Question about Exercise & Fitness
I have a Healthrider s500xi that is 10 years old and has been lightly used. It had been working fine until a few months ago. The control panel lights up when it is turned on, however when the start button is pressed nothing happens. I am wondering if it is repairable.
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
SOURCE: Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
Posted on Aug 13, 2008
  • 6 Answers
SOURCE: I have a bowflex tredclimer tc1000 won't turn on.
I have a TC3000 and when it wouldn't turn on I recalibrated it using the directions from the owners manual. It's now working. Give it a try.
Posted on Jul 29, 2009
SOURCE: control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Posted on Sep 21, 2009
  • 64 Answers
SOURCE: Life Fitness T3 treadmill won't turn on. Power
Could be. If you had to take it apart, I would definately check the wire harness connection. Also if there are bolts that were removed, check to make sure none of those pinched the harness when reassembling.
Posted on Nov 17, 2009
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Display is in 'demo mode'?
Before inserting key hold down stop key then insert key then turn off demo mode
Jun 03, 2015 | HEALTHRIDER S500XI TREADMILL Console
I have a Hampton Bay Midili fan which I just installed about a month ago and it was working fine. A few days ago when I flipped the switch on the light flickered on and off consistently until I turned the...
in many of these remote controlled lamps you cant use the new spiral light bulbs .. you can only use standard incandescent lights .. if thats not the trouble then you may indeed have a bad controller (in the fan) .. there is probably at least a 90 day warranty maybe as much as 3 years .. make sure the wire nut power connections are secure inside the fan.. if one of the the wires in the fan are not making contact then you will see a similar problem .. once in a while i have seen strong external RF signals interfere with the controller but thats rare and usually doesnt last long ..
i would : 1. check all the connections .. 2. replace the light bulb to make sure its not flakey or the wrong type .. 3. try to get the fan replaced in warranty ..
Jun 06, 2010 | Vacuums
I have a Whirlpool range hood model #RH4930XD81 approx. 10 years old. A few months ago, the light and vent fan just quit working. They were both working fine and just would not turn on one day. Any...
probably need new replacement parts......... new hoods these days start out at like 60 dollars,,, i would probably replace the unit with the age of it, because the parts needed for that will exceed prob 150 dollars
Feb 05, 2010 | Kitchen Ranges
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Exercise & Fitness Logo
67 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
