Question about Foxconn P4M9007MB-8RS2H Motherboard
Hi, I've aquired a used P4M9007MB-8RS2H, furnished it with a (properly working) P4 631 plus 2 x 512 MB Hynix PC2 3200U-333-12 modules and connected it to : - a Xilence MP480 with both 24 pin-ATX cable and 8 pin-Power cable, - a 3 pin CPU cooler - a floppy disk drive - a VGA cable (via onboard graphics) - and both Mouse and keyboard via PS/2-connector This configuration should be sufficient as test platform prior to installation into a chassis. So, I'm short cutting the power pins, the CPU-fan is running and I'm getting a single "beep" (about 4 seconds), again and again. Clearing CMS doesn't help, replacing the RAM modules doesn't help, the monitor keeps being dark, the mb is still emitting its "beeps". Can it be rescued? Thanks in advance and best regards from Bremen/Germany, Thomas
  • Foxconn Master
  • 27,725 Answers
The first thing you should be checking are the leads
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 10, 2011
Hi, I want to upgrade my RAM from 256 MB 400MHz DDR1 (hynix) to 1GB DDR1. Do the both will work together or i would have to use 1GB alone? Im having ASUS K8V- VM motherboard. Will it be compatible with...
It will be compatible but it is recommended, you use same type of modules(RAM)
ie 256 MB + 256 MB
1GB + 1GB
Plus the advantage of using two instead of one(If you want 2GB, go for 1-1Gb two modules, depends on you) are, if one fails other works.
Apr 24, 2011 | Computers & Internet
P4M9007MB-8RS2H mbd does not access dvd rw but works fine with cdrw
What kind of connection do you use for each one? SATA or IDE. Take a look at these photos.
They are from hard dsiks but the connectors are the same at the cd-dvd drives.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jan 06, 2011 | Foxconn P4M9007MB-8RS2H Motherboard
Compability with intel dual core 2180
Probably you should find out if proc is in order, because I have same motherboard and my proc is
Intel Dual Core 2160 and it works perfectly...
Dec 17, 2008 | Foxconn P4M9007MB-8RS2H Motherboard
Pin layout for the Front Audio Connector
Hi HomeCPU, if you do not have a manual for the P4M9007MB-8RS2H motherboard than lick the link below & dowload it.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000243
Goto Pg.4- Front Audio Connector Board layout.
Than to Pg.13, Audio Connector: F_AUDIO detailed pic of pin loacations.
please vote...
Feb 22, 2008 | Foxconn P4M9007MB-8RS2H Motherboard
Drivers
For the drivers, access the following page. Fill the "Search by download type" with your motherboard model "p4m9007mb-8rs2h" and the socondr field with drivers.
http://www.foxconnchannel.com/support/downloads.aspx
Forget the Internet security, You will not get it from the foxconn website.
Good luck
Dec 17, 2007 | Foxconn P4M9007MB-8RS2H Motherboard
Drive for foxconn P4M9007MB-8RS2H
You should indicate what OS you are using!
Oct 28, 2007 | Foxconn P4M9007MB-8RS2H Motherboard
Foxconn P4M9007MB
are you connected to the right socket?? try using headphones to check the ports on the mobo..
Oct 04, 2007 | Foxconn P4M9007MB-8RS2H Motherboard
P4M9007MB Motherboard
Yes, VIA VT8237A (stay as south bridge on your mobo) support ATA133. You can use upto two IDE/ATAPI devices.
Sep 27, 2007 | Foxconn P4M9007MB-8RS2H Motherboard
Foxconn P4M9007MB-8RS2H Motherboard Logo
80 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
