I have been using the vga feature for about a month now on my curtis tv model number lcdvd326a, the other day when i tried to use it, it just started reading no signal on the screen once i changed the source to vga. I then purchased a new connection, but it still read the same thing. What else could stop my vga feature from working on this tv less than 5 months old.
    Novelist:
  • 159 Answers
Hi, I've posted many solutions about this phenomenon, more than likely you have a cold solder issue where the vga connector lays against the printed circuit board. If you can safely remove the plastic housing of television ( unit unlugged of course ) then use a stong magnifying glass/jewelers loupe to see for signs of breakage along the radius of the solder joint ( will resemble little volcano type hills with the vga connectors leads poking straight through them ) you may even see the breakage by trying to jiggle the vga connector itself. resoldering the connection from both sides is preferrable whenever possible-but seeing how the manufacturers use wave solgdering to acheive this it is not always possible on the retail side to repair. I hope this helps, Prodzilla
Posted on Apr 10, 2011
Curtis lcdvd326a keeps blinking and says no signal
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 26, 2014 | Curtis LCDVD326A TV
After a power surge my tv had a picture but no sound when the lights came back on.
Check its speaker first. If found OK, check and replace damaged component/s at its audio output stage circuit. Contact any service technician. If you wish to get some details; check the site linked here.Viewing it in "Mosaic" will make surf easy.
Feb 24, 2014 | Curtis LCDVD326A TV
Parts model
Maybe Curtis can tell you but most likely the screws are metric.
Jan 28, 2014 | Curtis LCDVD326A TV
Tv does not turn on with remote
I assume other remote functions work since you only mention turning off/on. this would most likely be a bad switch in the remote and probably not be worth repair. You can find a replacement here:
Jan 06, 2014 | Curtis Televison & Video
Does the LCDVD326A have the ability to attach headphones? If so, where are the connections?
First of all, here's the manual:
http://www.curtisint.com/html/custservice/manuals/CUR_LCDVD326A_EN.PDF
Refer to page 11. Apparently this set only has audio input connections (as analog audio) It does have an audio output but it is digital audio. you can't just plug in speakers or headphones, you need an adapter to convert digital to analog.
If you're a techie and want to know about SPDIF, look here:
Everything You Need to Know About the SPDIF Connection Hardware Secrets
You will need the converter:
Fosmon Digital to Analog Stereo Audio Converter Adapter Changes Digital...
and a cable to connect the adapter to the TV (choose the length you want)
AmazonBasics Digital Optical Audio Toslink Cable 6 Feet 1 8 Meters
they don't make it easy, do they?
Good luck
Oct 19, 2013 | Curtis LCDVD326A TV
LCDVD326A-2 REMOTE CODE
Code to Curtis is 1052. If you wish to get more details, check the sites linked here. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 07, 2013 | Curtis Televison & Video
Curtis tc lcdvd326a
see the diagram attached. However if you are using CRT tv FOR TO use the computer you must need some converter see it.
God bless you960a8614-3ccb-4da5-a137-b8027bcad5db.jpg9e539faa-e98c-4eaf-a01e-efc87cc5bc5d.jpg
Jul 27, 2013 | Televison & Video
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
