Question about Toshiba 32D46 32" TV
TV will not turn on manually or with remote when used more than 10 hrs. Have to wait 24 hrs before it turns on again.
  • 10,594 Answers
This kind of problem occurs due to bad capacitor or devalued resistor in power supply section after long period of service, please replace bad electrolytic capacitors and devalued resistors in power supply and deflection section to solve this problem.
Capacitor and resistor replacement requires soldering work with proper tools and its job of technician, please contact local tv repair shop as any attempt to replace parts on circuit board by novice would caused more damage.
Hope these info will help.
Thanks.
Posted on Apr 10, 2011
LG TV Button will not turn on tv, Remotes won't either. Have checked power supply and it's ok.
Have you unplugged the tv then plugged it back in--this will usually turn the tv on----have you had a power failure---brown out---power disruption of some sorts---if so unplug the tv for 24 to 48 hrs---this gives the tv a chance to reset---ck with your manual for situations of power problems as it may have instructions for this---all of this is based on that the batteries are good in remote.
May 31, 2017 | LG Televison & Video
Tip
RCA Universal Remote Code Search Models RCR312W - RCR311BN - RCR311BIN RCR311SN...
RCR311SN - RCR311STN
To setup your RCA Universal Remote Control with your TV or other devices, you can perform a code search. A code search tries to turn your set off with different brands' remote control codes until it finds one that works with your set.
Here are the steps for an RCA Universal Remote Control Code Search:
  1. Turn on the device you would like to control.
  2. Press and hold the device key (TV for example).
  3. While holding the TV key, use your other hand to press and hold the ON/OFF key.
  4. Wait until the ON/OFF key light comes on and stays on, then release both keys.
  5. Point the remote at the front of the TV and press PLAY.
  6. Wait 6 seconds while the remote sends a batch of 10 codes to your TV. If your device turned off, go ahead to the next step. If the device did not turn off, press play again and wait 6 seconds again.
  7. When your device turns off, press the REVERSE key on the remote and wait 2 seconds. If the device turns back on, press STOP and your remote is now successfully programmed for controlling that device. If the device does not turn back on, keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
I hope that helps.
on Apr 07, 2010 | RCA RCR311S Remote Control
Tip
I hope that helps.
on Apr 07, 2010 | RCA Universal Remote Control
Model #3217. Why doesn't remote work?
Try removing batteries and pressing all buttons in case one is stuck. Reinstall batteries and try again.
Apr 09, 2016 | Televison & Video
Spilled coffee on dish remote for pano sonic tv now remote won't work
Remove batteries and put remote in rice. Rice will help to remove moisture, wait 24 hrs and replace batteries. If still not working try again or contact company, remotes aren't that expensive.
Jun 11, 2014 | Televison & Video
Tip
I hope that helps.
on Apr 06, 2010 | RCA RCR311B Remote Control
Why is my LCD TV not powering on after resetting to factory settings?
Kindly study the operation manual and follow instructions for installation from the beginning. You may have to switch off the TV manually, switch off power, remove plug, wait for sometime and retry this.
Jul 30, 2012 | Toshiba Televison & Video
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting...
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Jan 17, 2009 | Toshiba 36A43 36" TV
TV doesn,t turn on
the power regulater for your system have a short take it to a tech to have him fix it orelse you might cause further damage.
Feb 17, 2007 | RCA P46812BL 46" Rear Projection...
Toshiba 32D46 32" TV Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
