Question about Mitsubishi WS-65809 65" Rear Projection Television
Hello,65613 mits i cannot get my tv to stop rolling on ant A.also it will not remeber any channels from cable.on antB the picture will remain still .any suggestions
  • thegrother5
    thegrother5 Sep 15, 2008
    I also have model #65513 and replaced the cap's that caused blinking green light and that lasted for about 6 months and now this new problem. I'm no expert with multimeter's. What I did is set meter to 200 acv and attached leads to both ends of ic9c25 with the set unplugged it read 0. plugged in it read 2.3 when I turned set on it read 1.7. If I did it right does anyone know if those readings indicate a bad IC? Recommend replacing the capacitors next to it with the same kind?. If you recommend replacing are there any tips on procedures. I replaced the Dm board caps fairly easily. Thank you!
  • 927 Answers
Good Day, boofis68;
Sound like you may have voltage concern,9 volt source. Check for 9-volts DC to the Terminal PCB at connector JA pins 57 and 58 if missing, check IC9C25 (9-volt regulator) part # 270P677030 on the Signal PCB and replace the two caps. Good Luck, big IRISH.
Posted on Aug 31, 2008
SOURCE:
How do I add ANT-A to the list of devices on my Mitsubishi WS-65613?
you need to have a strong enough signal present before they can be added. connect your antenna or your set top box. then check
Dec 24, 2014 | Mitsubishi WS-65613 65" Rear Projection...
Besides the horrible animation of Bob's Burgers, why is my screen rolling like that on the lower half?
If this happens on one channel only call your cable or satellite provider.
If this is happening on all TV channels locate the vertical hold button on your TV and turn the button slowly until the picture stops rolling, if it increases turn it in the opposite direction.
Jan 07, 2013 | Televison & Video
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How to program with cable using remote
Hello
1 Find and disconnect the cable that is connected to the
ANT IN terminal on your cable box.
? This terminal might be labeled "ANT IN", "VHF IN" or
simply, "IN".
2 Connect this cable to a two-way splitter.
3 Connect an Antenna cable between an OUT terminal on
the splitter and the IN terminal on the cable box.
4 Connect an Antenna cable between the ANT OUT terminal
on the cable box and the B-IN terminal on the RF(A/B)
switch.
5 Connect another cable between the other OUT terminal on
the splitter and the A-IN terminal on the RF (A/B) switch.
6 Connect the last Antenna cable between the OUT terminal
on the RF (A/B) switch and the ANT IN (AIR/CABLE)
terminal on the back of the TV.
After you have made this connection, set the A/B switch to the
"A" position for normal viewing. Set the A/B switch to the "B"
position to view scrambled channels. (When you set the A/B
switch to "B", you will need to tune your TV to the cable box's
output channel, which is usually channel 3 or 4.)
OK
Jan 01, 2011 | Samsung SlimFit TX-T2782 HDTV
Cannot connect to cable tv
Yes, connect cable to Ant A and ensure the TV is on the input for Ant A.
Then go into the setup menu and ensure that the Input is set to Cable not Antenna.
Next, choose the auto program option to load your channels.
If you still don't get a picture and you have a small tv to bring to this outlet try this and make sure you are able to get a picture.
If you still can not get a picture then the outlet is not active and you need to call your service provider and ask them to activate the outlet for you.
Dec 29, 2009 | Mitsubishi VS-55707 TV
I have cable and when i plug it into my tv i only
The tv will only process cable channels when set to 'ant cable' . After the scan, you should be able to view all channels provided on the frequency.
If you want more cable #'s, you will have to pay for those or get a cable box. If you don't find your local channels in the lineup, you will have to use a switcher, or hassle with unplugging and plugging the antenna. This is true for ATSC broadcasts. Please give feedback if this helps. Or tell me more.
Sep 27, 2009 | Mitsubishi WD-60735 Projection Television
My sanyo tv will not show that the cable is there, even though it is hooked up. I tried adding/searching for channels but to no avail. What can I do to fix it?
HELLO. sounds like you need to go in the menu and find the setting for (air tv ant)/(cable tv ant), and reset.the setting to the cable ant setting. and see if that works "good luck"
Aug 02, 2008 | Televison & Video
Tv/vdr/cable box
Your hookup is correct- Your VCR needs to be tuned to channel 3 or 4, to match the cable box.
Also, the VCR channel output needs to be matched to the TV. If VCR menu options are displayed on the TV then this part is right. If not, then set either the VCR or TV to the correct channel.
May 11, 2008 | Sharp VC-A420U VHS VCR
Ws 65613
1-800-552-7278 Mits parts = still gonna cost ya.......T.
Oct 24, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
184 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
