the belt back off .
May 13, 2011 | Kenmore Dryers
http://repair2000.com/wpoolbelt.htm same as kenmore, good luck,, this is the best site i have found for doing this with pictures
Apr 10, 2011 | Kenmore Dryers
I have a Kenmore 70 Series Dryer and the belt broke. I ahve since ordered the replacement belt, but am uncertain how to replace it. Is there somewhere I can view a diagram of my dryer so I know where the...
pulley fits into slots in bottom of dryer near motor pulley. idler pulley will be to the left of motor pulley looking at it from the front. loop belt thru idler and place around motor pulley.
Jun 26, 2010 | Dryers
A constant clicking noise near the motor of my maytag dryer. seems something is slipping as occasionally the drum and belt slow down
It sounds as if the idler bearing has started to fail see this picture http://sites.google.com/site/sublimeappliancerepair/_/rsrc/1246721031553/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info/Norge%20dryer%20with%20drum%20removed.jpg
The idler pulley in the picture is behind the motor.
I would check the ilder pulley to see if it rotates freely and does not have any odd side to side movements. If it does then replace the idler pulley and belt.
Belt: http://www.appliancepartspros.com/part_details.aspx?part_id=4043963&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d47809%26diagram_id%3d681078
NOTE: Before you remove the idler pulley and belt note carefully the installation position of the belt, idler arm, spring and the idler pulley. For a first timer trying to do this it can be quite frustrating to get them all positioned correctly.
Idler pulley:
http://www.appliancepartspros.com/part_details.aspx?part_id=4373393&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d49146%26diagram_id%3d673577
I hope this has been useful information to you. Good day.
Jan 06, 2010 | Washing Machines
Belt drum replacement
If this is a Whirlpool manufactured dryer (which inlcudes Kenmore, Roper, Estate, Kitchenaid, and Frigidaire), just follow these steps:
a. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
b. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
c. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and locate diagram H.
NOTE: It is normal for the idler pulley to come loose when there is no belt tension.
If your dryer is not manufactured by Whirlpool, or if you simply aren't sure, please post back with your model number so I can give you more accurate information. I hope you find this helpful.
Sep 01, 2009 | Dryers
Need to install drive belt- lady kenmore dryer..loop designation
The belt probably broke first, which caused the idler pulley to come loose. This is normal. With no tension on the pulley it will commonly fall over. To re-install, follow these steps:
1. Loop the new drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. If this is a Kenmore dryer, it will be manufactured by Whirlpool. Refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jun 25, 2009 | Dryers
KENMORE SERIES 80 DRYER..The Tensioner use it or not and how?
To fit the new belt, you will need the idler pulley (tensioner)...
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side. Once the belt is pulled through the idler pulley, pull it around the motor pulley (this should force the idler pulley to "open up" and add tension).
If you still need help, I will try to provide you with a diagram shortly.
Mar 02, 2009 | Kenmore 62622 Electric Dryer
Drum belt assembly
take the belt and put it around the drum with the grooves touching the drum, then push a loop of the belt thru the idler pulley bracket and hook it onto the motor pulley. then the idler pulley and bracket will cause tension on the belt. if you need to see a picture then search your model number on google and it should show you a picture of how the belt goes around the motor.
by the way you dont have a good model number, or it is too new to be in most web sites.
Jan 22, 2009 | Kenmore 72802 Gas Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore 74932 Gas Dryer Logo
100 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
