Question about Karcher K2.26 Electric Power Washer
Loss of ppressure because of leak from motor - Karcher K2.26 Electric Power Washer
  • 92 Answers
Dear Danny,
For sure the leak has to be fixed. Most probably the O rings that prevent the oil coming out or going into the head are damaged. You can open the cover first using a Torx T15 screw driver. The head can be removed by using Alen Keys in many cases. If you find the compartment of the oil under the pump head full of water the seals are damaged.
Now before one changes the seals, the pistons mustbe checked. If the pistons ( 3 in number have scrathes or grooves it is useless changing the oil seals. In that case the pistons must be changed.
If the pistons are found in perfect condition..( which oftenly are not)...then oil seals can be changed....and also all gaskets. This job is better done by a qualkified technician......but if you have the tools and a bit of mechanical back-ground...it is child;s play. Always when working see that electricity is not connected. I wish to add that the high and low pressure seals must be damaged also. Thus the pressure drops. Also sometimes instead of oil they are using a type of grease. You can see it as it resembles butter. As I said if you have the tools and all spares available....go ahead and good luck!!
Regards,
Fulltech.
Posted on Apr 24, 2011
  • Martin Grech Apr 24, 2011
    Please note that I am not responsible, for any misuse, misinterpretation, damage caused to inexperience work, incompetent workmanship and damage or harm caused by irresponsible use of this advice. This is just advice and cannot be held responsible for work being done when myself I am not present.
    Fullteh.
1993 Cavalier has coolant loss. It's losing the
you should have the cooling system pressure tested and inspected for a leak that may only show up under pressure.it could be a slow leak from the water pump,frost plug,head gasket which wouldn`t show up in the oil,heater core.it sounds like a small leak but this is the best way to start to find it.
Apr 02, 2012 | 1993 Chevrolet Cavalier
How are the symtoms diffrent on internal and external head gasket leak? on 1986 honda civic
On an external head gasket leak you can see coolant leaking out between the cylinder head and engine block at the place where it is leaking .
An internal leak usually occurs into the cooling system . When this happens you might find that the cooling system will pressurize and you will experience coolant loss . The coolant loss may occur through the radiator over flow or on the other hand into the engine cylinders .
When this occurs through the engine cylinders you might find that the engine oil level will increase or the oil could turn a milky white color ( depending on the type of oil )
Also the exhaust smoke will be white in appearance as you rev the motor . ( caused by the coolant inhibitor being burnt in the engine cylinders )
Apr 25, 2011 | Honda Civic Cars & Trucks
Oil pump no pressure could
OIL PRESSURE RELAY SWITCH, OIL PPRESSURE SENDING UNIT
Mar 29, 2011 | 2000 Chevrolet Suburban
Really loud noise, smell of burning then complete loss of power
It can be that the capacitor has burst which has resulted in the total loss of power to the motor. So open the vacuum and check for the motor section to find if there is a leak.
Aug 30, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
I repaired an AC leak, vacuumed the system down for 8 hours and am ready to recharge. How much oil is normally (lost) do I need to replace with the freon R134? Is more oil lost in a big leak like a...
Did you repair the leak? You need to before you do anything. You must do a full oil and freon recharge after vacuum. You can find places that will refill with R-12 or equivalant. R-12 operates at a lower ppressure and cools better without replacing any other parts.
Aug 10, 2010 | 1991 Mercedes-Benz 560
Yes the a/c has no power but I can not find the >>>
look on or near the accumilator you can unplug the sensor and jump the wires the compressor should come on with engine running and the a/c switch inside turned on if it comes on and it blows cold replace the switch if it comes on and doesnt get cold the system is empty and needs to be charged.
Oct 22, 2009 | 2008 Dodge Avenger
Karcher K2.26 Electric Power Washer Logo
177 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
