Question about Whirlpool GGW9250PL Gas Dryer
WHERE IS THE FUSE LOCATED IN THE WHIRLPOOL GAS DRYER
  • 59 Answers
If you remove the back panel. you will see the blower housing on the left side. O n the right side of the blower housing near the bottom you will see the thermal fuse mounted above the operating thermastat. To test you will need a Volt/ Ohm meter. Set meter to RX1, take off a lead, and probe both terminals, Look for zero reading, if its high or infinity you will need to replace.
Posted on Apr 10, 2011
Dryer will not heat gas
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 28, 2009 | Whirlpool GGQ8831L Gas Dryer
Gas dryer not hot, do not stop running
Sounds like the thermal fuse (slim white piece located on the blower housing ) Pt# 3390719 , or , the ignitor Pt# 279311 is bad .Start with the thermal fuse first . Disconnect the power and put the 2 wires together (tape). Reconnect power and see if dryer heats .
Jul 13, 2009 | Whirlpool WGD5900S Gas Dryer
Dryer not heating up
Check the following areas to address this issue.
1. Gas valve coils
2. Thermal fuse
3. Igniter
If all the above check out ok, replace the timer or, control board.
Jun 17, 2009 | Whirlpool Dryers
Gas Dryer does not continue to heat.
Check the Following to address this issue--
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 02, 2009 | Whirlpool Dryers
Location of thermal fuse on whirlpool estate gas dryer
if this is a gas dryer and the ignitor is working the thermal fuse is fine.need more info .dose the valve coils make any clicking noisecheck with ohm meter to see if coils open/also is gas on
Dec 31, 2008 | Dryers
Gsas dryer ignitor won't light
HI thanks for your question. the faulty part is a thermal fuse, located at the back. pull dryer out . remove the back panel. clean all lint . clean venting to the outside. thermal fuse is located inside the dryer, on the air duct to the Left a small piece of plastic with 2 blue wires to it. replace this part. thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Whirlpool Dryers
Fuse
This electric dryer has a thermal fuse. If blown, the drum will not turn. On a gas dryer the drum will still turn but no heat. The thermal fuse is located on the blower housing. You have to remove the back panel to get at it. It will be the white fuse located right above the fixed thermostat. Two wires going to it. Catriver.
Apr 26, 2008 | Whirlpool LER2614JQ Electric Dryer
Whirlpool Lgr7646eq2 Dryer
Hi thanks for the question. most times the problem is with the thermal fuse . failure is caused by clogged venting. clean all vents . the thermal fuse is located on the air duct, inside the dryer on the left , a small piece of plastic, with 2 blue wires to it . replace thermal fuse. thanks the appliance doc
Apr 06, 2008 | Whirlpool LGR7646E Dryer
Gas dryer lgr4634eqo GAS
check the thermal fuse located at the back of the dryer for continuity and let me know how you make out
Sep 13, 2007 | Whirlpool LGV4634JQ Gas Dryer
Open Questions:
Strange issue with my gas dryer and the control panel I am having a strange issue with my dryer. I have a Whirlpool gas dryer, Model: GGW9250PW0; and am having issues with the Electronic Control (mfg part 8558753). Yesterday, I went to go use the dryer and I press the "Control On" button like normal, but nothing happened. I did not get any lights or anything, yet when I open the door, the inside light comes on. I have a similar model washer plugged into the same electric outlet and everything there works fine. After researching the issue out a bit, I took off the toe panel and took off the duct-lint (mfg part W10128606) so that I could reach the wires connected to the dryer thermister and dryer thermal fuse better. I then took the wires off both of those as well as disconnected the sensor wiring harness (mfg part 3406653) and used a vacuum to clean out any lint as well as compressed air to clean off those connectors. I re-hooked all the wires back up and plugged the dryer in. I pressed the "Control On" button and all the proper lights lit up. I then pressed the "Cancel" button to turn it off, unplugged the dryer, and put the duct-lint back on. I plugged the dryer back in and tried the "Control On" and "Cancel" again, and it still worked. I then put the toe panel back on, pushed "Control On", then turned on the dryer using the "Hold to Start" button and everything worked like it used to. Here is the strange issue I am having. I ran a load in the washer and when done, I put in the dryer and tried the "Control On" button. Everything came up, but when I pressed the "Hold to Start", nothing happened. I then tried to press the "Cancel" button, and nothing happened. I could turn the knob and the different lights lit up, but none of the buttons seemed to be working. After holding the "Cancel" button for a few seconds it turned off the panel lights. I then pushed the "Control On" button again and had to press it a few times before the panel lights came on. After a little bit of playing with the buttons and knob, I was able to start the dryer. I stopped the dryer (didn't want to run it the whole time in case something is wrong) and tried to start it again. I can get the panel lights to come on, but it seems like the buttons are sticking and not fully working like they should. I don't want to have to buy an expensive part unless I absolutely need to and wanted to see if anyone can think of anything else that might be going on or that I could try before paying almost $200 for a new Electronic Control, especially if I will still have the same problem after replacing this part like some other people have reported. Thanks!
Jun 14, 2013 | Whirlpool GGW9250PL Gas Dryer
See all Whirlpool GGW9250PL Gas Dryer Questions
Whirlpool GGW9250PL Gas Dryer Logo
47 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
