Question about Universal Remote Control RF20 LCD Remote Control
I have an RF20 and I just got a new comcast cable box. I have programmed each button individually and am having trouble programming a few buttons. Can anyone help me?
4 Suggested Answers
SOURCE: comcast remote's ok button doesn't work with xbox 360
Sorry, the Red Button won't work, but you can map the A button on the Comcast remote instead. It's almost the same thing... Your fingers will barely know the difference.
1. Press the Aux button at the top of the remote.
2. Hold the Setup button until the Aux button flashes twice.
3. Enter 994 on the keypad. The Aux button will flash twice again.
4. Now push the Setup button once. Enter 00001.
Finally, push the A button The Aux button will flash twice. You now have the A / Select / OK / Green button mapped on the Xbox360.
--If you want to switch the A button back to default, just do the same sequence but this time push the A button twice.--
Posted on Apr 16, 2009
  • 60 Answers
SOURCE: "Select" button doesn't work-Cox universal remote for XBOX 360
Depending on the specific remote, some buttons may not work with all systems. HOWEVER, in many cases the things you thing the "select button" would do, are done by the "play button" instead (IE: That's how I have to select DVD menu options with my remote).
If that is not the case with you, you can try a different programing code.
Posted on Sep 19, 2009
Testimonial: "I tried that it didn't work. And I tried the programming codes that I found online for the exact same problem but a comcast remote instead of cox."
SOURCE: replaced the batteries in my RF20 Universal Remote, it still thinks I have the old low batteries and will not work
Did you ever fix this problem? I have the exact same problem
Posted on Dec 13, 2011
How to program my decibel electronics jumbo universal remote to my comcast cable box
I pushed code search different blink appeared pressed tv press code then use on buttons. On all the code
Dec 20, 2012 | Televison & Video
What are the remote codes for Sony RM-EZ4 / Haier TV, Comcast Xfinity cable box?
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. Press the SET button.
  3. On the remote control, press the appropriate component button.
  4. Using the number pad, enter the component's manufacturer code.
  5. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  6. Press the ENT button.
  7. Point the remote control at the component.
  8. Press the POWER button to verify operation.
Comcast offers several remote controls. The type of remote you get depends on the device you're using. Some Comcast remote controls are multi-device or universal remotes, while others only control the set top box and TV.
May 06, 2012 | Sony RM-EZ4 Universal Remote Control
How do i program my comcast remote to my panasonic home theater system? SA-HT740 series
I have the solution! Get comcast to give you the remote with the GREY Ok/Select button. There are codes for this remote that support the Panasonic home theatre in a box. You can go to comcast.com and find the remote manual for this to see it for yourself. I have 3 boxes and just got a new one and was trying to do the same as you. I found the old remote for one of my older cable boxes and switched it out, programmed for the Panasonic and it all works quite well!
Nov 15, 2010 | Panasonic Home Theater System System
I am trying to program my Vizio Universal Remote XRU9M With my comcast cable box and none of the codes in the manual are working. We tried doing the 9-9-1 thing for the vizio remote which is a little...
Hello, Twomufflers -
Doesn't Comcast provide you with a remote to use for the cable box?
We have AT&T Uverse as our cable provider and have an AT&T remote control for each of our cable boxes.
One of our TVs is a Vizio and we only use the Vizio remote control when we need to change something through the TV menu - like when we change from HDMI input (for cable programs) to AV input to watch a DVD.
Jan 12, 2018 | One For All URC-9800 LCD Remote Control
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
Comcast Remote Control Code
comcast sucks and its tech support are a bunch of idiots. the book that comes with the remote is wrong (and for some reason no one in tech support knows this). the remote requires 5 digit codes and all the codes in the book are 4. typing the number 1 in front of any of the codes in the book, for any device and manufacturer, should fix this problem.
Jan 28, 2008 | RCA HD52W59 HDTV Projection Television
Sony Bravia and Comcast MY DVR Not Working Now
Greetings...
Is the Comcast box digital? and is it a Scientific America 8000 series box?
If so, try unplugging the power to the cable box for a minute, replug and after the reboot see if that fixes the problem...
Ed
Dec 14, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
CORRECT SETUP CODE FOR RECEIVER
Originally Posted by 3FingeredGlove viewpost.gif We can make this work. You didn't mention which setup code you're using, or explicitly say whether the OK/Select button is red or gray (the manual you're using is for gray), so these are somewhat generic instructions. Should work, though. This will provide a power toggle function to the Power key.
Use red numbers for the red OK/Select button remote, grey numbers for grey button remtoes.
Temporarily assign setup code 30842 or 0842 to AUX
1) Tap AUX
2) Press Setup until 2 blinks
3) Enter 30842 or 0842The remote should blink twice
Assign NEC1 IR protocol device 210, subdevice 108, function number 203 to Power (you don't need to understand these numbers)
1) Press Setup until 2 blinks
2) Enter 994 (2 blinks)
3) Tap Setup
4) Enter 00051
5) Tap Power (not All On)
Assign setup code 30135 or 0135 to AUX (this is NEC1, 210.109)
1) Tap AUX
3) Enter 30135 or 0135
Nov 15, 2007 | Onkyo HT-SR800 System
Remote control code needed for this TV
Need to program my Insignia TV to my Direct TV remote. Need code
Nov 07, 2007 | Insignia IS 20" TV040919 TV
Universal Remote Control RF20 LCD Remote Control Logo
183 people viewed this question
Top Universal Remote Control Televison & Video Experts
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
