Garden Logo
Posted on Apr 10, 2011
The switch on my corded hilti kwik-driver 2700 drywall screw gun is shorting out. I know that it's an older model, but it works like a champ. Finding a replacement switch is proving to be a challenge, so if you know of any distributor that still handles this part I could use yiur help. Thanks, James Ykimoff
5 Related Answers
myob247
Georgia B
  • 1342 Answers
  • Posted on Jun 01, 2008
SOURCE: Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
Anonymous
  • 4 Answers
  • Posted on Jan 02, 2009
SOURCE: How do you remove the Handle from the Hoover Windtunnel Deluxe to replace the switch?
Removing the handle assembly should be easy after removal of the two screws. It may be binding or hanging up on the self-propel cable...or the plastic may just be stuck/binding. Note that the handle slides in and out of the vacuum unit along the same axis as the two screws (i.e. slides straight off the back towards you when you are standing behind the vacuum). Try to pry it off gently w/thin-bladed screwdriver or butter knife (careful now!). Not sure about the smoking issue but you may have a severely plugged filter and the unit is overheating as a result. Check that out immediately/first to avoid fire or expensive motor burnout.
Anonymous
  • Posted on Jan 03, 2009
SOURCE: disassemble to repair
I just decided to try to fix mine. There are all together 5 screws. The two on the handle are covered with plastic caps which can be pulled out by sticking a duct tape and pulling it up. The other three screws are in the thumper head and are covered with the purple violet rubber piece. I removed it with my fingers. There are also two plastic bolts in the head of the thumper opposite to the handle. I removed them by using a sharp knife to loosen them and pulled with pliers.
I purchased two thumpers over time and in both the switch failed. I see that the switch in the handle is linked with the underlying mechanical switch by a very thin plastic piece. What a miserable design. That piece broke off in both thumpers rendering them unusable.
Good luck. Artur
Anonymous
  • Posted on Feb 03, 2009
SOURCE: Euro-Pro Steam Generator EP8015 - Rocker switch
The screws holding the unit together are T-20 TORX screws; the center post makes them anti-tamper TORX screws. These screws are used in applications in which the manufacturer does not want the average consumer to attempt repairs. Please don't take this wrong, but if you have to ask about the "unusual 6-sided screw", then you shouldn't be opening the unit.
Unfortunately, when the heating element rocker switch gives out (3-4 years), it is usually about time to overhaul the entire iron (both the tank portion as well as the iron portion). Other things that can cause problems are the thermostat and the pressure actuator.
Contact A2A Consulting at 1-888-830-3563; they can probably fix the unit for you.
Anonymous
  • 152 Answers
  • Posted on Mar 15, 2009
SOURCE: hilti te 10 switch problem
You may research your area for a Hilti service center / dealer or order your part directly from
www.hilti.com
or call (866) 445-8827
Good luck
Aduz
1helpful
How to replace brushes in a drywall screw gun
Take off the three screws in back of the handle and you should
see the brushes when you remove the back handle piece.
you can change the carbon brushes alone or you can change the holder also if its damaged ,
2answers
Hi, my hitachi drywall gun runs good but the bit dosent spin, it dont screw. any idea. thanks
drywall guns wont spin until you put pressure on the tip, load a screw and put it to the wall (or whatever) add pressure and pull the trigger
Hi, I am a Japanese carpenter. I recently purchaed a SF4000-A and dont understand why it features variable speed control switch. Can someone please teach me how I am supposed to use this feature?
The SF4000a Is a cordless Drywall Gun. Even thought it has variable speeds most people run it full speed and then press and engage the chuck to run the screws in. The variable speed is used more to back out screws in reverse
1helpful
2answers
Replacing the driver tip on Dewalt Dry Wall Screw Gun
yes,when you look at the front portion of the gun, the tip nozzle thing is actually two separate external parts. The foremost aluminum nozzle and the twisty black plastic thing behind it will pull straight off the piece that is reverse threaded onto the gear box.
Need to know how to operate milwaukee screw gun?
I hope you're talking screw gun and not drill/driver. Screw gun used specifically to set screws in drywall. Make sure you have proper tip in gun (usually #2 phillips). There should be a rotating collar on the gun to control screw depth. The screw should only "dimple" the drywall. It should not tear the paper but should be below the plane of the drywall. To check depth run a putty knife over the screw heads. If you hear it hit, screws need to go a bit deeper. To work quickly; lock the trigger on and place the screw on the gun. Apply steady pressure and let the screw walk into the board until gun breaks free. Takes a bit of practice but pretty soon you'll be flying.
How does the adjustable depth drywall bit work? The bit inside keeps spinning and does not drive screw into sheetrock?
It's not the tip, but the screw gun itself. The screw gun has a clutch on it that allows you to set the screw at different depths. You must adjust the screw gun to the desired depth. The deeper you want the screw to go, the less the clutch will slip.
Jim
1helpful
How do i take off the chuck from my dewalt 18v xrp so i can use my hilti smd57 mag (drywall cont.' screw magazine) i unscrewed the screw down the shaft but now im stuck????
go to the tip section or under my profile in the section and there are detailed instructions on how to do this. Let me know if you still need more help.
Bosch sg 45 drywall screw gun
You have to replace the entire depth guage assembly (the front plastic pieces where the bit driver is). Unfortunatly Bosch does not make the individual pieces for this gun. Any Bosch service center will be able to supply you with this piece
Top Garden Experts
Jay Finke
Jay Finke
john h
